Home » Eclipse Projects » DSDP - Target Management » Missing RemoteSystemsTempFiles (Remote Systems Explorer)
Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #20629] Fri, 18 April 2008 10:00 Go to next message
Originally posted by: Michal.Dobisek.wallstreetsystems.com
when cleaning up my workspace, I deleted the RemoteSystemsTempFiles
project - I assumed, that RSE will recreate it if needed. But it doesn't
seem to be the case. Now, when I try to open some file from RSE, I get
the error message in the editor
Resource '/RemoteSystemsTempFiles/ ... ' does not exist.
The project RemoteSystemsTempFiles does not exist (i.e. not shown in
navigator), but when I try to create it manually, the wizard says such
project already exist (and doesn't let me to create it).
Surprisingly, the RSE target files are created on disc in
{workspace.loc}/RemoteSystemsTempFiles, despite the fact, that the
project is not visible.
Is there any known trick how to fix this?
Thanks for the suggestions,
Michal
Re: Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #20633 is a reply to message #20629] Fri, 18 April 2008 18:59 Go to previous messageGo to next message
In my Eclipse installation the Navigator view does not filter the
RemoteSystems* projects from view but the package explorer does. If
you're using the package or project explorer, click the little triangle
\/ at the right of the explorer toolbar and choose Filters in the menu
and take a look to see if there are RemoteSystems* items in the list
with their checkboxes checked. If so, uncheck them and you should see
the entries in your tree view.
You may need to right click in the project tree view and choose Refresh
to sync things up.
Steve
Michal Dobisek wrote:
> Michal
Re: Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #21835 is a reply to message #20633] Tue, 22 April 2008 05:12 Go to previous messageGo to next message
Thanks for advice,
it was really filtered out (the filtering works also in Navigator for
me), these steps fixed my problem:
1) Unfilter Remote System Explorer File Cache
2) See the project is closed - try to open it - failed because missing
..project
3) Recreate .project file manually
4) Open the project.
Michal
> to sync things up.
> Steve
Re: Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #22010 is a reply to message #20629] Tue, 22 April 2008 11:42 Go to previous message
What version of RSE are you using? - What you describe sounds
very much like
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175748
which should have been fixed by RSE 2.0
It looks almost like a Regression, where you had deleted the
RemoteSystemsTempFiles project, RSE had re-generated a .project
file but it is still not useable.
Please open a bug for your problem, and attach a copy of your .log
file (from <workspace>/.metadata/.log). The logfile will show
us your Eclipse version; please also give information about your
RSE version, OS in use (Windows/Linux/Mac/...). Also, let us
know how exactly you had deleted the Tempfiles project (from Eclipse
or on the Harddisk), and whether the tip about Refresh helped you.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> Michal
Re: Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #573784 is a reply to message #20629] Fri, 18 April 2008 18:59 Go to previous message
to sync things up.
Steve
> Michal
Re: Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #574018 is a reply to message #20633] Tue, 22 April 2008 05:12 Go to previous message
Thanks for advice,
..project
Michal
> to sync things up.
> Steve
Re: Missing RemoteSystemsTempFiles (Remote Systems Explorer) [message #574143 is a reply to message #20629] Tue, 22 April 2008 11:42 Go to previous message
very much like
> Michal
Previous Topic:Set daemon port programmatically
Next Topic:Re: rse; dstore connector service; using port 0 error
Current Time: Fri Oct 24 18:21:21 EDT 2025
Powered by FUDForum. Page generated in 0.05149 seconds
