Home » Eclipse Projects » GEF » inverting axis in editor
inverting axis in editor [message #220290] |
Fri, 28 July 2006 04:06  |
Originally posted by: osipov.appliedtech.ru
Guys, is there a way for this? I've looked at logic example - the y axis is
headed downwards. Is there a way to head it upwards? I do need it. All in
all I need that ruler to show negative coordinates below and positive up.
I searched everywhere but still found nothing.
Thanks a lot for your help in advance.
Re: inverting axis in editor [message #221310 is a reply to message #221294] |
Fri, 11 August 2006 09:20   |
Originally posted by: remove-this-pgarbacz.pgs-soft.com.remove.this
Actually it does nothing. The setUnit() method expects one of the constants
defined in RulerProvider. UNIT_CENTIMETERS, UNIT_INCHES, UNIT_PIXELS are
defined by this class, and this could be extended in your implementation.
But it does not make the ruler invertable. DPU measure is calculated using
only those constants and zoomManager object.
Pawel
"Randy Hudson" <none@us.ibm.com> wrote in message
news:ebhuu2$il9$1@utils.eclipse.org...
> What does setUnit(-1) do?
> "Peter Osipov" <osipov@appliedtech.ru> wrote in message
> news:ebgso2$a0t$1@utils.eclipse.org...
>>> Inverted y-axis was not a requirement when the ruler was implemented. It
>>> would require updating viewport, scrollbar, rangemodel, etc. to make it
>> work
>>> properly.
>>> Pratik and myself are no longer paid to work on the GEF project. The
>> amount
>>> of *personal* time we can contribute is obviously going to be limited.
>> Hi, Randy!
>> Oh, right! what a big disappointment! Randy, what I am saying is that all
>> I
>> need is just invert numbers on the ruler. Is that difficult to implement?
Re: inverting axis in editor [message #221427 is a reply to message #221310] |
Sun, 13 August 2006 23:22   |
Thanks, Pawel and Randy!
So, at the end of the day, do I have a possibility of inverting the ruler?
At least, can I make it by just making a copy of those classes like
RulerComposite and "overloading" all the private methods? I know this is
wrong but, as I said, I do need inverting that axis.
Thanks, guys for your help.
> Regards,
> Pawel
It
it
> >> work
> >>> properly.
> >> amount
> >> Hi, Randy!
all
> >> I
implement?
Re: inverting axis in editor [message #221597 is a reply to message #221427] |
Wed, 16 August 2006 08:06   |
Originally posted by: exquisitus.eclipse.org
Hi Peter,
I needed this feature too, and I have extended RulerFigure to achieve
this. The key is to overwrite the paint() method. There is a section
with a for loop almost at the end of this method and all you have to do
is inserting this line right at the beginning of the branch:
num = "" + (-Integer.parseInt(num));
Furthermore there is some work to get the extended RulerFigure being
used, like extending RulerEditPart#createFigure,
RulerEditPartFactory#createRulerEditPart. I have also adapted the method
RulerComposite#createRulerComposite to set the extended Factory.
Sure this way is not very fine, but it works for me... If you have found
a better way, please post it!
Regards, Andreas
>> Regards,
>> Pawel
> It
> it
>>>> work
>>>>> properly.
>>>> amount
>>>> Hi, Randy!
> all
>>>> I
> implement?
Re: inverting axis in editor [message #221686 is a reply to message #221597] |
Wed, 16 August 2006 23:58   |
Thanks, Andreas!
You are a godsend!
Let me try it. Let us hope that guys working on GEF will give us opportunity
to do it in a better manner.
"Andreas Werner" <exquisitus@eclipse.org> ???????/???????? ? ????????
?????????: news:ebv1oh$l0j$1@utils.eclipse.org...
> Hi Peter,
> Regards, Andreas
ruler?
> >> Regards,
> >> Pawel
implemented.
> > It
> > it
> >>>> work
> >>>>> properly.
> >>>> amount
limited.
> >>>> Hi, Randy!
> > all
> >>>> I
> > implement?
Re: inverting axis in editor [message #223053 is a reply to message #221686] |
Mon, 18 September 2006 12:16   |
Originally posted by: something.eclipse.org
Thanks Peter, somehow I missed this thread. Please post your results
when you have a chance to try this out. This is an absolute requirement
for me as well and I really want to be able to use GEF.
adam
Peter Osipov wrote:
> Thanks, Andreas!
> You are a godsend!
>> Hi Peter,
>> Regards, Andreas
> ruler?
>>>> Regards,
>>>> Pawel
> implemented.
>>> It
>>> it
>>>>>> work
>>>>>>> properly.
>>>>>> amount
> limited.
>>>>>> Hi, Randy!
>>> all
>>>>>> I
>>> implement?
Re: inverting axis in editor [message #223105 is a reply to message #223053] |
Wed, 20 September 2006 02:53  |
AdamC, hi!
You see,I did it the way Andreas explained. All in all, you have to paint
your ownRulerFigure, this you should do what he said while explaning.
In RulerFigure you have to change the 287-th line:
String num = "" + (div / divsPerMajorMark) * unitsPerMajorMark;
//$NON-NLS-1$
to this
String num = "" -(div / divsPerMajorMark) * unitsPerMajorMark; //$NON-NLS-1$
----- Original Message -----
Newsgroups: eclipse.tools.gef
Sent: Monday, September 18, 2006 10:16 PM
Subject: Re: inverting axis in editor
> adam
> Peter Osipov wrote:
> > Thanks, Andreas!
> > You are a godsend!
opportunity
> >> Hi Peter,
method
found
> >> Regards, Andreas
> > ruler?
is
> >>>> Regards,
> >>>> Pawel
> > implemented.
> >>> It
make
> >>> it
> >>>>>> work
> >>>>>>> properly.
The
> >>>>>> amount
> > limited.
> >>>>>> Hi, Randy!
that
> >>> all
> >>>>>> I
> >>> implement?
Current Time: Sat Jul 26 18:52:56 EDT 2025
Powered by FUDForum. Page generated in 0.26920 seconds
