Home » Eclipse Projects » GEF » "One model - many edit parts" problem!
"One model - many edit parts" problem! [message #218444] |
Sat, 24 June 2006 08:21  |
Hi all,
Maybe this problem has been discused before but I just could not find the
solution of my problem in the previous newsgroup posts and in
bugs.eclipse.org...
I have a class called VariablesHolder with tree method getInVariables(),
getOutVariables(), and getInOutVariables().
The edit part for the VariablesHolder is called VariablesHolderEditPart.
The method getModelChildren() of the VariablesHolderEditPart looks like
this:
protected List getModelChildren() {
List list = new ArrayList();
list.addAll(getHolder().getInVariables());
list.addAll(getHolder().getOutVariables());
list.addAll(getHolder().getInOutVariables();
return list;
Every variable is presented with an edit part. And everything works fine.
I encountered a problem when I tried to present the inout variables with
two edit part. So every inout variable must have two edit parts.
It should be possible to achive such functionality.
So to create two edit parts I looked in the
AbstractEditPart::refreshChildren and decide to override this method so
that when I encounter an inout variable I will create two edit parts.
But then I noticed the following sentence in the documentation of the
method:
"* This method should <em>not</em> be overridden."
So my question is how can I achive the functionality of "one model may
parts" when I should not override this method?
Ofcourse the documentation of the method do not stop me from overriding
it, but is there a way to solve my problem without overriding the
refrehsChildren method?
And if I am to override refreshChildren() what consequence should I
expect? Anything special?
Thank you in advance...
Re: "One model - many edit parts" problem! [message #218460 is a reply to message #218444] |
Sun, 25 June 2006 09:40   |
Originally posted by: lamont_gilbert.rigidsoftware.com
kiril mitov wrote:
> Hi all,
> bugs.eclipse.org...
> this:
> return list;
> method:
What are you trying to achieve by having 2 edit parts use 1 model within the
same parent edit part? Perhaps there is another, better way to achieve
this.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into the
sheepfold{}, but climbeth up some other *way, the same is a thief and a
robber."
Re: "One model - many edit parts" problem! [message #218475 is a reply to message #218460] |
Mon, 26 June 2006 05:40   |
Thanks for the reply Gilbert...
Whell, as I said I have in, out, and inout variables.
A variable of type IN is represented by one edit part that shows some
information for the variable. The same applies for an OUT variable.
But an INOUT variable must be represented with two edit parts - one that
shows the "in" information for the inout variable and one that shows the
"out" information for the inout variable.
From my point of view, and for the editor I am developing, It will be very
I mean very user friednly to use two edit parts for the same model and
this parts to be in the same parent.
So, for this custom case I am sure that having "one model - many edit
parts" is a very good solution...
CL [dnoyeb] Gilbert wrote:
> kiril mitov wrote:
>> Hi all,
>> bugs.eclipse.org...
>> this:
>> return list;
>> method:
> this.
Re: "One model - many edit parts" problem! [message #218515 is a reply to message #218475] |
Mon, 26 June 2006 14:58   |
The most GEF centric way would be to return a single edit part, and that
edit part will have two children. One child will be the in and one will be
the out. The single edit part you return can have a free form figure just
like the other containers often do. So it is not seen but its two children
are.
You really can not have two edit parts with the same model since that is not
gefs architecture. There is a map that maps models to edit parts and it
would not work well if you did that.
The other alternative is to create two mini models for each in-out model.
One representing in and one representing out. So when the parent is asked
for all children, you return the ins and outs, and then these sub/mini
models. Which can be simple wrappers around the actual model with an added
method
class InModel implements MainModel {
public boolean isIn(){ return true;}
class OutModel implements MainModel {
public boolean isIn(){return false;}
Its probably adviseable to hold onto the instances and return the same ones
each time else GEF may dump and recreate the editparts when it does not
need to.
The models you give to your views do not have to match exactly your true
models.
CL
>> kiril mitov wrote:
>>> Hi all,
>>> the solution of my problem in the previous newsgroup posts and in
>>> bugs.eclipse.org...
>>> this:
>>> return list;
>>> fine.
>>> method:
>> the
>> this.
Respectfully,
CL Gilbert
robber."
Re: "One model - many edit parts" problem! [message #218626 is a reply to message #218515] |
Tue, 27 June 2006 12:13   |
Thanks...
Ofcourse this have always been a solution. And I have even try it, but
having the "one model - many parts" sounds much more as the solution for
me, so maybe I will first try to implemented it this way and if I have
many problems I will implemented it the way you have proposed.
And here I come to the question - If I override the refreshChildren()
method would the behaviour of certain classes change in a dramatic way
and would this cause any "hide" problems? Are there any basic guidelines
that I should consider when overriding the refreshChildren method?
Thanks in advance...
> are.
> method
> need to.
> models.
> CL
>>>kiril mitov wrote:
>>>>Hi all,
>>>>bugs.eclipse.org...
>>>>this:
>>>>return list;
>>>>fine.
>>>>method:
>>>the
>>>this.
Re: "One model - many edit parts" problem! [message #218651 is a reply to message #218626] |
Tue, 27 June 2006 14:13   |
I wish I knew. My advise is still the new wrapper class with the tacked on
'boolean isIN()' method. Less pain in the long run.
one model - many parts within the same parent edit part is going to go over
poorly with GEF. If you really want to do it I think you are on the right
path in overriding refreshChildren. I don't think you will see any side
effects right away. They will only come as you begin to implement more
features. For instance, I suppose you are not using an EditPart Factory in
your editor since you must be creating the edit parts in your
Kiril Mitov wrote:
> Thanks...
>> be
>> just
>> children are.
>> not
>> asked for all children, you return the ins and outs, and then these
>> sub/mini
>> added method
>> ones each time else GEF may dump and recreate the editparts when it does
>> not need to.
>> models.
>> CL
>>>very I mean very user friednly to use two edit parts for the same model
>>>and this parts to be in the same parent.
>>>>kiril mitov wrote:
>>>>>Hi all,
>>>>>bugs.eclipse.org...
>>>>>getInVariables(), getOutVariables(), and getInOutVariables().
>>>>>VariablesHolderEditPart. The method getModelChildren() of the
>>>>>VariablesHolderEditPart looks like this:
>>>>>return list;
>>>>>fine.
>>>>>with two edit part. So every inout variable must have two edit parts.
>>>>>method:
>>>>the
>>>>this.
Respectfully,
CL Gilbert
robber."
Re: "One model - many edit parts" problem! [message #218659 is a reply to message #218651] |
Tue, 27 June 2006 14:33   |
Originally posted by: user.domain.invalid
I was thinking of just an "if" statement in the refreshChildren() method.
So if one of the modelObjects is and inout variable I will just use the
addChild() and createChild() methods twice - first for the in part and
second for the out part.
I will still use an EditPartFactory. When the factory is asked to
created an edit part based on an inout variable, it will be smart
enought to know which part to create - the in or the out part. One
approache I was thinking for was to use the context param passed to the
create method of the factory.
So when an inout variable is passed the factory checks if there is an in
part for this inout variable in this context. If there is such a part
than an out part is created. If there is no such part than an in part is
created. Here the edit part is of type VariableEditPart and has a method
isIn() that returns true or false and getTwinPart() that returns the
other part( for in part it returns the out part, and for the out it
returns the in).
So what I should do is first to remove the modelToEditPart map in the
refreshChildren() method and use a custom way to find which parts must
be reordered, added or created. Than I should make the EditPartFactory
rather smart to achive the given functionality...
In fact I have almost implemented this way.
But I still have some doubts whether this is the right solution...
Any help is appreciated...
> Kiril Mitov wrote:
>>Thanks...
>>>be
>>>just
>>>children are.
>>>not
>>>sub/mini
>>>added method
>>>not need to.
>>>models.
>>>CL
>>>>>kiril mitov wrote:
>>>>>>Hi all,
>>>>>>bugs.eclipse.org...
>>>>>>return list;
>>>>>>fine.
>>>>>>method:
>>>>>the
>>>>>this.
Re: "One model - many edit parts" problem! [message #218675 is a reply to message #218659] |
Tue, 27 June 2006 15:39   |
> returns the in).
Let me get this right;
1. add an if to refreshChildren
2. add an if to EditPartFactory
3. create artificial connection between VariableEditPart instances through
getTwinPart.
4. remove the modelToEditPart map.
5. create custom way to order add and create editparts?
vs.
1. Create wrapper around true model adding isIn() method.
2. children() method returns one wrapper model with isIn true and one
wrapper with isIn false in place of original model.
3. VariableEditPart asks model isIn() to know which figure to create (in or
out.)
class DecoratorModel {
private YourModel model;
private boolean in;
ChildModel(YourModel model, boolean in){
this.model = model;
this.in=in;
return in;
//forward all calls to YourModel
ArrayList list = new ArrayList();
for(Iterator It =
getHolder().getInOutVariables().iterator();it.hasNext();){
YourModel model = (YourModel)it.next();
list.add(new DecoratorModel(model,true));
list.add(new DecoratorModel(model,false));
return list;
You say this was always an option. I wonder what about it bothers you, or
what you are not telling us about your requirements?
Respectfully,
CL Gilbert
robber."
Re: "One model - many edit parts" problem! [message #218683 is a reply to message #218675] |
Tue, 27 June 2006 17:17  |
>>returns the in).
> getTwinPart.
> vs.
> out.)
> private boolean in;
> this.model = model;
> this.in=in;
> return in;
> for(Iterator It =
> return list;
Dont get me wrong CL [dnoyeb] Gilbert, there isn`t something I am not
telling. Something I am hiding.
But when considering a Model-View-Controller architecture like GEF I
have always had the feeling that there should be no one to one mapping
between the model and the controller (in this case the edit part). Thats
way it bothers me. I wasn`t feeling it this way...
One of my GEF editors used a "one model - many parts" mapping but with
parts in different parents. There were no problems. Now when I came to
creating the parts in the same parent things got more, lets say "complex".
If creating the DecoratorModel objects is the GEF way, then let it be
the GEF way. No argue :)
Thanks...
Current Time: Mon Sep 15 18:12:43 EDT 2025
Powered by FUDForum. Page generated in 0.06041 seconds
