FacesConfig Editor [message #221498] |
Tue, 16 September 2008 22:59  |
I have a java CVS project that is mainly comprised of JavaServer Faces -
and I have an issue with seeing all the tabs of my FacesConfig Editor.
When I view my project's faces-config.xml file using the FacesConfig
Editor, I only see the "source" tab. This happens regardless of whether
I'm in a Web, Java EE, or Java perspective. However, if I create a new
Web project or Java EE project I see all the tabs (e.g., Navigation,
ManagedBean,Component, etc). I'm not finding any way to make those tabs
available under Window -> preferences.
Does anyone know why only the "source" tab would be available in my
FacesConfig editor?
I am running eclipse GanyMede (Version: 3.4.0).
Re: FacesConfig Editor [message #221710 is a reply to message #221658] |
Sat, 20 September 2008 04:09  |
Originally posted by: david_williams.linux.vnet.ibm.com
<html>
<head>
http-equiv="Content-Type">
</head>
Derek Widmayer wrote:
<blockquote
cite="mid:f90a782d6364fc5b682f5d7115510d0c$1@www.eclipse.org"
type="cite">Thanks David... that did the trick. Since I was working
with an existing project I had to manually modify the
org.eclipse.wst.common.component,
org.eclipse.wst.common.project.facet.core.xml, and my .project files.
<br>
<br>
</blockquote>
<font face="Consolas">I'm glad you at least got working again, but to
be clear, there should be some menus and dialogs that could have done
this for you. The end result is those files are modified ... and I know
lots of people do it directly, since that's sometimes easier ... but we
do not want to encourage people to edit those files directly ... so if
you have time to investigate how to do it with menus and dialogs ...
and then have some suggestions on how to make that easier or more
apparent, please open a feature request. <br>
<br>
Thanks, <br>
<br>
</font>
</body>
</html>
FUDForum. Page generated in 0.28564 seconds
