Home » Language IDEs » ServerTools (WTP) » Tomcat redeploys web application when a JSP get changed (because of faceted project dependencies are
Tomcat redeploys web application when a JSP get changed (because of faceted project dependencies are [message #222642] Tue, 14 October 2008 02:16 Go to next message
I think I found where the issue come from, but still no workaround.
I have two projects, one is a simple Java project which performs DBMS data
access (say p1), and another web module (say p2). Not all of my .jar files
are copied in the WEB-INF/lib of p2 (webmodule) project, but they are
actually referenced through "Java EE Module Dependencies", so that Eclipse
copies p1 and p2 projects' dependencies to the target module deployment
folder's WEB-INF/lib.
p1 project has Utility Module facet, so that whenever it changes a new jar
file is created and exported to p2's WEB-INF/lib. The problem is that
whenever I change a simple .jsp page (in p2), a new p1.jar is created in
WEB-INF/lib and this is the cause that Tomcat reloads the module.
There is also another issue which I believe happens because of another facet
set in my p1 project. I have eclipselink.jar as a dependency in my pure java
project (p1). There is also a JPA facet set in p1 project. Whenever I change
a jsp, not only p1.jar is modified, but also eclipselink.jar is re-copied in
WEB-INF/lib.
Isn't it a bug in WTP facet engine?
Mohsen.
Re: Tomcat redeploys web application when a JSP get changed (because of faceted project dependencies [message #222663 is a reply to message #222642] Thu, 16 October 2008 02:36 Go to previous message
Originally posted by: mohsen.siahe.com
Reported as bug 250966.
"Mohsen Saboorian" <mohsens@gmail.com> wrote in message
news:gd1dqe$o8v$1@build.eclipse.org...
> facet
> java
> change
> in
> WEB-INF/lib.
> Mohsen.
Previous Topic:Where do I find WTP Updates for Ganymede?
Next Topic:maven, eclipse, WTP 1.5.5 and deep project structures
Current Time: Sat Jul 26 02:23:03 EDT 2025
Powered by FUDForum. Page generated in 0.05020 seconds
