Home » Eclipse Projects » GEF » Can't delete certain EditParts from the model
Can't delete certain EditParts from the model [message #218490] |
Mon, 26 June 2006 12:39  |
Originally posted by: gui.le.conquerant.com
Hiya group,
I got my hands on an internal EMF/GEF project. It appears that, on the
graphical editor, the Delete action (right click - Delete) does not
appear on some figures.
Quite surprisingly, 'Delete' only appears on figures that are at the
root of the model (i.e.: drag & dropped on a blank worspace).
Anyone has got any lead in order for me to find the solution?
Thank you much.
Re: Can't delete certain EditParts from the model [message #218506 is a reply to message #218490] |
Mon, 26 June 2006 14:46   |
Originally posted by: lamont_gilbert.rigidsoftware.com
Gui wrote:
> Hiya group,
> Thank you much.
I believe there is a delete request sent to the edit part. If the part does
not respond with a command that can delete it, then the part is essentially
un-deleteable.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into the
sheepfold{}, but climbeth up some other *way, the same is a thief and a
robber."
Re: Can't delete certain EditParts from the model [message #218581 is a reply to message #218573] |
Tue, 27 June 2006 07:43   |
Same thing. Have you set a breakpoint in your editparts delete request
handling method? If so, is it being called?
I think the delete request goes to the parent first. If the parent does not
forward it onto its children, or does not formulate a delete command for
the child, then they won't see it and no delete command will be generated.
CL
Gui wrote:
> CL,
> Thank you for the answer.
> As I said, the EditParts are capable of handling the delete request
> since you can delete them when dropped on a blank workspace.
> What would not trigger the delete menu when figures are nested?
> Thanks!
> CL [dnoyeb] Gilbert a écrit :
>> Gui wrote:
>>> Hiya group,
>>> Thank you much.
>> does not respond with a command that can delete it, then the part is
>> essentially un-deleteable.
Respectfully,
CL Gilbert
robber."
Re: Can't delete certain EditParts from the model [message #218635 is a reply to message #218581] |
Tue, 27 June 2006 13:12  |
All right, thanks I figured out where the problem came from.
I had a flag which, by default, disallows an EditPart to be deleted. Odd!
Many thanks for you help!
> CL
> Gui wrote:
>> CL,
>> Thanks!
>>> Gui wrote:
>>>> Hiya group,
>>>> Thank you much.
Current Time: Sat Jul 26 03:18:56 EDT 2025
Powered by FUDForum. Page generated in 0.06905 seconds
