Home » Modeling » GMF (Graphical Modeling Framework) » Dynamic palette and parts
Dynamic palette and parts [message #222117] |
Fri, 20 March 2009 12:58  |
--------------040405020201070803040303
Content-Type: text/plain; charset=ISO-8859-15
what I want to do recently is to dynamically add items to the palette
that create the same figure/domain element but with a different
attribute (e.g. type) value.
What I read is that I have to make use of PaletteService. Unfortunately
I can't find any (non-API) documentation on how to use it. Can anyone
point me to this?
Is there a similar mechanism for what I want the EditParts/Figures to
behave? To clarify: Let us say the above mentioned type attribute holds
up to n distinct values. These values are determined at runtime and for
each value there shall be a tool on the palette that can create a
generic node figure on the canvas with a label that shows this
attribute's value.
It would even help me if you give me a hint or link or anything that
points me to the correct documentation location.
Thanks in advance.
name="as_maps.vcf"
filename="as_maps.vcf"
begin:vcard
fn:Andreas Schoeneck
n:Schoeneck;Andreas
email;internet:as.maps@gmail.com
x-mozilla-html:FALSE
version:2.1
end:vcard
--------------040405020201070803040303--
Re: Dynamic palette and parts [message #222132 is a reply to message #222117] |
Fri, 20 March 2009 14:22   |
Originally posted by: me.urszeidler.de
Andreas Schoeneck schrieb:
> point me to this?
My current approach for this is to put some data in the ExtendedData map of the creation request, and then use this data in the CreationCommand and
initialize the domain object with it.
here is an example :
in XXXPaletteFactory
* Creates "actions" palette tool group
* @generated
private PaletteContainer createActions1Group() {
PaletteDrawer paletteContainer = new PaletteDrawer(Messages.Actions1Group_title);
createRegisterdActions(paletteContainer);
return paletteContainer;
* Creates the dynamic generator tool entrys.
* @param paletteContainer
private void createRegisterdActions(PaletteDrawer paletteContainer) {
Collection<ActionDescription> list = Activator.getDefault().getRegistry().getActiondescriptions() ;
for (ActionDescription generatorDescriptor : list) {
List/* <IElementType> */types = new ArrayList/* <IElementType> */(1);
IElementType elementTypes;
types.add(WorkflowElementTypes.Action_2001);
ActionToolEntry entry = new ActionToolEntry(generatorDescriptor.getActionInstance().getN ame(), generatorDescriptor
.getDescription(), types, generatorDescriptor);
// TODO : set the large icon also
if (generatorDescriptor.getSmallIcon() != null)
entry.setSmallIcon(Activator.getDefault()
.getBundledImageDescriptor(generatorDescriptor.getOwner().ge tConstibutorID(), generatorDescriptor.getSmallIcon()));
// entry.setLargeIcon(generatorDescriptor.getLargeIcon());
paletteContainer.add(entry);
Will create dynamically tool entrys, in this case in an "action" group.
* A specialized Tool entry to provide the descriptor to the request.
* @author urs
private static class ActionToolEntry extends ToolEntry {
public ActionToolEntry(String label, String shortDesc, List types, ActionDescription generatorDescriptor) {
super(label, shortDesc, null, null);
this.descriptor = generatorDescriptor;
this.elementTypes = types;
private final List elementTypes;
private ActionDescription descriptor;
* @generated
public Tool createTool() {
Tool tool = new UnspecifiedTypeCreationTool (elementTypes){
protected Request createTargetRequest() {
CreateUnspecifiedTypeRequest actionCreateRequest = new CreateUnspecifiedTypeRequest(elementTypes, getPreferencesHint());
actionCreateRequest.getExtendedData().put("generator_descriptor ", descriptor);
return actionCreateRequest;
tool.setProperties(getToolProperties());
return tool;
This tool entry puts the descriptor for the element to create in the ExtendedData map.
In the XXXCreateCommand
protected EObject doDefaultElementCreation() {
EObject eo = super.doDefaultElementCreation();
Object parameter = getRequest().getParameter("generator_descriptor");
if (parameter instanceof ActionDescription) {
ActionDescription descriptor = (ActionDescription) parameter;
Action action = (Action) eo;
action.setName(descriptor.getName());
Action actionInstance = descriptor.getActionInstance();
//TODO : add some features to generic generator (type)(id)
Collection<OutParameter> out = EcoreUtil.copyAll(actionInstance.getOut());
action.getOut().addAll(out);
Collection<InParameter> in = EcoreUtil.copyAll(actionInstance.getIn());
action.getIn().addAll(in);
action.setId(descriptor.getQuallifiedName());
return eo;
just override the doDefaultElementCreation() and get the descriptor from the request, and use it to configure your element.
If some one has a more elegant solution, I would be pleased to know.
greetings, urs.
Re: Dynamic palette and parts [message #222350 is a reply to message #222132] |
Mon, 23 March 2009 08:46   |
--------------020303050807070308050703
Thanks again, Urs.
After getting through the code you posted, I figured out, which classes
belong to your domain model and which belong to GMF/GEF runtime/core or
whatsoever.
For demonstration purposes I've done this with simple strings:
This method is used to add the supposed tools to the tool group
(in the XXXPaletteFactory)
private void createSomeActions(PaletteGroup paletteContainer) {
Collection<String> sampleList = new ArrayList<String>();
fillTheCollection(sampleList); // just fill with some strings
for (String singleDataString: sampleList) {
List types = new ArrayList(1);
types.add(MyModelEditorElementTypes.ANode_2002);
MyCustomToolEntry entry = new MyCustomToolEntry(
MyModelEditor.diagram.part.Messages.ANode1CreationTool_title + "/"
+ singleDataString,
MyModelEditor.diagram.part.Messages.ANode1CreationTool_desc,
// TODO: add the correct icons
null, null, types, singleDataString);
This class is the custom ToolEntry class:
(is mainly the same as you posted)
public class MyCustomToolEntry extends ToolEntry {
private String additionalData; // could be anything
public MyCustomToolEntry(String label, String shortDesc,
ImageDescriptor iconSmall, ImageDescriptor iconLarge, List types,
String aData) {
super(label, shortDesc, iconSmall, iconLarge);
additionalData = aData;
// set the additional data
"additional_data", additionalData);
return tool;
And - last but not least - the overridden
XXXCreateCommand.doDefaultElementCreation():
Object parameter = getRequest().getParameter("additional_data");
if (parameter instanceof String) {
String additionalData = (String)parameter;
// get domain model element
ANode node = (ANode) eo;
// do something with the additional data
// (here we set a property of a domain element)
node.setDescription(additionalData);
return eo;
For what one has to modify:
ANode - is my generic (node in this case) domain model element, use yours
String - used for demonstration purposes, could be any data that shall
be passed to the creation
"additional_data" - the key of the additional data passed to the
creation, one could add more data or use a different string as key
MyModelEditorXXX - the generated classes that hold strings etc., use yours
fillTheCollection(...) - a sample method that fills up the string
collection (with random bullshit so far), can be anything that fills up
your additional data collection dynamically
What is left?
- Use the correct icons. Maybe this can be achieved by using a different
superclass for MyCustomToolEntry. Advice needed.
- Either have the quick creation assistant to support this or remove all
the items from it. I can't do neither. Advice needed.
If anyone can solve the issues mentioned here, your contribution would
be very much appreciated.
Thanks in advance.
Andy
name="as_maps.vcf"
begin:vcard
n:Schoeneck;Andreas
version:2.1
end:vcard
--------------020303050807070308050703--
Re: Dynamic palette and parts [message #222389 is a reply to message #222350] |
Mon, 23 March 2009 12:15   |
That's it.
> What is left?
+ singleDataString,
Your TODO is absolute right, thats the point where you can define your icons.
That's a point I'm also interesting in. To remove is simple, in XXXModelingAssistantProvider just
remove the corresponding types form the list. Or you could disable it in the preferences.
But the ModelingAssistantProvider is quite cool, so the best is keep it.
So the question is how to supply the ModelingAssistantProvider with additional entrys.
> Thanks in advance.
> Regards
> Andy
Re: Dynamic palette and parts [message #222865 is a reply to message #222848] |
Thu, 26 March 2009 09:52  |
> Hey, this is me again!
> Urs, do you know, how all the stuff can be achieved with connections?
> The createTargetRequest method does not seem to be able to pass the
> parameter to the creation request. Do I have to override a different
> method? Or is there another request to return?
> Maybe I am just too stupid today, please help me. My code looks as follows.
> in MyCustomLinktoolEntry:
> Tool tool = new UnspecifiedTypeConnectionTool (elementTypes){
> CreateUnspecifiedTypeConnectionRequest actionCreateRequest =
> new CreateUnspecifiedTypeConnectionRequest(
> elementTypes, false, getPreferencesHint());
> "entry_type", entryType);
> return tool;
Why not doing something like this :
Tool tool = new UnspecifiedTypeConnectionTool(relationshipTypes){
Request req = super.createTargetRequest();
actionCreateRequest.getExtendedData().put("entry_type", entryType);
return req;
If your link is an "typebased" link there is an analog XXXCreateCommand with somethink like this :
* @generated
Transition newElement = WorkflowFactory.eINSTANCE.createTransition();
//where you could do the same as for nodes
getSource().getTransitions().add(newElement);
newElement.setTarget(getTarget());
return newElement;
If it is a reference link, there is no element in your semantic model you could configure, but you could configure the view, but I'm not sure where
you could intercept.
greetings, urs.
Current Time: Sat Jul 19 04:42:48 EDT 2025
Powered by FUDForum. Page generated in 0.05052 seconds
