Home » Eclipse Projects » GEF » GEF application, not plug-in!
GEF application, not plug-in! [message #222950] Fri, 15 September 2006 12:59 Go to next message
Hey,
Just to check, as I haven't seen any around, is it possible to build gef
based applications that are not plug-ins.
Only just started with gef, I want to build an appliocation where the user
can build their own models with a graphical editor... migth ne a silly
questoin, but as I said, just started.
Cheers
Re: GEF application, not plug-in! [message #223000 is a reply to message #222950] Mon, 18 September 2006 00:58 Go to previous messageGo to next message
Originally posted by: hiran.chaudhuri.softwareag.com
"Con Gaff" <conorgaff@hotmail.com> wrote in message
news:41d2b1b106e9992ae8be7edd46a782cb$1@www.eclipse.org...
> Hey,
Have a look at applications (no matter whether they are GEF-based or not).
Applications are sets of plugins.
Hiran Chaudhuri
Re: GEF application, not plug-in! [message #223011 is a reply to message #222950] Mon, 18 September 2006 03:19 Go to previous messageGo to next message
Originally posted by: mateu.yabar.justinmind.com
For an example of an stand-alone application you can find it in here:
http://www13.plala.or.jp/observe/GEF/GEF_StandAlone.html and
http://www13.plala.or.jp/observe/GEF/GEF_Tool_StandAlone.htm l
It is in japanesse, but the examples are ok (I don't speek japanesse). I
think that it is the only place where this is explained.
However you may try to do and RCP application; in fact I think that this is
the best solution.
Mateu Y
Re: GEF application, not plug-in! [message #223046 is a reply to message #223000] Mon, 18 September 2006 12:04 Go to previous messageGo to next message
Okay, but I don't want to build a plug-in. I wan to t build a stand alone
graphical editor for end users to be able to build their own models.
If I build as an eclipse plug-in can I then have it run by itself?
Would it not be easier to build a totally seperate app from the start?
Re: GEF application, not plug-in! [message #223068 is a reply to message #223046] Tue, 19 September 2006 03:12 Go to previous messageGo to next message
You can
1. make and RCP
2. make a stand alone application, as explained in the links I attached in
the previous message
Mateu Y
Re: GEF application, not plug-in! [message #223074 is a reply to message #223068] Tue, 19 September 2006 06:08 Go to previous message
Right so, going to try a plug-in using RCP which can then be turned into a
standalone app.
Unzipped the Japanese projects, added the jars to the build path but
getting errors. Probably better I go with the RCP approach and do it
properly.
Cheers for your help.
Previous Topic:Issue with Graphics.setAlpha
Next Topic:inverting axis in editor
Current Time: Sat Jul 26 22:29:11 EDT 2025
Powered by FUDForum. Page generated in 0.26094 seconds
