Home » Eclipse Projects » GEF » XML document as input rather than serialized objects
XML document as input rather than serialized objects [message #222052] Thu, 24 August 2006 11:53 Go to next message
Originally posted by: pilgrim.us.ibm.com
I'm looking for advice as to how to implement an editor using a file
containing an XML document as the input file. Currently my GEF-based
editor's input is a file containing a serialized diagram. My plugin.xml
declares the extension of this serialized file to be used by my editor.
When I save the diagram, after the byte outputstream is written, I next
write an XML document representing the diagram.
What I'd like to do is make the file containing the XML document the
editor's input. If there is a corresponding serialized file, I'd next
read that because it contains some information such as location which is
not retained in the XML document.
Re: XML document as input rather than serialized objects [message #222065 is a reply to message #222052] Thu, 24 August 2006 16:42 Go to previous message
Your model and its persistence is an issue that GEF knows nothing about. You
might consider mapping your POJOs to and from a DOM, which can then be
(de)serialized. Or, you could use a modelling framework such as EMF.
BTW, when you serialize java objects, I'm pretty sure there is a mechanism
for XML serialization instead of binary. I don't know what's involved other
than I saw it mentioned at JavaOne years ago.
"Jeff" <pilgrim@us.ibm.com> wrote in message
news:99727868dd6553cdcf227374f009f900$1@www.eclipse.org...
Previous Topic:Placing Decorations
Next Topic:how to fire a request or how to nest commands
Current Time: Wed Jul 23 10:44:18 EDT 2025
Powered by FUDForum. Page generated in 0.03775 seconds
