Home » Language IDEs » ServerTools (WTP) » Is it possible to install server through extension or API?
Is it possible to install server through extension or API? [message #221378] Mon, 15 September 2008 09:32 Go to next message
Originally posted by: imeikas.gmail.com
I'm trying to bundle a tomcat with my custom eclipse build, but I can't
find a way how I can preregister that server, so that the end user
wouldn't have to configure the Installed Server Runtime environments
themselves.
Is there an extension point or an API I could call to tell the WTP where
the tomcat is installed?
Ivar Meikas
Re: Is it possible to install server through extension or API? [message #221386 is a reply to message #221378] Mon, 15 September 2008 10:22 Go to previous messageGo to next message
Ivar Meikas wrote:
> themselves.
> Regards,
> Ivar Meikas
It should be possible to do programmatically what the user would have to
do manually. Some startup initialization could detect if its running in
a new workspace and if so, create the runtime and server you want. The
WTP automated JUnit tests that run for the Tomcat plug-in
programmatically create a runtime and server. As a starting point, you
can examine this code:
http://dev.eclipse.org/viewcvs/index.cgi/servertools/tests/o rg.eclipse.jst.server.tomcat.core.tests/src/org/eclipse/jst/ server/tomcat/core/tests/AbstractTomcatServerTestCase.java?r evision=1.16&root=WebTools_Project&view=markup
Larry
Re: Is it possible to install server through extension or API? [message #221394 is a reply to message #221386] Mon, 15 September 2008 10:29 Go to previous message
Ivar
Previous Topic:Disable compression on the EAR?
Next Topic:Applets
Current Time: Wed Jul 23 07:49:01 EDT 2025
Powered by FUDForum. Page generated in 0.05908 seconds
