Home » Language IDEs » ServerTools (WTP) » How do I change "WebContent" folder in web project?
How do I change "WebContent" folder in web project? [message #217914] Mon, 21 July 2008 21:45 Go to next message
Originally posted by: ben.playscapegames.com
How do I change "WebContent" folder to another value in a Dynamic Web
Project in Web Tools 3.0?
I am using Maven which wants to put web content in a subfolder. But I
couldnt find the setting to customize the web content path.
Thank you
Ben
Re: How do I change "WebContent" folder in web project? [message #217933 is a reply to message #217914] Tue, 22 July 2008 04:22 Go to previous messageGo to next message
> Thank you
> Ben
AFAIK you have manually edit the file called
org.eclipse.wst.common.component in .settings of your project.
Use CTRL+SHIFT+R to open it.
Replace WebContent with the folder you need.
There's an enhancement request open to provide a UI way of editing that
file:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=133359
Please comment and/or vote on it if you are interested.
Mauro.
Re: How do I change "WebContent" folder in web project? [message #217997 is a reply to message #217914] Tue, 22 July 2008 12:07 Go to previous messageGo to next message
You can specify an alternate web content directory during project
creation. If you already have a project created, you can invoke the
refactor action on WebContent and specify the new location. I believe that
will update the component metadata.
Re: How do I change "WebContent" folder in web project? [message #220139 is a reply to message #217933] Wed, 03 September 2008 23:15 Go to previous message
Originally posted by: e.komissarov.dartit.ru
Why I can't set root folder as "WebContent" in new Dynamic Web Project
Wizard?
Only manually edit the file org.eclipse.wst.common.component.
Mauro Molinari пишет:
>> Thank you
>> Ben
> file:
> Mauro.
Previous Topic:Tomcat 6 web app is not started because of "java.io.IOException: invalid header"
Next Topic:Array cannot be resolved error
Current Time: Thu Jul 17 15:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.24906 seconds
