Home » Language IDEs » C / C++ IDE (CDT) » problems view
problems view [message #221221] Tue, 05 August 2008 17:39 Go to next message
Originally posted by: noah.roberts.eng-software.com
Is there any way to get the problems view to just show me problems in
the project I just built? I'm trying to port things over from VS and
there's just a LOT of problems associated with that. It would be MUCH
easier if I could filter them down just a tad.
Re: problems view [message #221229 is a reply to message #221221] Tue, 05 August 2008 19:06 Go to previous messageGo to next message
One way which I use quite a bit is - in view menu (click on little
triangle pointing down - on the right side of the view) enable
Show>Warnings on selection. After that, select a folder in Project
explorer. You gonna see only problems for this folder. You can also
"Configure contents" in the view menu to your liking.
Andrew
Re: problems view [message #221237 is a reply to message #221229] Wed, 06 August 2008 01:06 Go to previous messageGo to next message
That's what I would have suggested...
(actually this is an eclipse.workbench issue, not eclipse.cdt)
additionally:
in "Configure Contents" - now depending if you have Eclipse Ganymede or
an earlier version:
in Ganymede you'll have to check the Boxes on the top left as well (for
which configuration) - and those boxes "where severity is" and the
problem types themselves, for which this settings apply to.
In all versions then (Europa and before):
check the radio button: "On selected element and its children" (I always
wonderer, why this is not the default option!)
Afterwards when you click on the resource tree, you'll only get the
problems from the subtree or the element you selected. When editing a
file you'll only get those problems shown from that file.
Michael
> Andrew
Re: problems view [message #221322 is a reply to message #221237] Wed, 06 August 2008 12:04 Go to previous messageGo to next message
Despite making the suggestion, I actually find this option a bit
inconvinient to use in our environment. What I really want is to see all
errors and warnings for a given subfolder all the time. Working in editor
selects just one file and hides away many errors I am interested in from
the view. There is an option to define working set for the folder, but I
have to switch to new different folder a way too often to define working
sets for each one of them. So I'd rather stick to the default being the
default in future.
Andrew
> Michael
>> Andrew
Re: problems view [message #221330 is a reply to message #221229] Wed, 06 August 2008 12:11 Go to previous messageGo to next message
> Andrew
Heh, I'd never noticed that menu. I clicked everything but those
buttons because they look too much like windows boxes. Never thought to
expect a menu in one.
Thanks. This will give me some stuff to play with.
Re: problems view [message #221338 is a reply to message #221229] Wed, 06 August 2008 12:15 Go to previous messageGo to next message
OK. That works but I only see the warnings. Is there a way to make this
exact behavior with errors as well?
Re: problems view [message #221344 is a reply to message #221338] Wed, 06 August 2008 12:18 Go to previous messageGo to next message
>>> MUCH easier if I could filter them down just a tad.
Got it. I made a new filter and checked off "On any element in same
project" as well as checking off all severity boxes.
Re: problems view [message #221352 is a reply to message #221322] Wed, 06 August 2008 12:40 Go to previous message
> editor selects just one file and hides away many errors I am interested
> in from the view. There is an option to define working set for the
> folder, but I have to switch to new different folder a way too often to
> define working sets for each one of them. So I'd rather stick to the
> default being the default in future.
Hm - yeah - all right. It's a bit odd (designed) behavior, that the
selection does not only depend on which branch you have selected in the
resource tree, but also on editor activity. It would be better, if it
worked as described in the setting "On the selected resource and its
children" and not "On the selected resource and its children or for the
active editor" which it is in reality. The setting as it is could be
achieved by linking the editor to the resource tree anyway.
On the other hand it's a bit strange (for me) to see errors that are not
from the currently edited file, but maybe even from another project.
Previous Topic:Default file extensions for C++ classes
Next Topic:Re: CDT indexer has no project #defines?
Current Time: Thu Oct 23 11:57:37 EDT 2025
Powered by FUDForum. Page generated in 0.04972 seconds
