Home » Language IDEs » ServerTools (WTP) » Why doesn't Tomcat log to System.err?
Why doesn't Tomcat log to System.err? [message #222454] |
Tue, 30 September 2008 03:42  |
Originally posted by: dontreply.want.ch
Hi all
On Eclipse 3.3.1 (also tried Ganymede 3.4.?), the integrated Tomcat (5.5)
seems to log everything to the Eclipse System.out console. I've set up log4j
to log DEBUG-INFO to System.out and WARN-FATAL to System.err. When running a
unit test, this logging setup works fine, warnings and errors appear in the
color of System.err (red). When launching Tomcat, all messages are black (as
in System.out). The log4j part is definitely ok, if I change the pattern of
the System.err appender, this is reflected in Eclipse console (but black
instead of red)
It's a rather minor issue, but with a Spring/Hibernate webapp, there are
lots of potentially important messages (especially during testing) and
having warnings and errors pop up in red would really help.
Is this a known bug, do I need to reconfigure something?
Thanks a lot
Simon
Re: Why doesn't Tomcat log to System.err? [message #222509 is a reply to message #222454] |
Tue, 30 September 2008 13:32   |
Simon Niederberger wrote:
> Hi all
> instead of red)
> Thanks a lot
> Simon
On Eclipse 3.3.2 and WTP 3.0.2, using a JSP that outputs to System.err
and System.out, I get the following results:
Tomcat 4.0.6: out = black, err = red
Tomcat 4.1.32: out = black, err = black
Tomcat 5.5.26: out = black, err = black
Tomcat 6.0.18: out = black, err = black
Given that the Eclipse/WTP code that launches the server is pretty much
the same regardless of Tomcat version, it suggests that something inside
Tomcat is playing with System.out and System.err since Tomcat 4.1.x.
Unfortunately, my knowledge of the Tomcat code base doesn't quite cover
why this would be happening.
Larry
Re: Why doesn't Tomcat log to System.err? [message #222514 is a reply to message #222509] |
Tue, 30 September 2008 16:13  |
Larry, thanks a lot for the info on the different versions. Good to know
it's essentially a Tomcat issue.
Investigating further, it seems Tomcat (starting with 5.0) logs everything
written to System.out and System.err to 'catalina.out'. This is usually a
growing logfile in tomcat\logs. I wonder if Eclipse redirects that stream to
its own console (System.out).
to be continued ...
Simon
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:gbtnqu$rhq$1@build.eclipse.org...
>> Hi all
>> log4j to log DEBUG-INFO to System.out and WARN-FATAL to System.err. When
>> running a unit test, this logging setup works fine, warnings and errors
>> appear in the color of System.err (red). When launching Tomcat, all
>> messages are black (as in System.out). The log4j part is definitely ok,
>> if I change the pattern of the System.err appender, this is reflected in
>> Eclipse console (but black instead of red)
>> Thanks a lot
>> Simon
> On Eclipse 3.3.2 and WTP 3.0.2, using a JSP that outputs to System.err and
> Cheers,
> Larry
Current Time: Sun Jul 27 14:00:50 EDT 2025
Powered by FUDForum. Page generated in 0.30300 seconds
