XML validation & content assist w/o doctype or namespace [message #221308] |
Fri, 12 September 2008 13:19  |
We'd like to enable the default XML Editor's validation and content
assistance feature, but on an XML file that does not have doctype or
namespace.
We have XML documents w/ namespaces for which we associate XSD with their
namespaces via XML Catalog entries. This works great. But, we don't have
control over this particular XML document, so we're trying to figure out
the best way to provide validation and content assistance w/o a namespace.
Looking at how XML content assistance is performed, I see that
XMLAssociationProvider.getCMElementDeclaration(...) gets the XSD registry
for a given namespace and subsequent processing creates wrappers for each
assistance candidate. I'm thinking that I could add to this [empty]
result by creating an arbitrary XML Catalog registry containing the
supporting XSD and somehow explicitly retrieve the associated XSD and add
selection candidates to the ContentAssistRequest.
What's the best way to implement a solution? Suggestions? Appreciate
your help.
Re: XML validation & content assist w/o doctype or namespace [message #221418 is a reply to message #221356] |
Mon, 15 September 2008 20:43  |
Thank you David and Lawrence.
Yep, with _ we're able to register an XSD for a given file extension.
However, since the XML file is namespace-less, the XSD is parsed as a
default, as note by the code below:
// we assume that this is an inferred CMDocument for a DTD style
'namespaceless' document
CMDocument cmDocument = getCMDocument("", "", "DTD");
Do you guys, anybody, know a way around this? Is there an extension point
to manipulate XMLAssociationProvider?
Thanks.
FUDForum. Page generated in 0.04605 seconds
