Home » Eclipse Projects » GEF » inverting axis in editor
inverting axis in editor [message #220290] Fri, 28 July 2006 04:06 Go to next message
Originally posted by: osipov.appliedtech.ru
Guys, is there a way for this? I've looked at logic example - the y axis is
headed downwards. Is there a way to head it upwards? I do need it. All in
all I need that ruler to show negative coordinates below and positive up.
I searched everywhere but still found nothing.
Thanks a lot for your help in advance.
Re: inverting axis in editor [message #221105 is a reply to message #220290] Wed, 09 August 2006 10:23 Go to previous messageGo to next message
Originally posted by: remove-this-pgarbacz.pgs-soft.com.remove.this
"Peter Osipov" <osipov@appliedtech.ru> wrote in message
news:eacgia$25d$1@utils.eclipse.org...
> is
I also need this feature but it appeared that it is feasible only with
overriding the original rulers. But they are not really overridable so you
should rewrite the RulerComposite. I wanted one more thing too: why are the
rulers shown only at the NORTH and WEST positions? And one more question:
can I override the RulerFigure so I can draw a ruler looking rather as an
axis not the ruler?
Pawel
Re: inverting axis in editor [message #221136 is a reply to message #221105] Thu, 10 August 2006 00:46 Go to previous messageGo to next message
Hi everybody!
Why does nobody answer? I mean I found a similar topic but there was no
answer as well.
Did anybody taboo this topic or what?
> > is
in
up.
the
> axis not the ruler?
> Regards,
> Pawel
Re: inverting axis in editor [message #221144 is a reply to message #221105] Thu, 10 August 2006 00:48 Go to previous messageGo to next message
I mean, Pratik, you do answer a lot and RulerComposite was written by you.
Why do not you break this taboo and answer us something?
> > is
in
up.
the
> axis not the ruler?
> Regards,
> Pawel
Re: inverting axis in editor [message #221207 is a reply to message #221144] Thu, 10 August 2006 13:39 Go to previous messageGo to next message
Inverted y-axis was not a requirement when the ruler was implemented. It
would require updating viewport, scrollbar, rangemodel, etc. to make it work
properly.
Pratik and myself are no longer paid to work on the GEF project. The amount
of *personal* time we can contribute is obviously going to be limited.
news:ebedro$ldr$1@utils.eclipse.org...
Re: inverting axis in editor [message #221256 is a reply to message #221207] Thu, 10 August 2006 23:15 Go to previous messageGo to next message
work
> properly.
amount
Hi, Randy!
Oh, right! what a big disappointment! Randy, what I am saying is that all I
need is just invert numbers on the ruler. Is that difficult to implement?
Re: inverting axis in editor [message #221294 is a reply to message #221256] Fri, 11 August 2006 08:58 Go to previous messageGo to next message
What does setUnit(-1) do?
news:ebgso2$a0t$1@utils.eclipse.org...
> work
>> properly.
> amount
> Hi, Randy!
> I
Re: inverting axis in editor [message #221310 is a reply to message #221294] Fri, 11 August 2006 09:20 Go to previous messageGo to next message
Actually it does nothing. The setUnit() method expects one of the constants
defined in RulerProvider. UNIT_CENTIMETERS, UNIT_INCHES, UNIT_PIXELS are
defined by this class, and this could be extended in your implementation.
But it does not make the ruler invertable. DPU measure is calculated using
only those constants and zoomManager object.
Pawel
"Randy Hudson" <none@us.ibm.com> wrote in message
news:ebhuu2$il9$1@utils.eclipse.org...
>> work
>>> properly.
>> amount
>> Hi, Randy!
>> I
Re: inverting axis in editor [message #221427 is a reply to message #221310] Sun, 13 August 2006 23:22 Go to previous messageGo to next message
Thanks, Pawel and Randy!
So, at the end of the day, do I have a possibility of inverting the ruler?
At least, can I make it by just making a copy of those classes like
RulerComposite and "overloading" all the private methods? I know this is
wrong but, as I said, I do need inverting that axis.
Thanks, guys for your help.
> Regards,
> Pawel
It
it
> >> work
> >>> properly.
> >> amount
> >> Hi, Randy!
all
> >> I
implement?
Re: inverting axis in editor [message #221597 is a reply to message #221427] Wed, 16 August 2006 08:06 Go to previous messageGo to next message
Originally posted by: exquisitus.eclipse.org
Hi Peter,
I needed this feature too, and I have extended RulerFigure to achieve
this. The key is to overwrite the paint() method. There is a section
with a for loop almost at the end of this method and all you have to do
is inserting this line right at the beginning of the branch:
num = "" + (-Integer.parseInt(num));
Furthermore there is some work to get the extended RulerFigure being
used, like extending RulerEditPart#createFigure,
RulerEditPartFactory#createRulerEditPart. I have also adapted the method
RulerComposite#createRulerComposite to set the extended Factory.
Sure this way is not very fine, but it works for me... If you have found
a better way, please post it!
Regards, Andreas
>> Regards,
>> Pawel
> It
> it
>>>> work
>>>>> properly.
>>>> amount
>>>> Hi, Randy!
> all
>>>> I
> implement?
Re: inverting axis in editor [message #221686 is a reply to message #221597] Wed, 16 August 2006 23:58 Go to previous messageGo to next message
Thanks, Andreas!
You are a godsend!
Let me try it. Let us hope that guys working on GEF will give us opportunity
to do it in a better manner.
"Andreas Werner" <exquisitus@eclipse.org> ???????/???????? ? ????????
?????????: news:ebv1oh$l0j$1@utils.eclipse.org...
> Hi Peter,
> Regards, Andreas
ruler?
> >> Regards,
> >> Pawel
implemented.
> > It
> > it
> >>>> work
> >>>>> properly.
> >>>> amount
limited.
> >>>> Hi, Randy!
> > all
> >>>> I
> > implement?
Re: inverting axis in editor [message #223053 is a reply to message #221686] Mon, 18 September 2006 12:16 Go to previous messageGo to next message
Originally posted by: something.eclipse.org
Thanks Peter, somehow I missed this thread. Please post your results
when you have a chance to try this out. This is an absolute requirement
for me as well and I really want to be able to use GEF.
adam
Peter Osipov wrote:
> Thanks, Andreas!
> You are a godsend!
>> Hi Peter,
>> Regards, Andreas
> ruler?
>>>> Regards,
>>>> Pawel
> implemented.
>>> It
>>> it
>>>>>> work
>>>>>>> properly.
>>>>>> amount
> limited.
>>>>>> Hi, Randy!
>>> all
>>>>>> I
>>> implement?
Re: inverting axis in editor [message #223105 is a reply to message #223053] Wed, 20 September 2006 02:53 Go to previous message
AdamC, hi!
You see,I did it the way Andreas explained. All in all, you have to paint
your ownRulerFigure, this you should do what he said while explaning.
In RulerFigure you have to change the 287-th line:
String num = "" + (div / divsPerMajorMark) * unitsPerMajorMark;
//$NON-NLS-1$
to this
String num = "" -(div / divsPerMajorMark) * unitsPerMajorMark; //$NON-NLS-1$
----- Original Message -----
Newsgroups: eclipse.tools.gef
Sent: Monday, September 18, 2006 10:16 PM
Subject: Re: inverting axis in editor
> adam
> Peter Osipov wrote:
> > Thanks, Andreas!
> > You are a godsend!
opportunity
> >> Hi Peter,
method
found
> >> Regards, Andreas
> > ruler?
is
> >>>> Regards,
> >>>> Pawel
> > implemented.
> >>> It
make
> >>> it
> >>>>>> work
> >>>>>>> properly.
The
> >>>>>> amount
> > limited.
> >>>>>> Hi, Randy!
that
> >>> all
> >>>>>> I
> >>> implement?
Previous Topic:GEF application, not plug-in!
Next Topic:IFigure tooltip
Current Time: Sat Jul 26 12:16:25 EDT 2025
Powered by FUDForum. Page generated in 0.27011 seconds
