Detecting scrolling events [message #222971] |
Sat, 16 September 2006 05:19  |
Originally posted by: dstamkokeng.gmail.com
Can some one help me with detecting scrolling event? I am extending the
Shapes example of GEF. It comes with a FreeformLayer which enables
scrolling in all 4 directions.
I have a painted a timeline figure which is required to be displayed all
the time. Thus I will need to detect scrolling events so that I can
repaint the figure.
Or is there any other way I can get thru this problem? Thanks in advance!
Re: Detecting scrolling events [message #223575 is a reply to message #223211] |
Fri, 29 September 2006 09:02   |
Hi Mateu,
why don't you add another layer to your RootEditPart and adapt the
layer's paintFigure method?
What about this:
protected void paintFigure(Graphics graphics){
Rectangle clip = g.getClip(Rectangle.SINGLETON);
IFigure parent = getParent();
while (parent != null && !(parent instanceof Viewport)){
parent = parent.getParent();
// now you can use the Viewport's bounds:
parent.getBounds()
Regards, Andreas
Mateu Yábar Vallès schrieb:
> I have tried to add a figure to the view port, but it reacts to the
> scrolling events (it is moved like the rest of the figure). Is there a
> better way to have a figure allways in the same position (bottom-left) of
> the screen even when the window is redimensioned or the scrollbars are used,
> that listening to the viewport?
> Thanks
> "Pratik Shah" <none@unknown.com> escribió en el mensaje
> news:eesn0n$dsm$1@utils.eclipse.org...
>> If you're only interested in scrolling events, add a listener to the
>> Viewport's horizontal and vertical range models. But for what you want to
>> do, you could get away with adding the timeline figure to the Viewport
>> instead of its contents.
>> "Mateu Yábar Vallès" <mateu.yabar@justinmind.com> wrote in message
>> news:eep340$6cl$1@utils.eclipse.org...
>>> My solution is the following:
>>> you first need the Viewport:
>>> if viewer is your viewer, you have to do
>>> Viewport port=((FigureCanvas)getControl()).getViewPort();
>>> afterwards you need to add listeners to the port; I don't remember which
>>> is which, but one enables to listen to the move of the scroll and the
>>> other to the size of the window:
>>> port.addFigureListener()
>>> port.addPropertyChangeListener()
>>> You can get the client area by:
>>> port.getClientArea()
>>> Mateu Yábar Vallès
>>> Just In Mind
>>> www.justinmind.com
>>> "Meo Kok Eng" <dstamkokeng@gmail.com> escribió en el mensaje
>>> news:d1fc9c7b14fbbbb853b8889ef62c7d7c$1@www.eclipse.org...
>>>> I think its has to do with the GraphicalViewer of the editor, which is
>>>> ScrollingGraphicalViewer. But I cannot find where to detect if scrolling
>>>> has occur. Help needed.....
Adding figures to the viewport directly to make them immobile [message #536473 is a reply to message #223203] |
Fri, 28 May 2010 08:08  |
Hello Pratik,
I have a very similar problem: I want to place 4 Text labels in the 4
corners of my editor viewport, they are not supposed to be be moved or
affected otherwise by scrolling or zooming. Only when the editor window
gets resized, they are supposed to adapt their position to be in their
respective editor corner.
Label label = new Label("MY COOL PRODUCT 30-DAY TRIAL");
Rectangle constraint = new Rectangle(10, 10, -1, -1);
viewport.add(label, constraint);
Adding them to the viewport figure, however, has no effect: they are
among the children of the viewport but are not displayed. Setting the
"opaque" value of the viewport and the labels to true does not help,
either. I tried assigning the viewport a XYLayout, still nothing to see.
I also tried different orderings of the viewport's children to check if
the labels were simply behind the viewport's contents.
After some debugging, it seems that the labels do not receive any bounds
from the layout manager. That is why the check
child.intersects(graphics.getClip(clip)
in Figure.paintChildren() keeps failing and why the labels are not
painted by the viewport figure.
Any idea what I might be doing wrong? Any help is appreciated, thanks in
advance!
greetings,
Patrick.
Am 21.09.2006 02:39, schrieb Pratik Shah:
> "Mateu Yábar Vallès"<mateu.yabar@justinmind.com> wrote in message
>> Mateu Yábar Vallès
>> Just In Mind
>> www.justinmind.com
>> "Meo Kok Eng"<dstamkokeng@gmail.com> escribió en el mensaje
FUDForum. Page generated in 0.08590 seconds
