Home » Archived » BIRT » Using parameters in WHERE clause.. (probably a stupid question)
Using parameters in WHERE clause.. (probably a stupid question) [message #220175] Wed, 21 February 2007 08:09 Go to next message
Originally posted by: ryan.seldonplan.com
Hi All,
This is probably a really stupid question, but if I don't ask I'll never
work it out. Google and eclipse.org don't turn up any examples, neither
does a title search for SQL on the last few thousand posts from this
group...
I've created a dataset in BIRT 2.1.2 in Eclipse, which will be used as the
source of a graph.
The SQL is:
SELECT
count(distinct ID) as total,
d.description
FROM licences L
INNER JOIN departments d ON d.id=l.dim_department
GROUP BY
d.description
That works fine.
The chart will eventually be embedded in a webpage, accessed via the
appropriate URL.
What I'd like to do is add pass a parameter by the url to the report, which
would then be put into the sql's where clause.
I've tried defining a "report parameter" called "department" and making my
SQL look like this:
SELECT
d.description
FROM licences L
WHERE
d.dim_department=params["department"]
GROUP BY
d.description
However, that doesn't work.
Can anyone explain to me what I'm doing wrong?
Thanks in advance!
Ryan
Re: Using parameters in WHERE clause.. (probably a stupid question) [message #220194 is a reply to message #220175] Wed, 21 February 2007 08:20 Go to previous messageGo to next message
Originally posted by: martin.tauber.t-online.de
Ryan,
try this:
add a "Report"-parameter to your report
enter the query using a ? as a placeholder for the parameter
SELECT
d.description
FROM licences L
WHERE
d.dim_department = ?
GROUP BY
d.description
click on the "parameters" in the "edit data set"-dialog
add a "dataset"-parameter and link it to the "Report"-parameter
this should work ... If you are using String values I experianced that
the value of the parameter must be quoted.
Martin
Ryan Barrett schrieb:
> Hi All,
> group...
> source of a graph.
> The SQL is:
> SELECT
> d.description
> FROM licences L
> GROUP BY
> d.description
> That works fine.
> appropriate URL.
> SQL look like this:
> SELECT
> d.description
> FROM licences L
> WHERE
> GROUP BY
> d.description
> Thanks in advance!
Re: Using parameters in WHERE clause.. (probably a stupid question) [message #220210 is a reply to message #220194] Wed, 21 February 2007 08:45 Go to previous message
Hi Martin,
Thanks, that works perfectly!
Ryan
"Martin Tauber" <martin.tauber@t-online.de> wrote in message
news:erhgu5$2i9$1@utils.eclipse.org...
> Ryan,
> try this:
> SELECT
> d.description
> FROM licences L
> WHERE
> GROUP BY
> d.description
> this should work ... If you are using String values I experianced that the
> Regards
> Martin
>> Hi All,
>> group...
>> the source of a graph.
>> The SQL is:
>> SELECT
>> d.description
>> FROM licences L
>> GROUP BY
>> d.description
>> That works fine.
>> appropriate URL.
>> which would then be put into the sql's where clause.
>> my SQL look like this:
>> SELECT
>> d.description
>> FROM licences L
>> WHERE
>> GROUP BY
>> d.description
>> Thanks in advance!
Previous Topic:Do Charts work in Libraries?
Next Topic:PHP sessions/authentication
Current Time: Wed Sep 17 01:09:52 EDT 2025
Powered by FUDForum. Page generated in 0.43804 seconds
