Home » Language IDEs » ServerTools (WTP) » WSDL Parser error
WSDL Parser error [message #222581] Mon, 06 October 2008 10:45 Go to next message
Hello all,
I have a WSDL file with some inline schemas lets name them A and B.
the schema A refers to some components in schema B and it doesnt have any
import statement for B. This is a valid WSDL as per the specification and
i dont get any errors when i validate this with Altova XML spy and some
more validators.
The validator in eclipse shows this as an invalid schema.
But when i get the model for this WSDL using WSDLResourceImpl and then
check the schemas the components are resolved and i can see the components
of schema B getting resolved in schema A. but when i call validate on the
EMF models of the schema it gives me the validation errors that the
components
cannot be resolved.
Thanks and regards,
Keshav Veerapaneni.
Re: WSDL Parser error [message #222584 is a reply to message #222581] Mon, 06 October 2008 10:56 Go to previous messageGo to next message
Keshavrao,
What you describe is not valid with respect to the XML Schema
specification. You must have an <xsd:import> of B's namespace in A for
A to see things in B's namespace; you can omit the schemaLocation. XML
spy is notorious for under reporting errors...
Keshavrao wrote:
> Hello all,
> and i dont get any errors when i validate this with Altova XML spy and
> some more validators.
> components of schema B getting resolved in schema A. but when i call
> validate on the
> components
> cannot be resolved.
> Thanks and regards,
> Keshav Veerapaneni.
Re: WSDL Parser error [message #222631 is a reply to message #222584] Mon, 13 October 2008 02:04 Go to previous messageGo to next message
Hello Ed,
Thanks for the quick reply.
I found the below line in the XSD 1.1 specification which actually does'nt
put any restriction on what basis the components are to be resolved.
<B>
Note: Since both the namespace and schemaLocation [attribute] are
optional, a bare <import/> information item is allowed. This simply allows
unqualified reference to foreign components with no target namespace
without giving any hints as to where to find them.
</B>
Should we not consider WSDL specification to be driving here? as it is
part of WSDL specification that allows to have multiple inline schemas and
here the WSDL spec should know how to resolve the components within these
inline schemas.
Also the parser is actually able to resolve the components and the only
problem that comes is when i explicitly call validate on the XSD.
Thanks and regards,
Keshav Veerapaneni.
Re: WSDL Parser error [message #222636 is a reply to message #222631] Mon, 13 October 2008 09:29 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
What does the XSD 1.0 specification say, as there are differences
between the official XSD 1.0 Recommendation and the Working draft of XSD
1.1.
Dave
Keshavrao wrote:
> Hello Ed,
> does'nt put any restriction on what basis the components are to be
> resolved.
> <B>
> allows unqualified reference to foreign components with no target
> namespace without giving any hints as to where to find them.
> </B>
> and here the WSDL spec should know how to resolve the components within
> these inline schemas.
> Thanks and regards,
> Keshav Veerapaneni.
Re: WSDL Parser error [message #222640 is a reply to message #222636] Tue, 14 October 2008 02:02 Go to previous messageGo to next message
Hello Dave,
Even the XSD1.0 says the same, both the namespace and location are
optional and
its upto the tools and implemention, how it makes the referred components
resolvable.
Thanks and regards,
Keshav Veerapaneni.
Re: WSDL Parser error [message #222698 is a reply to message #222640] Fri, 17 October 2008 11:20 Go to previous messageGo to next message
Keshavrao wrote:
> Hello Dave,
> optional and
> resolvable.
Most tooling I know of is going to require at least a namespace on an
Import so that it can check it's cache of grammars or at least an XML
Catalog to see if it already has something it can reference.
Re: WSDL Parser error [message #222759 is a reply to message #222631] Mon, 20 October 2008 06:12 Go to previous messageGo to next message
--------------010701060609070900070602
Keshavrao,
Sorry, I didn't have much time for newsgroups last week. What you're
quoting below is the part of the specification that says <xsd:import/>
is valid because schemaLocation is an optional hint and the because
namespace can be null. So <xsd:import> is used to import components
from the null target namespace without specifying where to find the
schema for that. It in no way implies that the import isn't necessary.
In fact, if you think about it, if an import isn't necessary in the
first place, then <xsd:import> would be pointless. In fact, it's
*required *if you want to reference names from the null namespace.
I would never trust XML Spy's lack of an error message as a good
indicator of validity. The only other arbiter I trust is Xerces and
I've discussed the interpretation of the specification as it relates to
this specific issue with Xerces' developers...
Keshavrao wrote:
> Hello Ed,
> resolved.
> <B>
> </B>
> within these inline schemas.
> only problem that comes is when i explicitly call validate on the XSD.
> Thanks and regards,
> Keshav Veerapaneni.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Keshavrao,<br>
<br>
Re: WSDL Parser error [message #222768 is a reply to message #222698] Mon, 20 October 2008 06:14 Go to previous messageGo to next message
David,
The lack of a namespace in the import is how the null target namespace
is specified, so tools had better know how to deal with that. It's just
very rare to see such a thing...
David Carver wrote:
> Keshavrao wrote:
>> Hello Dave,
>> optional and
>> components
>> resolvable.
Re: WSDL Parser error [message #222872 is a reply to message #222759] Tue, 21 October 2008 02:04 Go to previous message
Hello Ed,Dave,
Thanks for the information. I will also report this Altova XML Spy and
will try describing the issue and check why is this allowed.
Thanks for the support again.
Keshav Veerapaneni.
Previous Topic:Re: How to strip off all unreferenced ComplexTypes from WSDL?
Next Topic:How to contribute to Tomcat's shared/lib?
Current Time: Sun Jul 27 22:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.05753 seconds
