Home » Eclipse Projects » GEF » Problems with routing of connection for nested nodes
Problems with routing of connection for nested nodes [message #218566] Tue, 27 June 2006 04:47 Go to next message
Originally posted by: ivica.a.gmx.de
Hello!
I am visualising a nested graph structure using GEF.
In order to avoid overlapping between connections and nodes I use the
ShortestPathConnectionRouter which is configured in the DiagramEditPart.
DiagramEditPart is the root of my model.
Figure f = new FreeformLayer();
f.setLayoutManager(new FreeformLayout());
ConnectionLayer connLayer =
(ConnectionLayer)getLayer(LayerConstants.CONNECTION_LAYER);
ConnectionRouter router = new ShortestPathConnectionRouter(f);
connLayer.setConnectionRouter(router);
The routing works fine between the top-level children of the diagram.
However, routing between nodes which are nested in a composite does not
work. Only straight lines are drawn.
As far as I was able to analyse it, the problem seems to be that for all
nesting structures only one connection layer exists. As soon as I nest
elements into a composite the effect for the routing algorithm is like
these nodes do not exist anymore.
Did I miss something here? What are the consideration which should be
made if I want my routing to work for nested structures? I hope someone
can give me a hint.
Thank you in advance!
Ivica Aracic
Re: Problems with routing of connection for nested nodes [message #218643 is a reply to message #218566] Tue, 27 June 2006 13:53 Go to previous message
CC yourself to:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=135086
This will be on the proposed list for 3.2
-Steve
"Ivica Aracic" <ivica.a@gmx.de> wrote in message
news:e7qra9$hsj$1@utils.eclipse.org...
> Hello!
> can give me a hint.
> Ivica Aracic
Previous Topic:Can't delete certain EditParts from the model
Next Topic:scrolling in a graphical Editor
Current Time: Tue Oct 28 21:22:32 EDT 2025
Powered by FUDForum. Page generated in 0.03125 seconds
