Home » Modeling » GMF (Graphical Modeling Framework) » copy paste issue
copy paste issue [message #219306] Thu, 19 February 2009 11:19 Go to next message
Originally posted by: jxtamarc.gmail.com
I'm trying to copy and paste single elements from a model into a new
model. Apparently it looks like it's done, since I can see a graphical
copy of that element, but if I try to save the diagram and open it back
it just disappears.
any ideas?? this is starting to drive me crazy. I haven't been able to
find any complete and clear example of a simple copy paste action on GMF.
Many people has already asked this issue on this list before me but it
seems like there aren't any convincing solution.
Please, help!
thank you!
Re: copy paste issue [message #219314 is a reply to message #219306] Thu, 19 February 2009 11:37 Go to previous messageGo to next message
I don't really know why that may be happening but as GMF copy & paste didn't
satisfy my requirements I chose to implement my own copy & paste. You can
see a presentation I made here:
http://www.moskitt.org/fileadmin/conselleria/documentacion/P resentaciones/MOSKitt-CopyPasteSupport.pdf
Don't send me an email to the email that is in the presentation because it's
no longer my email :-). The basics of the presentation is that I replaced
via extension points the classes that are executed when making copy & paste
by my classes. If you want to see the code you can download MOSKitt in
www.moskitt.org. It's in the plugin "es.cv.gvcase.mdt.common".
Mario
"markitus" <jxtamarc@gmail.com> escribi
Re: copy paste issue [message #219327 is a reply to message #219314] Thu, 19 February 2009 11:58 Go to previous messageGo to next message
Thanks Mario,
I'm going to take a look to the code right now. By the way, I already
came across with your presentation a few time ago and actually sent you
an email to the given address ;-), I'm not sure if you got to read it.
I'll take a look and let you know if it was of help.
Marc.
El dia Thu, 19 Feb 2009 17:37:02 +0100, en/na Mario Cervera va escriure:
> didn't satisfy my requirements I chose to implement my own copy & paste.
> You can see a presentation I made here:
Presentaciones/MOSKitt-CopyPasteSupport.pdf
> it's no longer my email :-). The basics of the presentation is that I
> replaced via extension points the classes that are executed when making
> copy & paste by my classes. If you want to see the code you can download
> MOSKitt in www.moskitt.org. It's in the plugin
> Regards
> Mario
> "markitus" <jxtamarc@gmail.com> escribió en el mensaje
> news:gnk0r1$ekk$1@build.eclipse.org...
>> Hi,
>> it just disappears.
>> GMF. Many people has already asked this issue on this list before me
>> but it seems like there aren't any convincing solution.
>> Please, help!
>> thank you!
Re: copy paste issue [message #219334 is a reply to message #219327] Thu, 19 February 2009 12:14 Go to previous messageGo to next message
I've just tried to download the code of Moskitt project, but it looks
like only the binaries are available. Is there any way to get source
files?
thank you!
El dia Thu, 19 Feb 2009 16:58:50 +0000, en/na markitus va escriure:
> Thanks Mario,
> Regards,
> Marc.
>> Hi,
>> paste. You can see a presentation I made here:
>> download MOSKitt in www.moskitt.org. It's in the plugin
>> Regards
>> Mario
>>> Hi,
>>> back it just disappears.
>>> Please, help!
>>> thank you!
Re: copy paste issue [message #219357 is a reply to message #219306] Thu, 19 February 2009 13:22 Go to previous messageGo to next message
Originally posted by: thomas.beyer81.t-online.de
Hi Markitus,
I really struggled a long time with cut, copy & paste, especially
pasting into compartments.
From what I can tell, GMF provides everything you need and implements a
very powerful framework around copy-paste. If you see all the related
classes, its a quiet complex job.
Marios approach might also work for your use-case, unfortunately I never
got it working for my editors.
There is just two little hints, I'd like to give you:
1. Make sure to use uuids for your semantic model as described in this
post:
http://serdom.eu/ser/2008/07/02/eclipse-gmf-enabling-uuids-i n-semantic-model-the-simplest-way
There are lots of others threats in this group, adressing exactly this
issue as well.
2. Fork the class NotationClipboardOperationHelper(in plugin
org.eclipse.gmf.runtime.notation.providers)
and modify the following methods:
a)
static EObject getSemanticPasteTarget(View view) {
View parent = (View) view.eContainer();
return parent.getElement();
b)
private boolean shouldAllowPaste(
PasteChildOperation overriddenChildPasteOperation) {
EObject eObject = overriddenChildPasteOperation.getEObject();
EObject parentEObject = overriddenChildPasteOperation
.getParentEObject();
//implement your logic here, that checks, if eObject is allowed zo be
can be pasted in the parentEObject
I got the clue from this page:
http://wiki.eclipse.org/GMF_Newsgroup_Q_and_A#How_to_make_co py.2Fpaste_work_on_compartments.3F
, which contains so many useful solutions!!!
Forking basically means, you import the plugin above from the eclipse
cvs base, modify the code and use your customized plugin for your
application, rcp or whatever. (just in case you struggle with the term,
like I used to)
Let me know, if you need any further help.
HTH
Thomas
markitus schrieb:
> it just disappears.
> Please, help!
> thank you!
Re: copy paste issue [message #219365 is a reply to message #219334] Fri, 20 February 2009 03:05 Go to previous messageGo to next message
You have to download it from the public repository (sorry I didn't mention
this before)
Re: copy paste issue [message #219373 is a reply to message #219365] Fri, 20 February 2009 03:06 Go to previous messageGo to next message
The url is http://www.moskitt.org/cas/repositorio/
"Mario Cervera" <mcervera@prodevelop.es> escribi
Re: copy paste issue [message #219538 is a reply to message #219357] Fri, 20 February 2009 08:40 Go to previous messageGo to next message
Hi Thomas,
Perhaps I misunderstood or I missed something. But wouldn't the result be
the same (or similar) if we extend AbstractClipboardSupport (which
implements IClipboardSupport) and rewrite these methods?
Anyway, I'm clearly confused, as you see.
My problem is not pasting into compartments , I didn't even get that far
yet :( . I've enabled the copy/Paste option so it shows up in the
contextual menu. I'm being able to copy or paste whatever elements I want
to(graphically), but when I try to make these changes persistent these
new copied elements simply disappear. Even if I add an original object
from the palette after a copy/paste action, the previously copied
elements disappear from the canvas. It is so weird!!
So I'm not sure if i have to rewrite anything since I'm not trying to do
anything special, just a simple copy paste action with simple elements
(not compartments).
Should I expect this to work straight, or should I rewrite some code ?
Thanks for your help.
Marc.
El dia Thu, 19 Feb 2009 19:22:49 +0100, en/na Thomas Beyer va escriure:
> Hi Markitus,
> There is just two little hints, I'd like to give you: 1. Make sure to
> use uuids for your semantic model as described in this post:
> issue as well.
> a)
> View parent = (View) view.eContainer(); return
> b)
zo be
GMF_Newsgroup_Q_and_A#How_to_make_copy.2Fpaste_work_on_compa rtments.3F
> like I used to)
> HTH
> Regards,
> Thomas
> markitus schrieb:
>> Hi,
>> it just disappears.
>> Please, help!
>> thank you!
Re: copy paste issue [message #219576 is a reply to message #219538] Fri, 20 February 2009 10:06 Go to previous messageGo to next message
Originally posted by: tobk42.gmx.de
Hello Marc,
it seems you have the same problem I had (and still have). The point
is, that the elements do not disappear after they have been copied, but
that only their views are copied, I guesss. To verify this, please
copy-paste an element and then modify it. If I'm right, the original
element will get changed, too.
However, this is not a solution to your problem (I wish it were, as then
my problem would be solved as well), but maybe it gives you some idea of
where to begin. For me, I tried a few days to solve it before I finally
gave up... :-(
Regards, and good luck,
Tobias
markitus schrieb:
> Hi Thomas,
> (not compartments).
> Marc.
>> Hi Markitus,
>> issue as well.
>> a)
>> b)
> zo be
>> like I used to)
>> HTH
>> Regards,
>> Thomas
>> markitus schrieb:
>>> Hi,
>>> it just disappears.
>>> Please, help!
>>> thank you!
Re: copy paste issue [message #219583 is a reply to message #219576] Fri, 20 February 2009 11:12 Go to previous messageGo to next message
Never give up, guys ;-)
So first of all:
Did you both make sure to use uuids for your semantic model as I
described earlier in step 1?
If so, copy paste should at least work for elements placed directly on
the canvas.
So you must add the following extension to your plugin-xml:
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser type="MY_SEMANTIC_MODEL_FILE_EXTENSION"
class=" org.eclipse.gmf.runtime.emf.core.resources.GMFResourceFactor y ">
</parser>
</extension>
Where MY_SEMANTIC_MODEL_FILE_EXTENSION seriously only is the
file-extension of your editor-files.
Step 2 was the solution to make copy/paste work in compartments
(container-elements).
Regards, Thomas
Am 20.02.2009 16:06, schrieb Tobias:
> Hello Marc,
> it seems you have the same problem I had (and still have). The point is,
> that the elements do not disappear after they have been copied, but that
> only their views are copied, I guesss. To verify this, please copy-paste
> an element and then modify it. If I'm right, the original element will
> get changed, too.
> gave up... :-(
> Tobias
> markitus schrieb:
>> Hi Thomas,
>> be the same (or similar) if we extend AbstractClipboardSupport (which
>> far yet :( . I've enabled the copy/Paste option so it shows up in the
>> want to(graphically), but when I try to make these changes persistent
>> these new copied elements simply disappear. Even if I add an original
>> object from the palette after a copy/paste action, the previously
>> copied elements disappear from the canvas. It is so weird!!
>> do anything special, just a simple copy paste action with simple
>> elements (not compartments).
>> Marc.
>>> Hi Markitus,
>>> issue as well.
>>> a)
>>> b)
>> zo be
>>> like I used to)
>>> HTH
>>> Regards,
>>> Thomas
>>> markitus schrieb:
>>>> Hi,
>>>> it just disappears.
>>>> Please, help!
>>>> thank you!
Re: copy paste issue [message #219706 is a reply to message #219583] Mon, 23 February 2009 04:54 Go to previous messageGo to next message
Hi Thomas,
I did exactly as you said (step 1). Actually it was already done before I
started trying to copy paste. I'm getting the same errors as Tobias. If I
change smth in the new copied element, whatever change I do on this new
element, is reflected on the original too. So there must be some base
errors that leads us to this behavior.
I can't understand why it's behaving like this, and for sure I don't want
to give up ( I can't ), but it's really starting to be quite
discouraging. It seems so obvious that it should SIMPLY work...
good to know, Tobias, that I'm not alone in this fight!
El dia Fri, 20 Feb 2009 17:12:12 +0100, en/na Thomas Beyer va escriure:
> So first of all:
> the canvas.
> So you must add the following extension to your plugin-xml: <extension
> </parser>
> </extension>
> Regards, Thomas
>> Hello Marc,
>> then my problem would be solved as well), but maybe it gives you some
>> idea of where to begin. For me, I tried a few days to solve it before I
>> finally gave up... :-(
>> Tobias
>> markitus schrieb:
>>> Hi Thomas,
>>> implements IClipboardSupport) and rewrite these methods? Anyway, I'm
>>> clearly confused, as you see. My problem is not pasting into
>>> compartments , I didn't even get that far yet :( . I've enabled the
>>> copy/Paste option so it shows up in the contextual menu. I'm being
>>> able to copy or paste whatever elements I want to(graphically), but
>>> when I try to make these changes persistent these new copied elements
>>> simply disappear. Even if I add an original object from the palette
>>> after a copy/paste action, the previously copied elements disappear
>>> Marc.
>>> escriure:
>>>> Hi Markitus,
>>>> a very powerful framework around copy-paste. If you see all the
>>>> related classes, its a quiet complex job.
>>>> never got it working for my editors.
semantic-
>>>> this issue as well.
>>>> org.eclipse.gmf.runtime.notation.providers) and modify the following
>>>> methods:
>>>> a)
>>>> static EObject getSemanticPasteTarget(View view) { View parent =
>>>> b)
>>>> PasteChildOperation overriddenChildPasteOperation) { EObject eObject
>>>> = overriddenChildPasteOperation.getEObject(); EObject parentEObject =
>>>> overriddenChildPasteOperation .getParentEObject();
>>> zo be
>>>> term, like I used to)
>>>> HTH
>>>> Regards,
>>>> Thomas
>>>> markitus schrieb:
>>>>> Hi,
>>>>> graphical copy of that element, but if I try to save the diagram and
>>>>> open it back it just disappears.
>>>>> to find any complete and clear example of a simple copy paste action
>>>>> on GMF. Many people has already asked this issue on this list before
>>>>> me but it seems like there aren't any convincing solution.
>>>>> Please, help!
>>>>> thank you!
Re: copy paste issue [message #219772 is a reply to message #219706] Mon, 23 February 2009 12:58 Go to previous messageGo to next message
Hello Markitus,
the behaviour you describe sounds to me like you are using shortcuts,
not real copies of elements.
How do you create your copy?
Select -> <Ctrl> + <C> -> <Ctrl> + <V> ?
Regards Thomas
markitus schrieb:
> Hi Thomas,
>> So first of all:
>> the canvas.
>> </parser>
>> </extension>
>> Regards, Thomas
>>> Hello Marc,
>>> Tobias
>>> markitus schrieb:
>>>> Hi Thomas,
>>>> Marc.
>>>> escriure:
>>>>> Hi Markitus,
> semantic-
>>>>> this issue as well.
>>>>> methods:
>>>>> a)
>>>>> b)
>>>> zo be
>>>>> HTH
>>>>> Regards,
>>>>> Thomas
>>>>> markitus schrieb:
>>>>>> Hi,
>>>>>> Please, help!
>>>>>> thank you!
Re: copy paste issue [message #219796 is a reply to message #219772] Tue, 24 February 2009 03:28 Go to previous messageGo to next message
Hi Thomas,
I create a copy through the context menu (right-click on selected element
(s)), then copy/cut and paste. Easy, straightforward. Actually, it
doesn't work at all if I try with shortcuts.
Weird weird weird. I guess it has something to do with the original
creation of the ecore. The thing is that the development of this app
started around 2 years ago, and perhaps it's a bit too late to start back
again from scratch.
thanks for your help.
REGARDS,
Marc.
El dia Mon, 23 Feb 2009 18:58:35 +0100, en/na Thomas Beyer va escriure:
> Hello Markitus,
> Regards Thomas
> markitus schrieb:
>> Hi Thomas,
>> I started trying to copy paste. I'm getting the same errors as Tobias.
>> If I change smth in the new copied element, whatever change I do on
>> this new element, is reflected on the original too. So there must be
>> some base errors that leads us to this behavior.
>> want to give up ( I can't ), but it's really starting to be quite
>>> So first of all:
>>> the canvas.
>>> </parser>
>>> </extension>
>>> Regards, Thomas
>>>> Hello Marc,
>>>> but that only their views are copied, I guesss. To verify this,
>>>> please copy-paste an element and then modify it. If I'm right, the
>>>> original element will get changed, too.
>>>> I finally gave up... :-(
>>>> Tobias
>>>> markitus schrieb:
>>>>> Hi Thomas,
>>>>> result be the same (or similar) if we extend
>>>>> AbstractClipboardSupport (which implements IClipboardSupport) and
>>>>> rewrite these methods? Anyway, I'm clearly confused, as you see. My
>>>>> the contextual menu. I'm being able to copy or paste whatever
>>>>> elements I want to(graphically), but when I try to make these
>>>>> changes persistent these new copied elements simply disappear. Even
>>>>> if I add an original object from the palette after a copy/paste
>>>>> action, the previously copied elements disappear from the canvas. It
>>>>> is so weird!!
>>>>> to do anything special, just a simple copy paste action with simple
>>>>> Marc.
>>>>> escriure:
>>>>>> Hi Markitus,
>>>>>> implements a very powerful framework around copy-paste. If you see
>>>>>> all the related classes, its a quiet complex job. Marios approach
>>>>>> might also work for your use-case, unfortunately I never got it
>>>>>> to use uuids for your semantic model as described in this post:
>> semantic-
>>>>>> this issue as well.
>>>>>> following methods:
>>>>>> a)
>>>>>> b)
>>>>>> eObject = overriddenChildPasteOperation.getEObject(); EObject
>>>>>> parentEObject = overriddenChildPasteOperation .getParentEObject();
>>>>> zo be
>>>>>> eclipse cvs base, modify the code and use your customized plugin
>>>>>> for your application, rcp or whatever. (just in case you struggle
>>>>>> with the term, like I used to)
>>>>>> HTH
>>>>>> Regards,
>>>>>> Thomas
>>>>>> markitus schrieb:
>>>>>>> Hi,
>>>>>>> new model. Apparently it looks like it's done, since I can see a
>>>>>>> and open it back it just disappears.
>>>>>>> able to find any complete and clear example of a simple copy paste
>>>>>>> action on GMF. Many people has already asked this issue on this
>>>>>>> list before me but it seems like there aren't any convincing
>>>>>>> solution.
>>>>>>> Please, help!
>>>>>>> thank you!
Re: copy paste issue [message #226856 is a reply to message #219796] Tue, 21 April 2009 10:00 Go to previous messageGo to next message
Originally posted by: awacs.batacs.de
Hi Marc,
unfortunately I ran into the same problems, recently. Copy/paste
basically works - meaning I am able to copy compartments and components
from one compartment to another (visually). If I modify properties of
the copied component/compartment, the source-component/compartment is
changed too. After reopening the diagram file, all copied elements
disappeared, although they are still visible in the generated xmi-file.
I am already using uuids.
Did you already manage to get copy/paste working? Any hints?
Thanks in advance,
Daniel
markitus wrote:
> Hi Thomas,
> again from scratch.
> REGARDS,
> Marc.
>> Hello Markitus,
>> Regards Thomas
>> markitus schrieb:
>>> Hi Thomas,
>>>> So first of all:
>>>> the canvas.
>>>> </parser>
>>>> </extension>
>>>> Regards, Thomas
>>>>> Hello Marc,
>>>>> Tobias
>>>>> markitus schrieb:
>>>>>> Hi Thomas,
>>>>>> is so weird!!
>>>>>> Marc.
>>>>>> escriure:
>>>>>>> Hi Markitus,
>>> semantic-
>>>>>>> this issue as well.
>>>>>>> following methods:
>>>>>>> a)
>>>>>>> b)
>>>>>> zo be
>>>>>>> HTH
>>>>>>> Regards,
>>>>>>> Thomas
>>>>>>> markitus schrieb:
>>>>>>>> Hi,
>>>>>>>> solution.
>>>>>>>> Please, help!
>>>>>>>> thank you!
Re: copy paste issue [message #226975 is a reply to message #226856] Wed, 22 April 2009 06:53 Go to previous message
El dia Tue, 21 Apr 2009 16:00:10 +0200, en/na Daniel va escriure:
> Hi Marc,
> Thanks in advance,
> Daniel
> markitus wrote:
>> Hi Thomas,
>> element (s)), then copy/cut and paste. Easy, straightforward. Actually,
>> it doesn't work at all if I try with shortcuts.
>> back again from scratch.
>> REGARDS,
>> Marc.
>>> Hello Markitus,
>>> Regards Thomas
>>> markitus schrieb:
>>>> Hi Thomas,
>>>> before I started trying to copy paste. I'm getting the same errors as
>>>> Tobias. If I change smth in the new copied element, whatever change I
>>>> do on this new element, is reflected on the original too. So there
>>>> must be some base errors that leads us to this behavior.
>>>> escriure:
>>>>> So first of all:
>>>>> on the canvas.
>>>>> </parser>
>>>>> </extension>
>>>>> Regards, Thomas
>>>>>> Hello Marc,
>>>>>> point is, that the elements do not disappear after they have been
>>>>>> copied, but that only their views are copied, I guesss. To verify
>>>>>> this, please copy-paste an element and then modify it. If I'm
>>>>>> right, the original element will get changed, too.
>>>>>> some idea of where to begin. For me, I tried a few days to solve it
>>>>>> before I finally gave up... :-(
>>>>>> Tobias
>>>>>> markitus schrieb:
>>>>>>> Hi Thomas,
>>>>>>> that far yet :( . I've enabled the copy/Paste option so it shows
>>>>>>> up in the contextual menu. I'm being able to copy or paste
>>>>>>> whatever elements I want to(graphically), but when I try to make
>>>>>>> these changes persistent these new copied elements simply
>>>>>>> disappear. Even if I add an original object from the palette after
>>>>>>> a copy/paste action, the previously copied elements disappear from
>>>>>>> simple elements (not compartments).
>>>>>>> code ?
>>>>>>> Marc.
>>>>>>> escriure:
>>>>>>>> Hi Markitus,
>>>>>>>> see all the related classes, its a quiet complex job. Marios
>>>>>>>> post:
>>>> semantic-
>>>>>>>> this issue as well.
>>>>>>>> following methods:
>>>>>>>> a)
>>>>>>>> b)
>>>>>>>> .getParentEObject(); //implement your logic here, that checks, if
>>>>>>>> eObject is allowed
>>>>>>> zo be
>>>>>>>> HTH
>>>>>>>> Regards,
>>>>>>>> Thomas
>>>>>>>> markitus schrieb:
>>>>>>>>> Hi,
>>>>>>>>> paste action on GMF. Many people has already asked this issue on
>>>>>>>>> this list before me but it seems like there aren't any
>>>>>>>>> Please, help!
>>>>>>>>> thank you!
Hi Daniel,
I'm afraid I don't have good news for you. I just gave it up. I didn't
get any closer, I tried to update all the emf/gmf plugins but it didn't
work out after all. I'm sorry.
I'm just back here to find a solution but it looks like i was the last
one asking about this. I spent a great amount of time attempting to
copy / paste but I didn't even take a single step forward. I don't want
to discourage you but I wouldn't waste much time with this.
anyway, good luck!! and of course, if you manage to solve it, tell me
how! ;)
cheers,
marc.
Previous Topic:Scrolling Compartment EditParts using Mouse Wheel
Next Topic:save as
Current Time: Sun Jul 27 12:55:32 EDT 2025
Powered by FUDForum. Page generated in 0.06642 seconds
