Home » Language IDEs » C / C++ IDE (CDT) » An error has occurred when creating this editor
An error has occurred when creating this editor [message #21921] Mon, 18 March 2002 08:44 Go to next message
Originally posted by: mwisse.hs-harz.de
Hallo!
I try to use
cdt-eclipse-R2-0125-20020308
with
eclipse-SDK-20020214-linux-motif .
I created a first C/C++ project for testing with the wizard and imported
some files. When I try to view a .c or a .h file, I get following error:
"An error has occurred when creating this editor".
What can I do?
Best regards and thanks for assistance.
Michael
Re: An error has occurred when creating this editor [message #21967 is a reply to message #21921] Mon, 18 March 2002 10:22 Go to previous messageGo to next message
Hi Michael,
I've tried this out with the drivers you mentioned but was unable to
reproduce.
Could you provide more details? There's a file that logs errors such as
this - you can find it in the "eclipse/workspace/.metadata" directory.
Could you post the log output?
Dave
Michael Wisse wrote:
> Hallo!
> I try to use
> with
> What can I do?
> Michael
Re: An error has occurred when creating this editor [message #22013 is a reply to message #21967] Mon, 18 March 2002 11:53 Go to previous messageGo to next message
Hello Dave!
Here is the content of .log:
Log: Mon Mar 18 14:35:00 CET 2002
2 org.eclipse.ui 2 Problems occurred when invoking code from plug-in:
org.eclipse.ui.
java.lang.NoSuchMethodError
at
com.ibm.lpex.alef.LpexSourceViewer.configure(LpexSourceViewe r.java:329)
at
com.ibm.lpex.alef.LpexAbstractTextEditor.createPartControl(L pexAbstractTextEditor.java:786)
at
org.eclipse.cdt.cpp.ui.internal.editor.CppEditor.createPartC ontrol(CppEditor.java:87)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:58)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:817)
at org.eclipse.core.runtime.Platform.run(Platform.java:395)
at
org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:56)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :98)
at
org.eclipse.ui.internal.EditorWorkbook.createPage(EditorWork book.java:214)
at
org.eclipse.ui.internal.EditorWorkbook.createControl(EditorW orkbook.java:179)
at
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:174)
at
at
org.eclipse.ui.internal.PerspectivePresentation.activate(Per spectivePresentation.java:88)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:552)
at
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1069)
at
org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:919)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:56)
at
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:907)
at
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:820)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:746)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:504)
at
at
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:489)
at org.eclipse.ui.internal.Workbench.openWindows(Workbench.java :539)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:389)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:768)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:777)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:319)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:151)
at org.eclipse.core.launcher.Main.run(Main.java:502)
at org.eclipse.core.launcher.Main.main(Main.java:362)
Log: Mon Mar 18 14:35:02 CET 2002
org.eclipse.ui.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Log: Mon Mar 18 14:35:05 CET 2002
org.eclipse.ui.
at
com.ibm.lpex.alef.LpexContextContributor.setActiveEditor(Lpe xContextContributor.java:247)
at
org.eclipse.cdt.cpp.ui.internal.editor.contributor.CppEditor ContextContributor.setActiveEditor(CppEditorContextContribut or.java:69)
at
org.eclipse.ui.internal.EditorActionBars.partChanged(EditorA ctionBars.java:88)
at org.eclipse.ui.internal.WorkbenchPage$1.run(WorkbenchPage.ja va:121)
at
at
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:113)
at
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1073)
at
at
at
at
at
at
at
Michael
David McKnight wrote:
> Hi Michael,
> reproduce.
> Dave
> > Hallo!
> > I try to use
> > with
> > What can I do?
> > Michael
Re: An error has occurred when creating this editor [message #22057 is a reply to message #21921] Mon, 18 March 2002 13:26 Go to previous messageGo to next message
Michael,
For eclipse-SDK-20020214 you must use cdt-eclipse-R2-0214-20020308. Some
Eclipse editor interfaces changed between Eclipse build 20020125 and build
20020214...
> Hallo!
> I try to use
> with
> What can I do?
> Michael
Re: An error has occurred when creating this editor [message #22274 is a reply to message #21921] Tue, 19 March 2002 03:01 Go to previous messageGo to next message
Hello Adrian!
You are right, I used the wrong sdk. I changed to eclipse R2-0125, but I
have the same problem, that the editor can not be created.
Now I want to try a newer jdk, I use 1.3.0.
I already tried to use eclipse R1.0, but I am not able to start it:
"memory access error". Perhaps it is a problem of the jdk.
Michael
> Hallo!
> I try to use
> with
> What can I do?
> Michael
Re: An error has occurred when creating this editor [message #22308 is a reply to message #22274] Tue, 19 March 2002 09:38 Go to previous messageGo to next message
I haven't looked into the jre and editor problems you mention here, but I'd
recommend staying with the 20020214 Eclipse driver. Use the 20020214 CDT
driver, rather than going back a level.
Dave
> Hello Adrian!
> Michael
> > Hallo!
> > I try to use
> > with
> > What can I do?
> > Michael
Re: An error has occurred when creating this editor [message #22336 is a reply to message #22274] Tue, 19 March 2002 11:13 Go to previous messageGo to next message
Hi Michael,
It sounds like you have installed and re-installed incompatible versions of
the CDT and Eclipse. Therefore, it is not clear what you currently have
installed and why you are getting the errors. To help us diagnose the
problem, can you do the following to make sure you have a "clean"
installation:
1. Remove your current eclipse\cdt installation (if possible).
2. Install the eclipse-SDK-20020214-linux-motif.zip Stable Eclipse Build.
3. Then install the cdt-eclipse-R2-0214-20020308.zip Stable CDT Build.
If you still get the same errors, can you let us know the following:
1. What Linux Distribution\Level you are running.
2. Provide a copy of your workspace/.metadata/.log file
3. Provide the steps that you went through to produce the problem.
Thanks alot...
Jeff Turnham
"Michael Wisse" <mwisse@hs-harz.de> wrote in message
news:3C96F043.2178FB8E@hs-harz.de...
> Hello Adrian!
> Michael
> > Hallo!
> > I try to use
> > with
> > What can I do?
> > Michael
Re: An error has occurred when creating this editor [message #22492 is a reply to message #22274] Thu, 21 March 2002 02:38 Go to previous message
Now it works, with jdk 1.3.0, too. I was confused with the versions.
Thanks for assistance.
What jdk do you recommend?
Michael
> Hello Adrian!
> Michael
> > Hallo!
> > I try to use
> > with
> > What can I do?
> > Michael
Previous Topic:CDT as top level project
Next Topic:IDocument.replace(...) don't work with lpex
Current Time: Sat Nov 08 12:49:21 EST 2025
Powered by FUDForum. Page generated in 0.03992 seconds
