Team -> Upload - Where did it go? [message #221060] |
Fri, 02 April 2004 16:19  |
Originally posted by: joezulli.yahoo.com
Hello All,
I've been using 3.0 M6 for a while now and have bee relying on the ftp
plugin for deploying my code to my test web server. It worked quite well.
Recently, I upgraded to M8 and found that the Team->Upload context menu is
gone. The only way I know how to upload a file if I click the synchronize
button, find the file I want to synchronize in the wizard that pops up,
check it off, click finish (which opens up the team synchronizing
perspective), then click to upload my file.
Is there any shorter way to do this? I do uploads MANY times a day and
it's usually for just one file at a time. If not can we bring the old
"Upload" menu item back? I've been looking for some documentation on this
but the documentation that came with the plugin is still for Eclipse 2.0
and is quite out of sync.
Thanks in advance for any help!
Joe
Re: Team -> Upload - Where did it go? [message #222141 is a reply to message #221060] |
Mon, 05 April 2004 14:29   |
The FTP plugin has been intergrated into the new sync framework. There
are now two ways to work with FTP
1) When you want to upload, Choose Export, select FTP and click next.
The wizard allows you to associate any folder (not just a project) with
a remote FTP location.
2) If you'd rather se the sync view, you can perform the above step once
and subsequently use the sync view to upload changed resources.
Michael
Joe Zulli wrote:
> Hello All,
> Joe
Re: Team -> Upload - Where did it go? [message #228577 is a reply to message #228411] |
Wed, 14 April 2004 09:30  |
Because the plugins are not supported at the same quality level as those
in the SDK. They are offered more as examples than products but are
still useful to some.
Michael
Channing Walton wrote:
> Michael Valenta wrote:
>> There is a separate download on the download page for each Eclipse
>> build. It is near the bottom of the download page so you'll need to
>> scroll down to see it.
> Any ideas why this isn't included in the standard eclipse build ?
> Channing
FUDForum. Page generated in 0.08609 seconds
