Home » Eclipse Projects » GEF » How does ShortestPath routing algorithm work?
How does ShortestPath routing algorithm work? [message #219797] Fri, 21 July 2006 13:01 Go to next message
Originally posted by: pilgrim.us.ibm.com
The shortest path routing algorithm seems to do nothing different than
manual routing in my application. I've used the logic example as a base
and see the difference there. Switching to Manhattan in my application
does result in the same routing as the logic example. However, shortest
path does not. I have updated the value returned by getPreferredSize for
my figures. Any suggestions? Thanks!
Re: How does ShortestPath routing algorithm work? [message #219866 is a reply to message #219797] Sat, 22 July 2006 09:06 Go to previous messageGo to next message
Originally posted by: cricard.businessobjects.com
Have you tried to set your ConnectionLayer's router to a FanRouter, on which
you would have called setNextRouter(myShortestPathConnectionRouter)
beforehand ?
"Jeff" <pilgrim@us.ibm.com> wrote in message
news:8d5d999fd2a898450a32fe618b9c7730$1@www.eclipse.org...
Re: How does ShortestPath routing algorithm work? [message #219969 is a reply to message #219866] Mon, 24 July 2006 11:51 Go to previous messageGo to next message
I've retained the same call in my diagrameditpart as the logic example
uses:
protected void refreshVisuals() {
ConnectionLayer cLayer = (ConnectionLayer) getLayer(CONNECTION_LAYER);
cLayer.setAntialias(SWT.ON);
if
(getLogicDiagram().getConnectionRouter().equals(LogicDiagram .ROUTER_MANUAL))
AutomaticRouter router = new FanRouter();
router.setNextRouter(new BendpointConnectionRouter());
cLayer.setConnectionRouter(router);
} else if
(getLogicDiagram().getConnectionRouter().equals(LogicDiagram .ROUTER_MANHATTAN))
cLayer.setConnectionRouter(new ManhattanConnectionRouter());
else
ShortestPathConnectionRouter(getFigure()));
and I also tried:
if
(getProcessingElementCollectionDiagram().getConnectionRouter ().equals(ProcessingElementCollectionDiagram.ROUTER_MANUAL))
} else if
(getProcessingElementCollectionDiagram().getConnectionRouter ().equals(ProcessingElementCollectionDiagram.ROUTER_MANHATTA N))
else {
router.setNextRouter(new ShortestPathConnectionRouter(getFigure()));
both editparts have the same 'createFigure' method:
protected IFigure createFigure() {
Figure f = new FreeformLayer();
// f.setBorder(new GroupBoxBorder("Diagram"));
f.setLayoutManager(new FreeformLayout());
f.setBorder(new MarginBorder(5));
return f;
one thing I can think of that is different between my application and the
logic example is I'm using a triangle decorator on the connection lines.
Re: How does ShortestPath routing algorithm work? [message #220030 is a reply to message #219969] Tue, 25 July 2006 07:31 Go to previous messageGo to next message
Here is the code that is working for me. This code is in the root
EditPart's activate() method, after super.activate() call.
ScalableRootEditPart root =
(ScalableRootEditPart)getViewer().getRootEditPart();
ConnectionLayer connLayer =
(ConnectionLayer)root.getLayer(LayerConstants.CONNECTION_LAY ER);
GraphicalEditPart contentEditPart =
(GraphicalEditPart)root.getContents();
FanRouter router = new FanRouter();
router.setSeparation(20);
ShortestPathConnectionRouter spRouter = new
ShortestPathConnectionRouter(contentEditPart.getFigure());
router.setNextRouter(spRouter);
connLayer.setConnectionRouter(router);
If all else fails, step through your code. Make sure that the calls are
made correctly.
Sebu.
> uses:
> if
> } else if
> else
> and I also tried:
> if
> } else if
> else {
> return f;
> the logic example is I'm using a triangle decorator on the connection
> lines.
Re: How does ShortestPath routing algorithm work? [message #220203 is a reply to message #220030] Wed, 26 July 2006 10:31 Go to previous messageGo to next message
Yup, it definitely walks through the code. It will change from manhattan
to manual and vice versa too. I'll look in more depth at the figure used
to construct the sp router. It must be there somewhere since that's
really the difference between my app and the logic example. One
difference between my app and Sebu's post is that my editpart is a
ScalableFreeFormEditPart rather than a ScalableRootEditPart I notice.
Could that be not applicable to the shortest path router, its extra layer
for zooming be causing a problem? I'll check but I believe that to be the
same part in the logic example.
Thanks for the tips, will post back with what I find.
Re: How does ShortestPath routing algorithm work? [message #222045 is a reply to message #219797] Thu, 24 August 2006 11:37 Go to previous message
Still a concern... The preferred size of my editparts are 40x40.
Depending on how many editparts are on the canvas, their relative
placement, and how many connections exist, I do indeed see that some of
the connecting lines are segmented and drawn around the editpart's figure.
However, there are also lines which cross it. That doesn't seem to be
the case with the logic example - never see the lines cross the gates
there when the shortest path routing option is used. I've tried various
values of the router spacing including values of 5, 10, 60, and 120. The
first line between the parts always crosses. Could this be because of the
size of the figures, inherent to the routing algorithm?
Previous Topic:Selecting anchors (based on logic example)
Next Topic:Placing Decorations
Current Time: Wed Sep 17 00:44:07 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
