Home » Eclipse Projects » Equinox » How do you handle library classes via dependencies?
| How do you handle library classes via dependencies? [message #22318] |
Thu, 10 April 2003 13:24  |
I am curious, if plugin A depends on B that has xerces.jar 1.0 and also
depends on C that has xerces 2.0, and A uses xerces, first of all which one
does A use? Second, is there any issue like runtime ambiguous names or
something? How does A know to go to B for 1.0 as opposed to C for 2.0 or
vice versa OR even not use either because they aren't the version A needs?
| Re: How do you handle library classes via dependencies? [message #22469 is a reply to message #22427] |
Thu, 10 April 2003 15:45   |
Originally posted by: kduffey.marketron.com
That sounds similar to my engine where I have a "shared" classpath that any
plugin can stick something into and all other plugins can use it. Sort of
like every plugin depending on one plugin. It is the parent loader to ALL
plugin classloaders. That way, if a given requires class the JVM is asking
any plugin class is not found within its classpath, it goes to the dependent
loaders classpaths, and wont find it there, so then it goes to the parent
loader, which its immediate parent is the "global" plugin classpath that all
plugins share and it can find it there. If not, it then moves on to the
engine class loader, system loader, etc.
"dominic" <dominic@nospam.com> wrote in message
news:b74dne$dr4$1@rogue.oti.com...
> Normally there should be a way for A to say which interface it wants from
> xerces. And that should ultimately come from a central repository of ids.
> Ala com class ids or corba ior. A central key to component management is
the
> idea of mapping an interface with a certain Id. This way if A wants
> IXerces[020] then it does not matter where it gets it from. Does the idea
of
> interface id apeal to you guys ? This would be a minimal reinvention of
the
> wheel but !
> "Kevin" <supreme_java_guru_1@yahoo.com> wrote in message
> news:b7493v$9o0$1@rogue.oti.com...
> one
needs?
| Re: How do you handle library classes via dependencies? [message #22513 is a reply to message #22469] |
Thu, 10 April 2003 16:16   |
Originally posted by: dominic.nospam.com
What identifies the interface ? a string or guid type id. Also can a plugin
specify that it provides more than one interface when it is registering with
shared classpath? Maybe for bacward compatibility reasons a plugin may
decide to provide both interfaces.
"Kevin" <kduffey@marketron.com> wrote in message
news:b74h76$h16$1@rogue.oti.com...
any
dependent
all
from
ids.
> the
idea
> of
> the
> > wheel but !
also
which
> > one
or
> needs?
| Re: How do you handle library classes via dependencies? [message #22600 is a reply to message #22513] |
Fri, 11 April 2003 02:44   |
Originally posted by: Peter.Kriens.aQute.se
This relates back to an earlier posting I did.
MANY problems would be circumvented if plugins were delivered including
libraries like XML parsers they are dependent on (the reused libraries).
The runtime could be optimized to check for equivalence and (maybe on
class level) and only load the same library once.
The GUID approach is a nice approach technically, but in practice it
will be a lot of configuration, which I guess we all know is error prone.
Kind regards,
Peter Kriens
> any
> dependent
> all
> from
> ids.
>>the
> idea
>>of
>>the
>>>wheel but !
> also
> which
>>>one
> or
>>needs?
| Re: How do you handle library classes via dependencies? [message #22643 is a reply to message #22600] |
Fri, 11 April 2003 09:54   |
I can see how this would lead to a clumbered repository of libraries.
Imagine doenloading the same library two or three times for every plugin !
This is the other extreme of the table. Com and Corba have been dealing with
these issues for a long while now.
The simplest thing i see is a core engine that at start up reads all the
plugins and registers what interfaces they provide/need. At run/start time
this engine would return the *exact* interface requested by a plugin.
The dependency *should* only be used when the user starts to load/unload
certain plugins. For example if the user decides to turn off the jdt plugin
then the engine would remove all the interfaces provided by the jdt plugin
from its registry and also inform those interfaces that they are no longer
supposed to run ! of course if the user restarts his system then he would
only get the plugins he allowed to run.
So coming back to the subject packaging (static linking) together plugin
specific libraries does not look apealing to me. Heck this is why we need a
plugin framework in the first place.
Furthermore right now i do not think there is a provision for the platform
to support 2 versions of the jdt at the same time. Unless the plugin
framework becomes so much granular we will never be able to provide the
"capability a la carte" that we need here.
"pkriens" <Peter.Kriens@aQute.se> wrote in message
news:3E966438.4040002@aQute.se...
> Kind regards,
> Peter Kriens
plugin
with
> > any
of
ALL
asking
> > dependent
parent
> > all
> > from
> > ids.
is
> >>the
> > idea
> >>of
> >>the
> >>>wheel but !
> > also
> > which
> >>>one
> > or
> >>needs?
| Re: How do you handle library classes via dependencies? [message #22994 is a reply to message #22643] |
Tue, 15 April 2003 03:22   |
You are sure your estethic feelings are not in the way of your view of
reality? :-)
The real problem I see is that managing libraries by reference is not
working very well in practice. Go and download libs from apache and see
how many have version numbers. DLL hell was caused by the fact that
people did not follow Microsoft's guidelines for versioning. Most
versioning schemes require a discipline that is beyond what can be
expected from most developers.
Lets face it, download time and disk space are no real issues nowadays.
Knowing exactly what a plugin was compiled against (and having that
actual code) seems an enormous boon to reliability imho.
Keeping the repository well managed seems to be very straightforward imho.
Kind regards,
Peter Kriens
>>Kind regards,
>>Peter Kriens
> plugin
> with
>>>any
> of
> ALL
> asking
>>>dependent
> parent
>>>all
>>>from
>>>ids.
> is
>>>>the
>>>idea
>>>>of
>>>>the
>>>>>wheel but !
>>>also
>>>which
>>>>>one
>>>or
>>>>needs?
| Re: How do you handle library classes via dependencies? [message #23037 is a reply to message #22994] |
Tue, 15 April 2003 06:34   |
Which is probably precisely why Microsoft chose a variant of the
approach in .NET. Essentially, in .NET, a component is guaranteed to get
the exact versions of other components it was compiled against (modulo
policy filed). It certainly does make sense for a variety of scenarios.
Despite this, I do understand the hesitation to forcing every component
to always include its dependent libraries. It would be nice if there was
a way to get the best of both worlds. To do this, would require
something else that .NET has, a global cache of libraries. In such a
solution, we could just shove every library into the global cache and
use reference counting. Thus, when a duplicate library is entered into
the cache (determined with a content hash or something), it is not saved
to the disk, but just reference counted.
This would require that we come up with some sort of standard way to
package Java packages so that we could determine the identity...and not
to forget, their substitutability.
-> richard
| Re: How do you handle library classes via dependencies? [message #23162 is a reply to message #23121] |
Wed, 16 April 2003 22:25   |
Honestly guys, this along with my own interest in a plugin engine and not
knowing of eclipse before starting is why I built my own engine. My engine
with XMLPull parser is about 30K in size. It isn't near as robust as
Eclipse, but it works in a similar fashion: plugin repository, each plugin
dynamically loaded with its own classloader, plugin dependencies resolved
all while no plugin code is loaded, extension points and extensions, and so
forth. I'll be working on a generic UI framework similar to what Eclipse and
others are like, where by plugins can build the UI without any plugin code
running, and a proxy is used by the engine to listen for various events of
buttons/menu items that then create the plugin they are being sent to as
needed, and so forth.
Don't get me wrong, Eclipse IDE rocks, and Equinox will prove even better
once it can do all that is on its plate. But the bottom line to me is size.
I want a very small footprint, and the size of the runtime plus the
complexity is more than I personally care to have in my own applications.
However, that said, I do think Eclipse/Equinox have a very solid foundation
and with so many on board to support it, I too am along for the ride! If I
can figure out how to get testing of the core runtime code I am working on,
I am hoping to contribute to Equinox/Eclipse as well! So, while I do like
what I have built and it works well, I also want to contribute to the
Eclipse/Equinox products because of what they offer as well.
Still, despite that these days 100GB hds, 1GB of memory, DVD-R drives and
3+Ghz computers are "almost" the norm, I still believe writing code for the
smallest possible denominator is a good way to go. The code usually ends up
will refined, optimized (eventually) and easy to work with as opposed to
100's of classes to do something similar.
"Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> wrote in message
news:b7k8nm$ol0$1@rogue.oti.com...
> news:3E9BB332.2010500@aQute.se...
> I agree that this is a real problem deserving a solution. Some issue:
> - disk space and download bandwidth are very cheap but not universal and
> product team are continually under pressure to minimize their resource
> usage. eclipse.org has a 45Mb pipe which is saturated 24/7 and Eclipse is
> only 60MB.
> - the requires graph for a given product can be quite large. Some Eclipse
> based products today barely fit on a CD. These products form the basis of
> other products or *optionally* work in conjunciton with them. In addition
> to the scaling issues, we should also consider how the optional prereq'ing
> fits in.
> - as eclipse is used more in generic application scenarios, size does
> matter. For example, you would be disappointed if IE took 10 minutes to
> download the Flash plugin the first time you encountered Flash content.
> Note that this sort of scenario is precisely what is driving the dynamic
> plugins work.
> So, I don't know the answer. Perhaps a hybrid approach. It is definitely
> worth looking for an answer.
> Jeff
| Re: How do you handle library classes via dependencies? [message #23555 is a reply to message #23162] |
Sat, 26 April 2003 10:21  |
I REALLY think you should take a good look at OSGi. Your sentiments to
make things small and beautifull are shared with most of the designers
of the specifications.
Kind regards,
Peter Kriens
>>only 60MB.
>>fits in.
>>plugins work.
>>Jeff
Current Time: Tue Oct 28 13:11:59 EDT 2025
Powered by FUDForum. Page generated in 0.05620 seconds
