Home » Language IDEs » Java Development Tools (JDT) » drag and drop into CompilationUnitEditor
| drag and drop into CompilationUnitEditor [message #222214] |
Fri, 13 January 2006 19:05  |
The use case I am wondering about is that a user selects a widget in a View,
drags, and drops it into the Java editor. The drop processor for this
operation wants to add some code to the current compilation unit, I think
via ASTRewrite. I found an article in the docs about drag + drop, dated 2003
( http://www.eclipse.org/articles/Article-Workbench-DND/drag_d rop.html) which
seems to imply that the response to dropping on an editor window was then
limited to the workbench opening a resource in the appropriate editor. There
is a drag + drop enhancement request for 3.2 (107846), but it looks like it
pertains to dropping onto a View, not on an Editor. Is there a way to create
a drop listener that will get called when a drop event onto the
CompilationUnitEditor occurs?
| Re: drag and drop into CompilationUnitEditor [message #223047 is a reply to message #222249] |
Tue, 24 January 2006 21:57   |
Thanks Dani...
Next question: how do I get at the Editor? I know how to get at the
IEditorPart and IEditorSite, but I don't think that's the same thing:
getViewSite().getPage().getActiveEditor().getEditorSite()...
What is the path to the Editor itself, from a View, for example?
thanks again,
gary
"Daniel Megert" <daniel.megert@eclipse.org> wrote in message
news:dqgajo$28l$1@utils.eclipse.org...
> Gary,
> there's currently no official support to do this directly. You might try
> to register a org.eclipse.swt.dnd.DropTarget directly on the editor's
> control:
> Control ctrl= (Control)editor.getAdapter(Control.class);
> if (ctrl != null) {
> DropTarget dropTarget= new DropTarget(ctrl, <your DND styles>);
> dropTarget.setTransfer(<your transfer agents>);
> dropTarget.addDropListener(<your listener>);
> HTH
> Dani
>>View, drags, and drops it into the Java editor. The drop processor for
>>this operation wants to add some code to the current compilation unit, I
>>think via ASTRewrite. I found an article in the docs about drag + drop,
>>dated 2003
>>which seems to imply that the response to dropping on an editor window was
>>then limited to the workbench opening a resource in the appropriate
>>editor. There is a drag + drop enhancement request for 3.2 (107846), but
>>it looks like it pertains to dropping onto a View, not on an Editor. Is
>>there a way to create a drop listener that will get called when a drop
>>event onto the CompilationUnitEditor occurs?
| Re: drag and drop into CompilationUnitEditor [message #223061 is a reply to message #223047] |
Wed, 25 January 2006 04:50   |
Originally posted by: daniel.megert.eclipse.org
Gary Horen wrote:
>Thanks Dani...
The IEditorPart is the (Java) editor.
Dani
>thanks again,
>gary
>>Gary,
>>control:
>>if (ctrl != null) {
>>HTH
>>Dani
>>>dated 2003
| Re: drag and drop into CompilationUnitEditor [message #223109 is a reply to message #223061] |
Wed, 25 January 2006 20:50   |
This works, in that now I can construct a DropTargetListener that will
receive drop events when something is dropped on the Editor. This is great.
Next question: What I really want to do is to create a DropTarget on the
Editor's control, but when I receive a Transfer that I don't recognize, to
pass it along to the DropTarget that is already in effect for the Editor. I
don't want to pre-empt and swallow a drop event that the Editor already
supports. I'd love it if it just worked like that, but the way it works now
is that if my DropTarget isn't set up to receive JavaElementTransfers (an
internal object anyway, don't want to receive those), then the Editor does
not accept drops of files from the Package Explorer anymore.
Control#getData("DropTarget") will not give me the currently connected
DropTarget; it returns null (and I really don't want to make that call
anyway since "DropTarget" is actually a value private to the DropTarget
class). Do you have a suggestion about how I can find an object to pass a
drop event that is not mine along to? Or is there some feedback I should be
giving the Listener#dragEnter() method that will tell it that I don't own
the event, and it should find another that does?
Here is the experimental code that attaches the DropTarget to the control.
The listener is currently doing nothing with the Events.
private void hookDragonDrop()
Control ctl = (Control)
getViewSite().getPage().getActiveEditor().getAdapter(Control .class);
if (ctl != null) {
DropTarget dt = new DropTarget(ctl, DND.DROP_COPY | DND.DROP_MOVE |
DND.DROP_LINK);
Transfer[] trans = {FileTransfer.getInstance(),
JavaElementTransfer.getInstance()};
dt.setTransfer(trans);
DropTargetListener listener = new MyDropListener();
dt.addDropListener(listener);
thanks again.
news:dr7hm4$fhe$2@utils.eclipse.org...
> Gary Horen wrote:
>>Thanks Dani...
> Dani
>>thanks again,
>>gary
>>>Gary,
>>>control:
>>>if (ctrl != null) {
>>>HTH
>>>Dani
>>>>dated 2003
>>>>was then limited to the workbench opening a resource in the appropriate
| Re: drag and drop into CompilationUnitEditor [message #223296 is a reply to message #223109] |
Mon, 30 January 2006 09:52   |
>supports.
The editor doesn't do this, it's probably a listener on the parent
control. Try to set the event detail to DND.DROP_NONE.
Dani
> if (ctl != null) {
>DND.DROP_LINK);
>thanks again.
>>Gary Horen wrote:
>>>Thanks Dani...
>>Dani
>>>thanks again,
>>>gary
>>>>Gary,
>>>>control:
>>>>if (ctrl != null) {
>>>>HTH
>>>>Dani
>>>>>dated 2003
| Re: drag and drop into CompilationUnitEditor [message #223414 is a reply to message #223296] |
Mon, 30 January 2006 22:06   |
Hi again Dani (or whoever else chooses to respond) ...
I assume that in your last suggestion, you meant to set detail =
DND.DROP_NONE in the drop() method, but I'm not sure. When I do this, I get
a slightly different behavior: a progress dialog appears briefly on the
screen, but the original behavior does not happen. So the event is not (to
all appearances) being passed on to the handler that was there before I
registered my listener.
After some digging (and hacking) around, it looks to be like what I need to
be able to do (in order to preempt the drop events I care about, and let the
ones I don't manifest their original behavior), is to pass those that I
don't care about on, to the o.e.ui.internal.ide.EditorAreaDropAdapter, which
actually implements behavior like opening a file that's dragged in from the
pkg explorer. EditorAreaDropAdapter is, of course, not accessible to me
without some serious prying open of things I'm not supposed to touch :)
Am I right in the preceding paragraph? Or is there a solution that I'm
missing? And is this a discussion that I actually should be having with the
platform people (in which case I would stop bothering you? :)
thanks again,
-Gary
news:drl986$98u$1@utils.eclipse.org...
>>great.
>>I don't want to pre-empt and swallow a drop event that the Editor already
>>supports.
> Dani
>>I'd love it if it just worked like that, but the way it works now is that
>>if my DropTarget isn't set up to receive JavaElementTransfers (an internal
>>object anyway, don't want to receive those), then the Editor does not
>>be giving the Listener#dragEnter() method that will tell it that I don't
>>own the event, and it should find another that does?
>> if (ctl != null) {
>> DND.DROP_LINK);
>>thanks again.
>>>Gary Horen wrote:
>>>>Thanks Dani...
>>>Dani
>>>>thanks again,
>>>>gary
>>>>>Gary,
>>>>>try to register a org.eclipse.swt.dnd.DropTarget directly on the
>>>>>editor's control:
>>>>>if (ctrl != null) {
>>>>>HTH
>>>>>Dani
>>>>>>I think via ASTRewrite. I found an article in the docs about drag +
>>>>>>drop, dated 2003
>>>>>>appropriate editor. There is a drag + drop enhancement request for 3.2
>>>>>>(107846), but it looks like it pertains to dropping onto a View, not
>>>>>>on an Editor. Is there a way to create a drop listener that will get
>>>>>>called when a drop event onto the CompilationUnitEditor occurs?
| Re: drag and drop into CompilationUnitEditor [message #223451 is a reply to message #223414] |
Tue, 31 January 2006 08:59   |
Gary,
yes, I would expect that event.detail= DND.DROP_NONE would do the trick
and as you noticed there was some different behaviour. It's really an
SWT question though and I'd ask there. Please let me know of the outcome.
Dani
>thanks again,
>-Gary
>>>great.
>>>supports.
>>Dani
>>> if (ctl != null) {
>>>DND.DROP_LINK);
>>>thanks again.
>>>>Gary Horen wrote:
>>>>>Thanks Dani...
>>>>Dani
>>>>>thanks again,
>>>>>gary
>>>>>>Gary,
>>>>>>editor's control:
>>>>>>if (ctrl != null) {
>>>>>>HTH
>>>>>>Dani
>>>>>>>drop, dated 2003
| Re: drag and drop into CompilationUnitEditor [message #1066607 is a reply to message #720928] |
Wed, 03 July 2013 08:27  |
Hey werner.
Firstly, thank you very much for this, it has been very helpful to me!
Secondly, sorry for digging up this 2 year old thread.
I wanted to ask if you (or someone else) knows a way to set the style of the DragSource/DropTarget using this method (DropTarget dropTarget = (DropTarget) ctrl.getData(DND.DROP_TARGET_KEY)).
I was hoping that there was some kind of DragSource#setStyle(int style) so I could call ds.setStyle(DROP_NONE) or something with the same effect, after having initialized the DragSource/DropTarget objects.
Thank you very much in advance.
Current Time: Sat Nov 08 09:56:38 EST 2025
Powered by FUDForum. Page generated in 0.07574 seconds
