Home » Language IDEs » Java Development Tools (JDT) » Inserting comments above a particular ASTNode
Inserting comments above a particular ASTNode [message #220059] Mon, 05 December 2005 13:53 Go to next message
I'm trying to insert a comment before a particular ASTNode.
For example, I try to discover wherever a particular function or class is
used. Then I would like
to add a line comment just before that statement.
Any ideas on how to do that?
James.
Re: Inserting comments above a particular ASTNode [message #220167 is a reply to message #220059] Tue, 06 December 2005 12:54 Go to previous messageGo to next message
I assume you use an ASTRewrite. Then you can just create your comment with
astRewrite.createStringPlaceholder("//comment", ASTNode.EMPTY_STATEMENT)
and then insert this node in the statement list before the node to be
documented.
HTH
Markus
> James.
Re: Inserting comments above a particular ASTNode [message #220193 is a reply to message #220167] Tue, 06 December 2005 17:05 Go to previous messageGo to next message
Hi Markus
Thanks for the reply.
Pardon the newbie question... but are you suggesting to get a ListRewrite
and then do a listRewrite.insertBefore() ?
When I attempt this I get exceptions ( after numerous attempts ).
Thanks again,
- James.
"Markus Keller" <markus_keller@ch.ibm.com> wrote in message
news:dn4j9p$v53$1@news.eclipse.org...
> documented.
> HTH
> Markus
is
> > Thanks,
> > James.
Re: Inserting comments above a particular ASTNode [message #220208 is a reply to message #220193] Tue, 06 December 2005 17:37 Go to previous message
Hi Markus,
It works!
Thanks.
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:dn510r$kl8$1@news.eclipse.org...
> Hi Markus
> Thanks again,
> - James.
with
> > documented.
> > HTH
> > Markus
> is
> > > Thanks,
> > > James.
Previous Topic:Task tags priority and sorting
Next Topic:adding javadoc sources
Current Time: Thu Oct 16 05:49:40 EDT 2025
Powered by FUDForum. Page generated in 0.05107 seconds
