| JNIEXPORT  syntax error [message #222839] |
Mon, 01 September 2008 11:15   |
Eclipse User  |
Originally posted by: mhesselbach.gmx.net
I have a pair of Eclipse projects: A java app calling some native C++ code.
On windows, I used Eclipse for the java project, and VS for the C++ dll.
Now I build the same for linux, using the latest Eclipse version
(eclipse-cpp-ganymede-linux-gtk.tar.gz) for the C++ part.
The first steps are working :
  I added the include path to <jni.h> and to the linux\jni-md.h file as
well.
  Then, I got the shared lib built, and I can load it and access its methods
from my java project.
However, the implementing methods are marked in yellow as "syntax error"
without further hint, in my CDT project.
If I add the javah include file explicitly to the Eclipse project and open
it, the declarations there show the same error indicator, underlining
"JNIEXPORT jlong JNICALL" as a warning.
BTW methods returning "void" have the method name underlined as well:
make runs well, the Problems window is empty,  it's just the Eclipse syntax
highlighter.
Is that something everybody else simply accepts?
Thanks for some feedback  ( A similar message one ore two years ago seems
not to get any answer ...)
| Re: JNIEXPORT  syntax error [message #222847 is a reply to message #222839] |
Mon, 01 September 2008 13:05    |
Eclipse User  |
> well.
> highlighter.
Try to rebuild the index: right-click on the file, Index → choose
appropriate.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
| Re: JNIEXPORT  syntax error [message #222863 is a reply to message #222847] |
Tue, 02 September 2008 03:57   |
Eclipse User  |
Originally posted by: dontreplyhere.inter.net
"Hendrik Maryns" wrote
> Try to rebuild the index: right-click on the file, Index ? choose
> appropriate.
Yes: Right-clicking the project folder in Project Explorer shows
this "Index" submenu item, and "Update" helped.
(Seemed to be a smart question ;)
Thanks a lot
-- Michael
FUDForum. Page generated in 0.04207 seconds
