Home » Eclipse Projects » Nebula » Maximize problem
Maximize problem [message #21795] Wed, 03 January 2007 00:04 Go to next message
Originally posted by: krishna_24jan.yahoomail.com
I have a grid with some rows and columns. I have resized my grid size in
the code bu using grid.setSize().When i run my application iam getting the
size of the grid that i have set in my code.But when i maximize it ,the
grid gets maximized but the griditems in which i have placed images dosent
get resized.
can any one help me out in this..?
Thanks in advance
krishna
Re: Maximize problem [message #21842 is a reply to message #21795] Wed, 03 January 2007 07:11 Go to previous messageGo to next message
Hi Krishna ,
Try with SashForm....
Re: Maximize problem [message #21886 is a reply to message #21842] Thu, 04 January 2007 01:42 Go to previous messageGo to next message
nop!its not workin with sahform!
Re: Maximize problem [message #22063 is a reply to message #21795] Thu, 04 January 2007 11:27 Go to previous messageGo to next message
Krishna,
I don't quite understand. Are you trying to change the width of the
columns?
-Chris
krishna wrote:
> in the code bu using grid.setSize().When i run my application iam
> getting the size of the grid that i have set in my code.But when i
> maximize it ,the grid gets maximized but the griditems in which i have
> placed images dosent get resized.
> Thanks in advance
> krishna
Re: Maximize problem [message #22569 is a reply to message #22063] Mon, 08 January 2007 02:06 Go to previous messageGo to next message
No,iam not trying to change the size of grid columns.!
I have placed some text in grid items.Now when i maximize the grid,the
window size gets maximized but the grid size remains the same.
Re: Maximize problem [message #22874 is a reply to message #22569] Mon, 08 January 2007 09:33 Go to previous messageGo to next message
Can you attach some code?
Re: Maximize problem [message #29025 is a reply to message #22569] Tue, 13 February 2007 13:01 Go to previous message
The grid is not getting maximized since it didnt know the change in the
window size.
you may need to handle the control event, and resize the grid through
that event. So whenever there is a resize, your code should be invoked
to resize the complete grid.
Re: Maximize problem [message #573672 is a reply to message #21795] Wed, 03 January 2007 07:11 Go to previous message
Hi Krishna ,
Re: Maximize problem [message #573707 is a reply to message #21842] Thu, 04 January 2007 01:42 Go to previous message
Re: Maximize problem [message #573909 is a reply to message #21795] Thu, 04 January 2007 11:27 Go to previous message
Krishna,
columns?
-Chris
krishna wrote:
> Thanks in advance
> krishna
Re: Maximize problem [message #574358 is a reply to message #22063] Mon, 08 January 2007 02:06 Go to previous message
Re: Maximize problem [message #574589 is a reply to message #22569] Mon, 08 January 2007 09:33 Go to previous message
Re: Maximize problem [message #578477 is a reply to message #22569] Tue, 13 February 2007 13:01 Go to previous message
window size.
Previous Topic:label provider for grid viewer
Next Topic:To change the color of the image in the cell
Current Time: Sat Nov 08 07:21:02 EST 2025
Powered by FUDForum. Page generated in 0.07116 seconds
