Home » Archived » Visual Editor (VE) » VE integration build I20040226 bug?
VE integration build I20040226 bug? [message #21664] Tue, 02 March 2004 14:14 Go to next message
I am trying out the VE integration build I20040226 on
linux GTK with java 1.4.2.
I built a simple frame and ran it
as an application in debug mode. It produced a simple
window that I could look at, and then closed. Going
back into the debug environment, the project was still
running, and I tried to terminate it, but the terminate
button did not seem to work...
Eventually I used a cmd line "kill -HUP <pid>"
to kill it.
Now eclipse will not startup. When it goes to launch
the splash screen comes up, and that is all.
Is there a bug here, and how does one straighten this
out so one can run again?
Re: VE integration build I20040226 bug? [message #22198 is a reply to message #21664] Wed, 03 March 2004 11:18 Go to previous message
Hi Alan,
Do you see any output in the workspace log when you launch eclipse a
second time? Is the eclipse process which is started hung, or just
simply terminates?
Sri.
> to kill it.
Re: VE integration build I20040226 bug? [message #583244 is a reply to message #21664] Wed, 03 March 2004 11:18 Go to previous message
Hi Alan,
simply terminates?
Sri.
> to kill it.
Previous Topic:problem installing Visual Editor.
Next Topic:Documentation
Current Time: Wed Nov 05 21:00:31 EST 2025
Powered by FUDForum. Page generated in 0.03858 seconds
