| Logic Editor Question: Add a LogicLabel to Circuit [message #21711] |
Fri, 27 September 2002 02:01  |
I would like to change the logic in logic editor example, so that every
circuit has an logic label inside it everytime a user seclect that
component.
So In the constructor of teh CircuitEditPart, I add this line:
addChildVisual(new LogicLabelEditPart(), 0);
I can see the label in the editor, but
- it just should an empty rectangle, the text "label" is missing.
- which I click the mose over it, the curser did not change and I can't add
text inside that logic label
Is there something I miss?
Thanks for your help again.
| Re: Logic Editor Question: Add a LogicLabel to Circuit [message #22028 is a reply to message #21711] |
Fri, 27 September 2002 14:19   |
I tried addChild(new LogicLabelEditPart(), -1) instead of addChildVisual(),
it fails with a NullPointer Exception.
When I manually add a LogicLabel to the Container, it did break at
addChildVisual(), so I don't know what I am missing.
Thanks.
"Sam Cheung" <scheung@novarra.com> wrote in message
news:an0r2k$rgo$1@rogue.oti.com...
> component.
add
| Re: Logic Editor Question: Add a LogicLabel to Circuit [message #22071 is a reply to message #21711] |
Fri, 27 September 2002 15:24  |
> component.
I already responded to this question below. Do NOT new an EditPart. You
need a Label in the *model*, not just in the EditParts.
add
FUDForum. Page generated in 0.24230 seconds
