Tomcat 6 [message #224256] |
Tue, 25 November 2008 11:32  |
Originally posted by: nowhere.a.com
I just installed Tomcat 6 to Ganymede 3.4
Now when I start Tomcat from the debug view I get:
25-Nov-2008 8:30:01 AM
org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context}
Setting property 'source' to 'org.eclipse.jst.j2ee.server:myapp' did
not find a matching property.
25-Nov-2008 8:30:01 AM org.apache.catalina.core.AprLifecycleListener
init
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path: C:\Program
Files\Java\jre1.6.0_07\bin;.;C:\Windows\Sun\Java\bin;
25-Nov-2008 8:30:01 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
25-Nov-2008 8:30:01 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 357 ms
25-Nov-2008 8:30:01 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
25-Nov-2008 8:30:01 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
25-Nov-2008 8:30:02 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
25-Nov-2008 8:30:02 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
25-Nov-2008 8:30:02 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/47 config=null
25-Nov-2008 8:30:02 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 776 ms
The only place I found "org.eclipse.jst.j2ee.server:myapp" was in the
web.xml file:
<Server>
<Service>
<Engine>
<Host>
<Context docBase="myapp"
path="/myapp" reloadable="true"
source="org.eclipse.jst.j2ee.server:myapp"/>
</Host>
</Engine>
</Service>
</Server>
And there is the "performance in production environments" information
message. This causes an error when a JSP is compiled. It seems to run
OK, but I should not be getting errors.
Tomcat 5 did not show any of these errors.
Wojtek :-)
Re: Tomcat 6 [message #224783 is a reply to message #224477] |
Mon, 08 December 2008 13:37   |
Larry Isaacs wrote :
>>> The "source" attribute on the context is how the WTP Tomcat support tracks
>>> which context belongs to which project in your workspace. The _warning_
>>> is normal and may be ignored. The "source" attribute is managed
>>> internally by WTP and does not need to be included in anything you would
>>> deploy to production. It would not be responsible for any errors, though
>>> differences between Tomcat 5 and Tomcat 6 could.
>> Could you not place this parameter into its own file? Named eclipse.xml or
>> something? That way Tomcat would not read it and report warning/errors/info
>> messages etc.
>> I am assuming that prior to Tomcat 6, the Tomcat xml parser simply ignored
>> extraneous parameters.
> Unfortunately that would be a fair amount of work for very little benefit.
I do not understand why it would be a lot of work. You already have an
XML parser, and the code to extract the parameter. You would only need
to feed it a different file. Same for the config writer, simply point
it at a different file.
I am not trying to be snippy, I just do not understand.
> It's too annoying, modify the catalina.properties file to include a new
> location (such as ${catalina.home}/classes) at the beginning of the
> common.loader list. Then under that location, create a compiled version of
> the org.apache.catalina.core.StandardContext which has a setSource() method
> added. The warning should disappear. If you didn't mind this customization
> affecting all instances of your Tomcat 6 installation, put the modified class
> under "${catalina.home}/lib" and skip modifying catalina.properties.
I cannot locate org.apache.catalina.core.StandardContext. Do I need the
Tomcat source?
BTW, I also get:
Dec 8, 2008 10:19:06 AM org.apache.tomcat.util.http.Parameters
processParameters
WARNING: Parameters: Invalid chunk ignored.
For every JSP which is compiled. Is this related?
Wojtek :-)
Re: Tomcat 6 [message #224849 is a reply to message #224783] |
Tue, 09 December 2008 10:36   |
>>>> tracks which context belongs to which project in your workspace.
>>>> The _warning_ is normal and may be ignored. The "source" attribute
>>>> is managed internally by WTP and does not need to be included in
>>>> anything you would deploy to production. It would not be
>>>> responsible for any errors, though differences between Tomcat 5 and
>>>> Tomcat 6 could.
>>> eclipse.xml or something? That way Tomcat would not read it and
>>> report warning/errors/info messages etc.
>>> ignored extraneous parameters.
>> benefit.
> to feed it a different file. Same for the config writer, simply point it
I wouldn't say a "fair amount" is necessarily "a lot", but it's not a
trivial code change. With the few cycles I have to work on the WTP
tomcat support, this would take a while to get to the top of the to-do
list. If you would like to look into creating a patch for this, I'll
try to point you to the right places in the source code.
>> new location (such as ${catalina.home}/classes) at the beginning of
>> the common.loader list. Then under that location, create a compiled
>> version of the org.apache.catalina.core.StandardContext which has a
>> setSource() method added. The warning should disappear. If you
>> didn't mind this customization affecting all instances of your Tomcat
>> 6 installation, put the modified class under "${catalina.home}/lib"
> Tomcat source?
Yes, you would need to grab the source zip or tar.gz that corresponds to
the version of Tomcat you are using.
> BTW, I also get:
> processParameters
This is unrelated. It would seem to be related to request processing,
when something tries to get request parameter values.
Larry
Re: Tomcat 6 (Parameters: Invalid chunk ignored) [message #224931 is a reply to message #224849] |
Wed, 10 December 2008 20:57  |
>> BTW, I also get:
>> processParameters
> This is unrelated. It would seem to be related to request processing, when
You fix one thing, another breaks...
IE has a nasty habit of trying to resend form information if the second
of two calls to the same URL does not have any parameters.
So if you have a page with a form and it is submitted, parameters are
passed to the server. If the user chooses the same page again from a
menu (and the menu URL does not have any parameters), then IE will
resend the same parameters as from the original submission, but only
after a warning you that you need a page refresh:
Submit:
/app/servlet?myfield=yes
Menu:
/app/servlet
IE will actually try to send:
for the menu call
To get around this, I use an empty parameter string. IE sees something
that looks like a parameter and does not resend the old parameters:
Menu
/app/servlet?=
And this is what TomCat 6 is complaining about. It is harmless, but it
fills up the error log.
So now I need an actual parameter, such as:
/app/servlet?a=a
in the menu.
Posted for anyone else who runs into this.
Explanation:
http://www.nabble.com/Log-warning-after-URL-Querystring-incl ude-%22--%22-td15758085.html
Wojtek :-)
FUDForum. Page generated in 0.04581 seconds
