Home » Eclipse Projects » GEF » Figure paint causes 100% CPU load
Figure paint causes 100% CPU load [message #220767] Fri, 04 August 2006 08:24 Go to next message
Originally posted by: dscholz.htwm.de
at first I want to let you know that I'm German. So excuse me if my
English is not perfect.
I'm new to GEF. After reading some articles and tutorials I went to the
shapes example to learn and understand GEF a little bit more. I extended
this example by painting a sine figure depending on its size and the
number of oscillations. I do this by overriding the paint method and
drawing the sine with bezier lines (Path.cubeTo(...)). The figure is
painted properly. You can see that on this picture (3 oscillations):
http://img209.imageshack.us/img209/5725/sinustg7.jpg
All seems ok, but when the figure is drawn, the CPU load goes up to 100%
and stays at this value even after the painting. If I delete the figure or
exit the application everything is ok.
Here is the code of the figure, I think it can be helpful:
package org.eclipse.gef.examples.shapes.model;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.geometry.Point;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.swt.graphics.Path;
public class SinusFigure extends Figure {
private int oscillations;
public SinusFigure() {
oscillations = 1;
public SinusFigure(int osci) {
if (osci > 0)
oscillations = osci;
else
throw (new IllegalArgumentException());
public void paint(Graphics g) {
setBackgroundColor(this.getBackgroundColor());
setForegroundColor(this.getForegroundColor());
g.setLineWidth(1);
Path p = new Path(null);
Point top_left = this.getLocation();
Point bottom_right = this.getBounds().getBottomRight();
int diffy = (bottom_right.y - top_left.y)/2;
int ymid = top_left.y + diffy; //middle of y
int diffx = (bottom_right.x - top_left.x)/(2 * oscillations); //distance
between zeroises
int diffamp = diffx/3; //x-distance for controlpoints
int xstart = top_left.x; //x value of the starting point for the next
bezier line
int ystart = ymid; //y value of the starting point for the next bezier
line
int xzero = 0; //the zeroise
int cx1, cy1, cx2, cy2; //the values for the bezier
p.moveTo(xstart, ystart);
for(int i=0; i < oscillations; i++)
xstart = top_left.x + (i * 2) * diffx;
xzero = xstart + diffx;
cx1 = xstart + diffamp;
cy1 = top_left.y;
cx2 = xstart + 2 * diffamp;
cy2 = cy1;
p.cubicTo(cx1, cy1, cx2, cy2, xzero, ymid);
xstart = xzero;
ystart = ymid;
cy1 = bottom_right.y;
cy2 = cy1;
g.drawPath(p);
p.dispose();
Rectangle rect = this.getBounds().getCopy();
rect.width = rect.width - (rect.right() - xzero); //equalize the width
of bounds-rectangle to the width of the sinus
this.setBounds(rect);
I assume that the figure is repainted the whole time or something similar
which causes the 100% CPU load. But for what reason? What's wrong? I hope
it's not completely wrong ;-) Thanks for your help.
BTW: I'm using Eclipse + GEF 3.2 and the Java 1.4.2 SDK.
Re: Figure paint causes 100% CPU load [message #220776 is a reply to message #220767] Fri, 04 August 2006 09:04 Go to previous messageGo to next message
Originally posted by: ingo.koch[nospam].sap.com
you call:
in the paint method.
this re"paint"s the figure...
by the way, these statements do exactly... nothing
did you mean: graphics.setForegroundColor(this.getForegroundColor()); ?
Regards, Ingo
"Daniel Scholz" <dscholz@htwm.de> wrote in message
news:ebf6ea13184c72e5e5cb28deabb8488d$1@www.eclipse.org...
> Hello,
> oscillations = 1;
> if (osci > 0)
> else
> g.setLineWidth(1);
> between zeroises
> bezier line
> line
> cy1 = top_left.y;
> cy2 = cy1;
> xstart = xzero;
> ystart = ymid;
> cy2 = cy1;
> g.drawPath(p);
> p.dispose();
Re: Figure paint causes 100% CPU load [message #220797 is a reply to message #220776] Fri, 04 August 2006 09:23 Go to previous messageGo to next message
Hello Ingo,
your answer is exactly the right solution. I changed the 2 lines with the
set...Color(...) methods to this:
g.setBackgroundColor(this.getBackgroundColor());
g.setForegroundColor(this.getForegroundColor());
Everything is fine now. It was a small mistake but of course it's a big
difference between the figure and the graphics object. Thank you very much
for your help.
Regards, Daniel
Ingo Koch wrote:
> you call:
> Regards, Ingo
>> Hello,
>> oscillations = 1;
>> if (osci > 0)
>> else
>> g.setLineWidth(1);
>> between zeroises
>> bezier line
>> line
>> cy1 = top_left.y;
>> cy2 = cy1;
>> xstart = xzero;
>> ystart = ymid;
>> cy2 = cy1;
>> g.drawPath(p);
>> p.dispose();
Re: Figure paint causes 100% CPU load [message #220822 is a reply to message #220797] Fri, 04 August 2006 12:52 Go to previous message
Originally posted by: none.unknown.com
You should be overriding paintFigure(), not paint(). Then you won't have to
set the colors yourself, among other things.
news:8a4bf93a1cdd0a2855f062c1d9f0d10d$1@www.eclipse.org...
> Hello Ingo,
> for your help.
> Regards, Daniel
> Ingo Koch wrote:
>> you call:
>> Regards, Ingo
>>> Hello,
>>> or
>>> oscillations = 1;
>>> if (osci > 0)
>>> else
>>> g.setLineWidth(1);
>>> between zeroises
>>> bezier line
>>> line
>>> cy1 = top_left.y;
>>> cy2 = cy1;
>>> xstart = xzero;
>>> ystart = ymid;
>>> cy2 = cy1;
>>> g.drawPath(p);
>>> p.dispose();
>>> similar
>>> hope
Previous Topic:Trouble with GEF and update in RCP application
Next Topic:question about move editpart
Current Time: Thu Nov 13 10:40:21 EST 2025
Powered by FUDForum. Page generated in 0.06368 seconds
