Home » Archived » BIRT » Multiple values for Report Parameters
Multiple values for Report Parameters [message #221578] Wed, 28 February 2007 04:48 Go to next message
Keeping the question short ...
Can multiple values be supplied to a report parameter?
Ravi Chamarthy
Re: Multiple values for Report Parameters [message #221695 is a reply to message #221578] Wed, 28 February 2007 13:19 Go to previous messageGo to next message
Hello Ravi,
Yes. You can supply multiple values for a report parameter. While in the
design phase, set the report parameter type to either combo box or list.
That way it would accept multiple parameters.
Bidyut
> Ravi Chamarthy
Re: Multiple values for Report Parameters [message #221719 is a reply to message #221578] Wed, 28 February 2007 13:56 Go to previous messageGo to next message
Mauro answered at 2/1/2007 3:59 AM:
Message-ID: <eps355$e6u$1@utils.eclipse.org>
I have got around this problem by replacing the comma in the comma
seperated
list with ','
For example, I enter a parameter such as 37,23,47,58
In the Edit Data Set window, Property Binding section, I modified the query
to:
"SELECT .... FROM ... WHERE id in ('" +
params["pID"].value.replace(",","','") + "')"
The javascript replace() method replaces all instances of , with ','
So the query string executed is changed from '37,23,47,58' to
'37','23','47','58' which produces the correct output.
Re: Multiple values for Report Parameters [message #236630 is a reply to message #221719] Thu, 26 April 2007 18:18 Go to previous message
> seperated
> list with ','
> to:
Here is something I have tried:
For a query like
select * from tbl where id in (?,?,?)
The 'Parameters' in dataset editor can be used to set values for the
different '?' (dynamic markers) , this can be linked to report parameter
also.
regards,
Sunitha.
Previous Topic:How to monitor report progress
Next Topic:Where to create engine?
Current Time: Sun Aug 31 19:56:04 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
