Home » Newcomers » Newcomers » JDT: how to get the workspace from *.internal.compiler.Compiler.process()
JDT: how to get the workspace from *.internal.compiler.Compiler.process() [message #218117] Tue, 26 June 2007 13:54 Go to next message
Originally posted by: g_karab.cs.concordia.ca
Hi guys,
I have posted the following under the jdt group but I got no reply so I
am asking here as well in the hope I will get some pointers.
I am wondering if there is an "easy" way to obtain the full path name of
the file containing the compilation unit being processed? The
CompilationUnitDeclaration.getFileName() returns a partial path name
relative to the workspace AFAIK. Another workaround to this will be to
be able to obtain the current workspace but I can't see how I can do this.
Of course I can use the Compiler.lookupEnvironment.nameEnvironment and
search for it. Is there any other way?
Any help/ideas is appreciated.
TIA,
George
Re: JDT: how to get the workspace from *.internal.compiler.Compiler.process() [message #218151 is a reply to message #218117] Tue, 26 June 2007 16:41 Go to previous messageGo to next message
Originally posted by: csae7511.uibk.ac.at
what about ResourcesPlugin.getWorkspace() (from plugin
org.eclipse.core.resources) and then search for your file - this should
be possible, since you have the relative path.
When you have the corresponding IFile, it should be no problem to get
the full path (using some method from FileLocator).
HTH,
Stefan
George Karabotsos schrieb:
> Hi guys,
> TIA,
> George
Re: JDT: how to get the workspace from *.internal.compiler.Compiler.process() [message #218183 is a reply to message #218151] Tue, 26 June 2007 19:22 Go to previous message
Thank you so much Stefan for pointing me to the ResourcesPlugin class.
Invoking
ResourcesPlugin.getWorkspace().getRoot().getRawLocation().to String();
gets me the workspace :).
Thanks again for the pointer!
George
Stefan Zugal wrote:
> HTH,
> Stefan
>> Hi guys,
>> I am asking here as well in the hope I will get some pointers.
>> of the file containing the compilation unit being processed? The
>> to be able to obtain the current workspace but I can't see how I can
>> do this.
>> TIA,
>> George
Previous Topic:XML Editor plugin
Next Topic:Putting the existing source code into Project
Current Time: Tue Nov 04 14:10:55 EST 2025
Powered by FUDForum. Page generated in 0.10062 seconds
