Centering the text in a label [message #219935] |
Wed, 25 February 2009 04:51  |
I have changed the look on my state-nodes from an ordinary rectangle to a
rounded rectangle. This caused the label with the state name to be placed
a bit outside of the figure, so that when I add a name to my state it is
shown like in this picture:
http://farm4.static.flickr.com/3440/3265528805_dd9642471f_o. jpg
It might not be too easy to see, but the first letter of the name is
partially placed outside of the figure. I don't like this, so I would like
to center the text in the label (I have to assume that no state name is
longer than the length of the figure). Is this possible? And where can I
make this change?
Anna
Re: Centering the text in a label [message #219995 is a reply to message #219935] |
Wed, 25 February 2009 08:06  |
Originally posted by: cayla_sha.gmx.net
Hello Anna,
This issue was already discussed here:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg16168.html
You use the GridLayout on the Figure of the EditPart (the inner class
inside of the EditPart). And the Label gets the GridLayoutData.
Best wishes
Julia
> a rounded rectangle. This caused the label with the state name to be
> placed a bit outside of the figure, so that when I add a name to my
> state it is shown like in this picture:
> like to center the text in the label (I have to assume that no state
> name is longer than the length of the figure). Is this possible? And
> where can I make this change?
> Anna
FUDForum. Page generated in 0.03926 seconds
