drag & drop & SnapToHelper [message #219086] |
Fri, 07 July 2006 05:08  |
I've got a main diagram that have several NodeContainer, then a Node with
labels inside the container.
I can drag & drop every node everywhere in the diagram and labels and the
rectangle of the NodeContainer is updated each time.
Only problem, is that i got a SnapToHelper on the Diagram, and i'd like to
use it, but only for the Nodes, not for the containers and labels.
to drag & drop the nodes, i use :
public DragTracker getDragTracker(Request request) {
return new NodeTracker(this, this.getParent());
this = NodePart, and this.getParent() = NodeContainerPart
then :
public class NodeTracker extends DragEditPartsTracker {
EditPart part;
public NodeTracker(EditPart sourceEditPart, EditPart part) {
super(sourceEditPart);
this.part = part;
protected EditPart getTargetEditPart() {
return part;
With that, i can drag & drop and it works well.. but it doesn't use the
SnapToHelper at all as there's none defined in the NodeContainer.
if i use NodeTracker(this, this.getParent().getParent()); then it uses the
SnapToHelper of the diagram... but i can't drag & drop my Node.
After checked the code of DragEditPartsTracker, the easiest thing would be
to be able to set the SnapToHelper used for the drag & drop.. but there's no
getter/setter for this.
It would be for example:
EditPart part;
this.part = part;
setSnapToHelper(part.getParent().getAdapter(SnapToHelper.cla ss));
return part;
Is there any way to use the SnapToHelper only for one component that is
inside another figure?
I use SnapToGeometry & SnapToGrid
Nicolas
Re: drag & drop & SnapToHelper [message #219120 is a reply to message #219086] |
Fri, 07 July 2006 09:14   |
Could you create a SnapToHelper that looks at the request, and does nothing
in certain situations? The problem might be when you have multiple objects
selected, and some are supposed to snap, and other aren't. Another
possibility is that you could prevent targeting. If you can't drop a node in
the diagram, but only in containers, then the diagram should not identify
itself as the target for dragging nodes.
"Nicolas Rousseau" <nicolasrousseau@hotmail.com> wrote in message
news:e8l8cp$h9q$1@utils.eclipse.org...
> then :
> EditPart part;
> this.part = part;
> return part;
> no getter/setter for this.
> EditPart part;
> this.part = part;
> return part;
> Nicolas
Re: drag & drop & SnapToHelper [message #219128 is a reply to message #219120] |
Fri, 07 July 2006 09:52  |
I've finally found something that works, but it looks a little strange...
The children of my diagram are now the containers + the nodes, and the node
is also a children of the container.
So now when i move a label which is inside the container, it doesn't use the
SnapToHelper,
and when i move the the node, it uses the SnapToHelper of the diagram.
That's strange, but it works at least...
"Randy Hudson" <none@us.ibm.com> a
FUDForum. Page generated in 0.04016 seconds
