Home » Language IDEs » ServerTools (WTP) » Converting non-WTP projects to WTP
Converting non-WTP projects to WTP [message #218583] Fri, 01 August 2008 13:08 Go to next message
Originally posted by: joe.kauzlarich.expeditors.com
I am on Eclipse 3.4 using WTP 1.2
I have an older tapestry project in CVS that I'd like to run under WTP
using the Servers view. When I check it out of CVS, it is not recognized
as a web project and I can't find a switch that will make this project run
under WTP. My only workaround is to create a new web project and import
the .war built by the old project, but what I really want is just to
enable WTP for the old project.. any ideas?
Thanks!
Joe K
Re: Converting non-WTP projects to WTP [message #218685 is a reply to message #218583] Mon, 04 August 2008 00:28 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Joe K wrote:
> Hello,
> run under WTP. My only workaround is to create a new web project and
> import the .war built by the old project, but what I really want is just
> to enable WTP for the old project.. any ideas?
If it is coming in as a Java Project, then on the Project menu, there
should be an option to Convert to Dynamic Web Project.
Dave
Re: Converting non-WTP projects to WTP [message #218831 is a reply to message #218685] Mon, 04 August 2008 13:56 Go to previous messageGo to next message
I recall something like that in earlier versions of eclipse, but there is
nothing like that in 3.4 w/ the latest WTP. If you right-click on the
project name in package-explorer, there is no option, nor is there an
option anywhere in the project properties settings. If you're working on
the WTP project, you might check this out, as I think it could be
considered an oversight on the designer's part.
(As far as I know, the only way to create a web project is when creating a
new project from scratch. You might also be able to create a project and
import the old project, but then you have complications with CVS.)
Thanks!
Joe
Re: Converting non-WTP projects to WTP [message #218868 is a reply to message #218831] Mon, 04 August 2008 16:09 Go to previous messageGo to next message
I think you are getting bit by the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168538
There is a work around posted in that bug.
Dave
> is nothing like that in 3.4 w/ the latest WTP. If you right-click on the
> a new project from scratch. You might also be able to create a project
> and import the old project, but then you have complications with CVS.)
> Thanks!
> Joe
Re: Converting non-WTP projects to WTP [message #218882 is a reply to message #218868] Mon, 04 August 2008 19:06 Go to previous message
David,
Thanks, this pointed me in the right direction, but it's not a foolproof
workaround as WTP seemed unable to generate the needed files in the
settings directory (I noticed exceptions being thrown internally) in
order for the publish to work. Eventually, I copied and modified the
settings/org.eclipse.wst.common.component file from a different project
and it now seems to work fine.
Thanks again for your responses!
Joe
Previous Topic:Suppress XML Grammar warning
Next Topic:custom build.xml + jetty
Current Time: Fri Jul 25 22:54:45 EDT 2025
Powered by FUDForum. Page generated in 0.17362 seconds
