Home » Archived » IAM (Eclipse Integration for Apache Maven) » eclipse 3.5 iam 0.10.0 No providers found matching selection: default
eclipse 3.5 iam 0.10.0 No providers found matching selection: default [message #21889] Thu, 16 July 2009 17:55 Go to next message
Has anyone encountered the error shown below?
Googling the error turned up http://jira.codehaus.org/browse/MGROOVY-170
Any ideas?
Brian
Re: eclipse 3.5 iam 0.10.0 No providers found matching selection: default [message #21934 is a reply to message #21889] Thu, 16 July 2009 18:24 Go to previous messageGo to next message
The problem seems to be some interaction with the <build> element
contained in the parent pom.xml. I deleted this <build> element and the
problem went away.
<build>
<plugins>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-release-plugin</artifactId>
<configuration>
<tagBase>http://blanked-for-public-post</tagBase>
</configuration>
</plugin>
<plugin>
<artifactId>maven-jar-plugin</artifactId>
<version>2.2-APCS</version>
</plugin>
<plugin>
<groupId>org.codehaus.mojo.groovy</groupId>
<artifactId>groovy-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>generateStubs</goal>
<goal>compile</goal>
<goal>generateTestStubs</goal>
<goal>testCompile</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
Brian
Re: eclipse 3.5 iam 0.10.0 No providers found matching selection: default [message #21978 is a reply to message #21934] Mon, 20 July 2009 14:36 Go to previous message
By reading http://jira.codehaus.org/browse/MGROOVY-170, it looks like an
incompatibility between the groovy plugin and the
plexus-container-default bundled with the maven embedder in IAM.
As the work on the new maven embedder stabilizes (as part of maven 3.0),
we might get a fix for this by bundling a new embedder.
> problem went away.
> <build>
> <plugins>
> <plugin>
> <configuration>
> </configuration>
> </plugin>
> <plugin>
> </plugin>
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> </plugin>
> </plugins>
> </build>
> Brian
Re: eclipse 3.5 iam 0.10.0 No providers found matching selection: default [message #570267 is a reply to message #21889] Thu, 16 July 2009 18:24 Go to previous message
problem went away.
<build>
<plugins>
<plugin>
<configuration>
</configuration>
</plugin>
<plugin>
</plugin>
<plugin>
<executions>
<execution>
<goals>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
Brian
Re: eclipse 3.5 iam 0.10.0 No providers found matching selection: default [message #570281 is a reply to message #21934] Mon, 20 July 2009 14:36 Go to previous message
> problem went away.
> <build>
> <plugins>
> <plugin>
> <configuration>
> </configuration>
> </plugin>
> <plugin>
> </plugin>
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> </plugin>
> </plugins>
> </build>
> Brian
Previous Topic:eclipse 3.5 iam 0.10.0 No providers found matching selection: default
Next Topic:IAM Installed but not active on galileo?
Current Time: Fri Nov 07 00:47:43 EST 2025
Powered by FUDForum. Page generated in 0.03610 seconds
