Home » Language IDEs » C / C++ IDE (CDT) » Automated Night Builds
Automated Night Builds [message #222300] Tue, 19 August 2008 09:50 Go to next message
Originally posted by: alberto.ing.gmail.com
I all,
I need to set up an automated build of my projects and I would like to
understand if this is possible using CDT.
The steps that I need are:
check out the projects from cvs/svn the files
add the projects to a new workspace
compile the projects
run the cpp-unit test
pack the night build
One of the main points is that the environment must be fresh, so also the
workspace need to be created by scratch.
Can I obtain this (or part at least) using eclipse and cdt?
Thanks everyone
Re: Automated Night Builds [message #222314 is a reply to message #222300] Tue, 19 August 2008 12:46 Go to previous messageGo to next message
Originally posted by: jamesblackburn+eclipse.mac.com
Alberto Ingenito wrote:
> I all,
> the workspace need to be created by scratch.
Well you'd have to have to write a builder or custom application to
handle this. All that's currently built in is the ability to build a
pre-existing workspace.
You could almost get there by:
Manually:
- Creating the workspace & Projects in advance
Shell script:
- Remove any previous build /run artifacts
- Running cvs / svn update
Eclipse:
- Perform a headless build using the org.eclipse.jdt.apt.core.aptBuild
application in Eclipse
(which does a clean build on all projects before performing a
full build)
Shell script:
- tar up the output
So while CDT / Eclipse can perform the build for you, the rest you'll
either have to plug in with Java or script -- I'd personally opt for the
latter unless unless you had very specific reasons for doing everything
under Eclipse?
James
Re: Automated Night Builds [message #222328 is a reply to message #222314] Tue, 19 August 2008 12:55 Go to previous messageGo to next message
This mostly solves my problem.
If a workspace can be moved I can simply maintain one _template_ workspace
and copy that one each time.
I'll check this headless build stuff,
thanks a lot
Alberto
Re: Automated Night Builds [message #222359 is a reply to message #222328] Tue, 19 August 2008 13:11 Go to previous message
> workspace and copy that one each time.
Indeed. When setting up any workspace relative build paths, use the CDT
provided variables ${WorkspaceDirPath} & ${ProjDirPath}
James
> thanks a lot
> Alberto
Previous Topic:Usage of Linux 64bit
Next Topic:Developer documentation for CDT 5.0?
Current Time: Tue Nov 11 08:53:20 EST 2025
Powered by FUDForum. Page generated in 0.28309 seconds
