Re: obtain webtools sourcecode - HOW ? cvs does not work ? [message #223201 is a reply to message #223169] |
Tue, 28 October 2008 10:33  |
aaa wrote:
> I want to download webtools sourcecode
> I have not found the package with source of builds in downlod section
> (eclipse.otg) :-(
> I have found only one way - CVS as in document
> http://wiki.eclipse.org/index.php/CVS_Howto
> unfortunately :-( get:
> c:\cvs>cvs -d :pserver:anonymous@dev.eclipse.org:80/cvsroot/eclipse login
> Logging in to :pserver:anonymous@dev.eclipse.org:80/cvsroot/eclipse
> CVS password:
> cvs [login aborted]: unrecognized auth response from dev.eclipse.org:
> HTTP/1.1 400 Bad Request ( The data is invalid. )
> I need this sources, is there any way to get them ?
> best regards
> kris
If it helps, according to the document, proxy.eclipse.org is on port 80,
not dev.eclipse.org. I believe you would leave the port off for
dev.eclipse.org and include port 80 if you are using proxy.eclipse.org.
Larry
FUDForum. Page generated in 0.08276 seconds
