Home » Language IDEs » ServerTools (WTP) » Synchronization with temporary deploy directory
Synchronization with temporary deploy directory [message #222594] Tue, 07 October 2008 15:06 Go to next message
Hi there,
I would like to use WTP for my web projects. At the moment I'm working
with the sysdeo plugin, the eclipse project is directly the
application's root.
My application generates and modifies files in the web application. The
files and modifications are part of the application afterwards. This was
no problem up to now, since the application was never really deployed
with the sysdeo plugin. However, WTP does a real deploy and copies the
files to a temporary directory. If the application modifies or creates
files, only the temporary directory is affected and the changes are lost
(i.e. not synchronized back to the project directory).
Is there a way to achieve such a synchronization of the two directories?
Or can the project directory directly be used as the webroot while
developing (i.e. the files are never deployed elsewhere)?
Thanks for your help,
Dominik
Re: Synchronization with temporary deploy directory [message #222601 is a reply to message #222594] Wed, 08 October 2008 08:10 Go to previous messageGo to next message
Ok,
I found out that I can check the option "Serve modules with out
publishing". I think that this will avoid the need of copying back
published and modified files.
Dominik Raymann schrieb:
> Hi there,
> application's root.
> Dominik
Re: Synchronization with temporary deploy directory [message #222603 is a reply to message #222601] Wed, 08 October 2008 10:56 Go to previous messageGo to next message
Yes, this non-standard feature should achieve what you want. The
docBase of the context will point to the "webcontent" folder of the
project. In addition, a custom classloader is used by the webapp to get
a list of resources so that the jars and classes in your project are
used directly. This also applies to Java utility projects that your web
application project depends on.
Larry
Dominik Raymann wrote:
> Ok,
>> Hi there,
>> application's root.
>> Dominik
Re: Synchronization with temporary deploy directory [message #222613 is a reply to message #222603] Thu, 09 October 2008 04:46 Go to previous messageGo to next message
What do you mean by "non-standard" feature? Is it discouraged to use
this feature?
Cheers, Dominik
> Cheers,
> Larry
>> Ok,
>>> Hi there,
>>> application's root.
>>> Dominik
Re: Synchronization with temporary deploy directory [message #222617 is a reply to message #222613] Thu, 09 October 2008 09:03 Go to previous messageGo to next message
Not discouraged, but you may not find this feature available for other
servers. Within an Eclipse workspace with dynamic web projects, you
typically won't find a folder that can serve root folder of a webapp
with a WAR file directory structure. Thus a WAR or folder with a WAR
file structure has to be created so the webapp can be deployed or
served, as you noted in your first e-mail.
Because the Tomcat server adapter imports the server's configuration
into Eclipse, it is able to play some special games with that
configuration to make the "Serve modules without publishing" work. Note
that enabling this feature non-intrusively modifies the Tomcat server by
adding an extra jar to the server. You can also take a peek at the
<Context> that gets added to the server.xml when this feature is enabled
to see the special configuration of that <Context> gets to make this work.
Larry
> this feature?
> Cheers, Dominik
>> get a list of resources so that the jars and classes in your project
>> are used directly. This also applies to Java utility projects that
>> your web application project depends on.
>> Cheers,
>> Larry
>>> Ok,
>>>> Hi there,
>>>> application's root.
>>>> was
>>>> lost
>>>> directories?
>>>> Dominik
Re: Synchronization with temporary deploy directory [message #222620 is a reply to message #222617] Thu, 09 October 2008 14:04 Go to previous messageGo to next message
Thanks Larry for all your comprehensive answers in this and the other
thread.
Considering all the special tricks that have to be done to run the
application in situ (and the impossiblity to do it with other
application servers than Tomcat), what are the advantages of the dynamic
web project structure proposed by WTP? Wouldn't it be easier to use the
standard WAR file structure (i.e. exploded WAR) in the first place?
Dominik
> Cheers,
> Larry
>> this feature?
>> Cheers, Dominik
>>> Cheers,
>>> Larry
>>>> Ok,
>>>>> Hi there,
>>>>> application's root.
>>>>> The
>>>>> This was
>>>>> lost
>>>>> directories?
>>>>> Dominik
Re: Synchronization with temporary deploy directory [message #222624 is a reply to message #222620] Fri, 10 October 2008 09:05 Go to previous messageGo to next message
There are a number of reasons. First the servlet spec in no way
requires servlet containers or application servers serve exploded
directories, though many do as a convenience.
Second, Eclipse is very big on separating source from build artifacts.
So building your webapp's Java classes into WEB-INF/classes of the
"webcontent" folder, which should only contain source, would be
considered bad practice. Note that there is support for this use case
in WTP. If you manually direct the build output of your Java files to
WEB-INF/classes, I believe WTP detects this and won't be confused by
having built artifacts the it expects to publish being placed someplace
that it also expects to publish. It's just that Eclipse would never
require something like this be done in order to work.
Third, there is an important feature that I don't think would work that
well in your scenario. This is the ability to create "virtual"
dependencies on jars and not have them physically in the WEB-INF/lib of
the "webcontent" folder. They are available for compiling at build time
and are copied to the webapp as part of publishing in preparation for
run time. The same jar can serve many projects. It's a similar story
for Java utility projects, which are built into jars during and placed
in the published webapp's WEB-INF/lib. Having such dependencies
physically created so that the "webcontent" folder is a fully functional
WAR directory structure wouldn't be practical.
I assume you are aware that a self-modifying webapp may have limited
portability. There is nothing in the servlet spec that promises it
would work on a given servlet container or application server. Also,
the webapp could easily be deployed to a "working" area that isn't
persisted beyond a restart. I believe this would even be the case for
Tomcat if you turn on antiResourceLocking. However, if portability
isn't an issue, then this may not matter that much.
Larry
> thread.
> Cheers,
> Dominik
>> Note that enabling this feature non-intrusively modifies the Tomcat
>> server by adding an extra jar to the server. You can also take a peek
>> at the <Context> that gets added to the server.xml when this feature
>> is enabled to see the special configuration of that <Context> gets to
>> make this work.
>> Cheers,
>> Larry
>>> this feature?
>>> Cheers, Dominik
>>>> Cheers,
>>>> Larry
>>>>> Ok,
>>>>>> Hi there,
>>>>>> working
>>>>>> application's root.
>>>>>> application. The
>>>>>> This was
>>>>>> the
>>>>>> creates
>>>>>> are lost
>>>>>> directories?
>>>>>> Dominik
Re: Synchronization with temporary deploy directory [message #222633 is a reply to message #222624] Mon, 13 October 2008 04:53 Go to previous message
Larry,
thanks for your answer. I see the advantages of a directory layout as
proposed by the WTP, especially when it comes to separation of build
artifacts. I'm aware of the limitation of a self-modifying webapp and
there are plans to change this behaviour in the near future. By then
I'll have to cope with it somehow ;-)
Thanks again.
Dominik
> Cheers,
> Larry
>> thread.
>> dynamic web project structure proposed by WTP? Wouldn't it be easier
>> to use the standard WAR file structure (i.e. exploded WAR) in the
>> first place?
>> Cheers,
>> Dominik
>>> other servers. Within an Eclipse workspace with dynamic web
>>> projects, you typically won't find a folder that can serve root
>>> folder of a webapp with a WAR file directory structure. Thus a WAR
>>> or folder with a WAR file structure has to be created so the webapp
>>> can be deployed or served, as you noted in your first e-mail.
>>> peek at the <Context> that gets added to the server.xml when this
>>> feature is enabled to see the special configuration of that <Context>
>>> Cheers,
>>> Larry
>>>> this feature?
>>>> Cheers, Dominik
>>>>> to get a list of resources so that the jars and classes in your
>>>>> project are used directly. This also applies to Java utility
>>>>> projects that your web application project depends on.
>>>>> Cheers,
>>>>> Larry
>>>>>> Ok,
>>>>>>> Hi there,
>>>>>>> working
>>>>>>> application's root.
>>>>>>> application. The
>>>>>>> This was
>>>>>>> deployed
>>>>>>> copies the
>>>>>>> creates
>>>>>>> are lost
>>>>>>> directories?
>>>>>>> Dominik
Previous Topic:EJB Project and Entity
Next Topic:XSL Tools 0.5M9 available
Current Time: Sat Jul 26 02:25:23 EDT 2025
Powered by FUDForum. Page generated in 0.30575 seconds
