Home » Newcomers » Newcomers » Can't start Eclipse under XP x64
Can't start Eclipse under XP x64 [message #221162] Thu, 12 July 2007 11:01 Go to next message
Originally posted by: geo.loyola.edu
Hi, folks, new registrant here.
Have spent many a happy hour using Eclipse under XP Professional Version
2002 SP2. Got a new machine with Intel Xeon 5160 CPU running XP
Professional x64 Edition Version 2003 SP2.
I installed java version "1.6.0_02," SE Runtime Environment (build
1.6.0_02-b05), Java Hotspot 64-bit Server VM (build 1.6.0_02-b05, mixed
mode). and Eclipse Europa. Couldn't start Eclipse. Registered and read
this newsgroup to date. So here's my story....
My eclipse.ini files is, verbatim:
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
128M
-vm
C:\Program Files\Java\jre1.6.0_02\bin\javaw.exe
-vmargs
-Xms40m
-Xmx512m
When I double-click on the Eclipse icon, I get no splash screen at all but
an Eclipse dialog box with the following:
JVM terminated. Exit code=13
-Xms40m
-Xmx512m
-XX:MaxPermSize=128M
-jar C:\Program
Files(x85)\eclipse\plugins\org.exclipse.equinox.launcher_1.0 .0.v20070606.jar
-os win32
-ws win32
-arch x86
-showsplash
-launcher c:\Program Files (x86)\eclipse\eclipse.exe
-name Eclipse
--launcher.library C:\Program Files
(x86)\eclipse\plugins\org.eclipse.equinox.launcher.win32.win 32.x86_1.0.0.v20070523\eclipse_1017a.dll
-startup C:\Program Files
(x86)\eclipse\plugins\org.eclipse.equinox.launcher_1.0.0.v20 070606.jar
-exitdata a74_e0
-vm C:\Program Files\Java\jre1.6.0_02\bin\javaw.exe
-vmargs
-Xms50m
-Xmx512m
-jar c:\Program Files
I have the following environment variables (among others) defined:
CLASSPATH=.;%J2EE_PATH%
J2EE_HOME=C:\Sun\SDK
J2EE_PATH=%J2EE_HOME%\lib\j2ee.jar
JAVA_HOME=C:\Program Files\Java\jre1.6.0_02
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem ;%JAVA_HOME%\bin;%J2EE_HOME%\bin
PROCESSOR_ARCHITECTURE=AMD64
Naturally, the Eclipse dialog box makes me suspicious of items that refer to
win32 and x86, but I haven't figured out where these come from. Any advice
welcome!
Re: Can't start Eclipse under XP x64 [message #221272 is a reply to message #221162] Thu, 12 July 2007 20:29 Go to previous messageGo to next message
There isn't a 64bit version of Eclipse release for Windows yet, so you
most likely downloaded the 32 bit version. I believe that this will run
under 64bit XP if you use a 32bit jdk instead of the 64bit one you have
downloaded.
> -showsplash
> 128M
> -vm
> -vmargs
> -Xms40m
> -Xmx512m
> -Xms40m
> -Xmx512m
> -jar C:\Program
> -os win32
> -ws win32
> -arch x86
> -showsplash
> -name Eclipse
> -exitdata a74_e0
> -vmargs
> -Xms50m
> -Xmx512m
> welcome!
Re: Can't start Eclipse under XP x64 [message #221443 is a reply to message #221272] Fri, 13 July 2007 14:29 Go to previous message
"David Wegener" <wegener@cboenospam.com> wrote in message
news:f76h0t$6jv$1@build.eclipse.org...
> downloaded.
Thanks, David. Your advice did the trick. I downloaded
jdk-6u2-windows-i586-p.exe. This installer was smart enough to install into
"Program Files (x86)" (vice "Program Files").
>> -vm
I changed this to C:\Program Files (x86)\Java\jre1.6.0_02\bin\javaw.exe,
double-clicked on the Eclipse icon, and all was well.
Thanks again, David.
Previous Topic:question about jars and project output
Next Topic:Class Diagrams in Eclipse
Current Time: Mon Jul 21 05:02:32 EDT 2025
Powered by FUDForum. Page generated in 0.32222 seconds
