Home » Archived » Voicetools » Error in org.eclipse.vtp.desktop.projects.core
Error in org.eclipse.vtp.desktop.projects.core [message #22075] Tue, 31 March 2009 19:27 Go to next message
Friends,
I have a problem in org.eclipse.vtp.desktop.projects.core export wizard
429. ERROR in
C:\vtp\org.eclipse.vtp.desktop.projects.core\src\main\java\o rg\eclipse\vtp\desktop\projects\core\internals\WebService.ja va
(at line 31)
import org.apache.axis.utils.CLArgsParser;
I insert the "axis.jar" file but still did not work
Can you help me?
Re: Error in org.eclipse.vtp.desktop.projects.core [message #22118 is a reply to message #22075] Fri, 03 April 2009 14:06 Go to previous messageGo to next message
Hi Fernando--
Can you give me some more information about what you were doing? Presumably
using the webservice, built into OpenVMXL, but I'd like to confirm this.
Also, how old is your installation?
Randy Childers
OpenMethods
On 3/31/09 6:27 PM, in article
4d15930f420b12c3cc7796b0d8d5810c$1@www.eclipse.org, "Fernando Pesssoa"
<fernandojpessoa@gmail.com> wrote:
> Friends,
> 429. ERROR in
> ktop\projects\core\internals\WebService.java
> (at line 31)
> Can you help me?
Re: Error in org.eclipse.vtp.desktop.projects.core [message #22159 is a reply to message #22118] Fri, 10 April 2009 17:59 Go to previous messageGo to next message
Man,
yes Openxml.
I put this axis.jar file in
eclipse->windows->preferences->java->installed JRE->edit->add external JAR.
with that the function "exporter to War" worked fine but WebService
still don't work. When I Drag an wsdl File to Webservice folder ,I have
this error into console:
---------- console lines -----
full path: /Teste6/Web Services/WSCTI/.source
null
org.eclipse.core.runtime.CoreException: unknown protocol: c
at
org.eclipse.vtp.desktop.projects.core.internals.WebService$1 .run(WebService.java:318)
at
org.eclipse.vtp.desktop.projects.core.internals.WebService.g enerateAndCompileCode(WebService.java:323)
at
org.eclipse.vtp.desktop.projects.core.internals.WebService.p rocessWebServiceDescriptor(WebService.java:128)
at
org.eclipse.vtp.desktop.projects.core.internals.WebServiceSe t.createWebService(WebServiceSet.java:234)
at
org.eclipse.vtp.desktop.views.ProjectsView$2.drop(ProjectsVi ew.java:308)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 06)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:414)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:237 )
at
org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:119)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
org.eclipse.core.runtime.CoreException[0]: java.net.MalformedURLException:
unknown protocol: c
at java.net.URL.<init>(Unknown Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.set upCurrentEntity(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.d etermineDocVersion(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(Unknown
Source)
at org.apache.axis.utils.XMLUtils.newDocument(XMLUtils.java:369 )
at org.apache.axis.utils.XMLUtils.newDocument(XMLUtils.java:420 )
at
org.apache.axis.wsdl.symbolTable.SymbolTable.populate(Symbol Table.java:482)
at org.apache.axis.wsdl.gen.Parser$WSDLRunnable.run(Parser.java :361)
Resource Removed: /Teste6/Web Services/WSCTI/.source
--------- end console----------------
Actually I have had many problems in try using openvxml with webservices.
can you help me over this problem?
Thanks.
Re: Error in org.eclipse.vtp.desktop.projects.core [message #22204 is a reply to message #22159] Sat, 11 April 2009 13:52 Go to previous messageGo to next message
Man,
I resolved this problem change a line "parse.run(wsdlURI)" to
"parse.run(new File(wsdlURI).toURI().toString())" in WebService.java.
Is this correct?
Now I have others problems in execution time:
INFO
|2009/04/11|17:32:07|p=Teste6|s=1BBEBFCF6199F1A3924C5695249F 44C7|e=0002 >
Action "Webservice Call" Starting
INFO
Action "Webservice Call" Ended
ERROR|2009/04/11|17:32:07|p=Teste6|s=1BBEBFCF6199F1A3924C569 5249F44C7|e=0002 >
org.eclipse.vtp.framework.synthetic_ws.MyBean.MyBeanServiceL ocator
ERROR|2009/04/11|17:32:07|p=Teste6|s=1BBEBFCF6199F1A3924C569 5249F44C7|e=0002 > java.lang.ClassNotFoundException:
ERROR|2009/04/11|17:32:07|p=Teste6|s=1BBEBFCF6199F1A3924C569 5249F44C7|e=0002 > at
java.lang.ClassLoader.findClass(ClassLoader.java:359)
java.lang.ClassLoader.loadClass(ClassLoader.java:307)
java.lang.ClassLoader.loadClass(ClassLoader.java:252)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.vtp.framework.engine.http.Deployment.loadClass(D eployment.java:265)
org.eclipse.vtp.framework.engine.support.AbstractProcessCont ext.loadClass(AbstractProcessContext.java:167)
org.eclipse.vtp.framework.engine.support.AbstractSessionCont ext.loadClass(AbstractSessionContext.java:205)
org.eclipse.vtp.framework.engine.support.AbstractExecutionCo ntext.loadClass(AbstractExecutionContext.java:195)
org.eclipse.vtp.framework.engine.support.AbstractActionConte xt.loadClass(AbstractActionContext.java:157)
org.eclipse.vtp.framework.engine.support.ActionContextWrappe r.loadClass(ActionContextWrapper.java:426)
org.eclipse.vtp.framework.webservices.actions.WebServiceCall Action.execute(WebServiceCallAction.java:161)
org.eclipse.vtp.framework.engine.runtime.Action.execute(Acti on.java:133)
org.eclipse.vtp.framework.engine.runtime.Sequence.next(Seque nce.java:108)
org.eclipse.vtp.framework.engine.runtime.Execution$1.run(Exe cution.java:173)
org.eclipse.vtp.framework.engine.http.DeploymentExecution.vi sitRunnable(DeploymentExecution.java:461)
org.eclipse.vtp.framework.engine.runtime.Execution$1.accept( Execution.java:187)
org.eclipse.vtp.framework.engine.http.DeploymentExecution.do Next(DeploymentExecution.java:191)
org.eclipse.vtp.framework.engine.http.DeploymentSession.next (DeploymentSession.java:206)
org.eclipse.vtp.framework.engine.http.Deployment.next(Deploy ment.java:167)
org.eclipse.vtp.framework.engine.http.HttpConnector.invokePr ocessEngine(HttpConnector.java:376)
org.eclipse.vtp.framework.engine.http.HttpConnector.process( HttpConnector.java:287)
org.eclipse.vtp.framework.engine.http.HttpConnectorServlet.p rocess(HttpConnectorServlet.java:121)
org.eclipse.vtp.framework.engine.http.HttpConnectorServlet.d oGet(HttpConnectorServlet.java:142)
javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:75)
org.eclipse.equinox.servletbridge.BridgeServlet.service(Brid geServlet.java:115)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:875)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689)
java.lang.Thread.run(Thread.java:619)
INFO
Execution "2" Ended
Re: Error in org.eclipse.vtp.desktop.projects.core [message #22247 is a reply to message #22159] Sat, 11 April 2009 14:17 Go to previous messageGo to next message
Man.
I resolved thsi problem. I change a line parse.run(wsdlURI) to
parse.run(new File(wsdlURI.toURI().toString) in Webservice.java.
Is this correct?
Now I have this error in runtime:
INFO
Variable assignments complete
INFO
Action "Begin" Ended
INFO
INFO
INFO
Execution "2" Ended
thanks
Re: Error in org.eclipse.vtp.desktop.projects.core [message #22285 is a reply to message #22159] Sat, 11 April 2009 14:21 Go to previous message
Man,
I resolved this problem change a line parse.run(wsdlURI) to
parse.run(new File(wsdlURI.toURI().toString()) in WebService.java.
this is correct?
Re: Error in org.eclipse.vtp.desktop.projects.core [message #578279 is a reply to message #22075] Fri, 03 April 2009 14:06 Go to previous message
Hi Fernando--
Randy Childers
OpenMethods
> Friends,
> 429. ERROR in
> (at line 31)
> Can you help me?
Re: Error in org.eclipse.vtp.desktop.projects.core [message #578290 is a reply to message #22118] Fri, 10 April 2009 17:59 Go to previous message
Man,
yes Openxml.
null
at
at
at
at
at
at
at
at
at
at
at
at
at
at
unknown protocol: c
at
Source)
at
Source)
at
Source)
at
Source)
Source)
Source)
at
Source)
at
Thanks.
Re: Error in org.eclipse.vtp.desktop.projects.core [message #578313 is a reply to message #22159] Sat, 11 April 2009 13:52 Go to previous message
Man,
Is this correct?
INFO
INFO
INFO
Execution "2" Ended
Re: Error in org.eclipse.vtp.desktop.projects.core [message #578336 is a reply to message #22159] Sat, 11 April 2009 14:17 Go to previous message
Man.
Is this correct?
INFO
INFO
INFO
INFO
INFO
Execution "2" Ended
thanks
Re: Error in org.eclipse.vtp.desktop.projects.core [message #578357 is a reply to message #22159] Sat, 11 April 2009 14:21 Go to previous message
Man,
this is correct?
Previous Topic:TTS Portuguese Characters
Next Topic:Error runtime equinoxbridgeservlet threw exception
Current Time: Thu Nov 06 05:41:32 EST 2025
Powered by FUDForum. Page generated in 0.03960 seconds
