Home » Archived » BIRT » Too many ticks are displayed
Too many ticks are displayed [message #218140] Fri, 09 February 2007 04:21 Go to next message
Originally posted by: s.meyer.s2neuinformatik.de
My y-Axis values are numbers with no fraction digits. If the max value is
small - say 2 - then birt will display 6 ticks. Three of them have the
value 0 and the other three the value 1 attached. Setting step to 1 helps,
but generates far too many ticks when the values are much higher.
Is this a bug or can I fix it?
Re: Too many ticks are displayed [message #218157 is a reply to message #218140] Fri, 09 February 2007 10:08 Go to previous messageGo to next message
Set interval in axis properties window.
Regards, Wojtas
www.e-krug.com
Re: Too many ticks are displayed [message #218445 is a reply to message #218157] Mon, 12 February 2007 04:02 Go to previous messageGo to next message
This does not solve my problem. The intervall only says which ticks should
be labelled (every single one, every second one,..). I watn birt not to
display equal values on the ticks. Birt displays ticks for the values 1,5
and 1,0. My formatting does not show fractiondigits therefore I have 2
ticks with the value 1.
Re: Too many ticks are displayed [message #218461 is a reply to message #218445] Mon, 12 February 2007 05:47 Go to previous messageGo to next message
You can set a step of 1.
David
> should be labelled (every single one, every second one,..). I watn
> birt not to display equal values on the ticks. Birt displays ticks for
> the values 1,5 and 1,0. My formatting does not show fractiondigits
> therefore I have 2 ticks with the value 1.
Re: Too many ticks are displayed [message #218477 is a reply to message #218461] Mon, 12 February 2007 08:17 Go to previous messageGo to next message
This will always set the step size to one resulting in 15.000 ticks and
labels if my order count (which is actually the value dispayed) is 15.000.
It looks really messy.
Re: Too many ticks are displayed [message #218972 is a reply to message #218477] Wed, 14 February 2007 11:37 Go to previous message
If you know the min/max of your data, you could use scripting to modify the
scale limits. In any case we are working on fixing this kind of issue in
2.2. See this bugzilla entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142866
David
> and labels if my order count (which is actually the value dispayed) is
> 15.000. It looks really messy.
Previous Topic:DataSet Problem
Next Topic:old report library may have some problems in 2.1.2
Current Time: Sat Jul 26 11:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.67862 seconds
