Home » Eclipse Projects » GEF » Problem with connection and anchor
Problem with connection and anchor [message #224070] Wed, 11 October 2006 08:27 Go to next message
Originally posted by: beconico.gmail.com
--------------010906040404060907060605
Hi!
I have implemented my own anchor to handle connections to the
diamond-like figure that appears in the attached picture. The anchor
class should return one of the diamond's vertices. When I debug my
editor, the anchor class does really behave as expected. However, the
connection is not finally anchored on the right point, but in one of the
bounds' points (see attached figure). I think this behaviour is caused
by the router.
Can someone tell me how I can force the connection to use the point
returned by the anchor class?
Thanks a lot in advance!
Nicol
Re: Problem with connection and anchor [message #224088 is a reply to message #224070] Wed, 11 October 2006 11:22 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Take a look at the logic example where circuits have fixed anchor points.
"Nicolas" <beconico@gmail.com> wrote in message
news:eginvc$7bd$1@utils.eclipse.org...
> Hi!
> by the router.
> Nicol
Re: Problem with connection and anchor [message #224196 is a reply to message #224088] Thu, 12 October 2006 04:50 Go to previous messageGo to next message
Thanks Patrik. I have been looking at the logic example, but I could not
find the solution to my problem. Maybe it is because I did not
understand completely well how the code in the logic example works. For
example, in the example the getXConnectionAnchor methods are implemented
in the Figure class, and not in the EditPart class as I do (this
disturbs me). I have seen they also make use of a provider class, but
don't know exactly how it works. Anyhow, apart from those differences, I
think in the logic example they use the point returned by the
FixedConnectionAnchor class. And this class behaves similarly to my
DiamondAnchor class.
My problem is still the same. The anchor point is correctly calculated,
but at the end it is not used. Indeed, when creating an arc and after
selecting the source node, if I place the mouse pointer over the target
node, a temporary arc anchored at one of the vertices is correctly
drawn. However, when I press the mouse button to definitely create the
connection, a different line is drawn, as in the previous mail's
picture. Also, when I move a little the created connection, it is then
anchored at the vertex.
Hope you can help me. Thanks.
Nicolás
>> Hi!
>> by the router.
>> Nicolás
Re: Problem with connection and anchor [message #224419 is a reply to message #224196] Mon, 16 October 2006 05:38 Go to previous message
Hi, maybe you can reference org.eclipse.draw2d.EllipseAnchor and check
out diff.
QinXian.
在 2006-10-12四的 10:50 +0200,Nicolas写道:
> Nicolás
> >> Hi!
> >> by the router.
> >> Nicolás
Previous Topic:XMI on GEF
Next Topic:Genric Automation Tool
Current Time: Sun Jul 20 20:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.06332 seconds
