Home » Language IDEs » ServerTools (WTP) » how to extend HTML tags/attributes?
how to extend HTML tags/attributes? [message #217885] Mon, 21 July 2008 11:50 Go to next message
Is there a convenient way of extending HTML tags/attributes?
Writing something like:
<div myCustomTag="...">
is not accepted by HTML validator.
Is there a way to "improve" HTML validator?
Thanks!
Re: how to extend HTML tags/attributes? [message #217949 is a reply to message #217885] Tue, 22 July 2008 05:09 Go to previous messageGo to next message
Michael Spector wrote:
> Thanks!
IBM did this for a long time. Just write your own DTD. You have the
change the source code of all the browsers to make it work though. This
was done for Mozilla.
http://ln.hixie.ch/?start=1089635050&count=1
Cheers
Philippe
Re: how to extend HTML tags/attributes? [message #217974 is a reply to message #217949] Tue, 22 July 2008 10:14 Go to previous messageGo to next message
Originally posted by: nowhere.a.com
>> Hi,
>> Thanks!
> IBM did this for a long time. Just write your own DTD. You have the change
> the source code of all the browsers to make it work though. This was done for
> Mozilla.
> Cheers
> Philippe
I use custom attributes within HTML tags. Yes the validator complains,
but the browser simply ignores it.
Maybe a project level setting?
div : myCustomTag
etc?
Wojtek :-)
Re: how to extend HTML tags/attributes? [message #217982 is a reply to message #217974] Tue, 22 July 2008 10:26 Go to previous messageGo to next message
>>> Hi,
>>> Thanks!
>> This was done for Mozilla.
>> Cheers
>> Philippe
No, custom attributes is simply invalid.
Cheers
Philippe
Re: how to extend HTML tags/attributes? [message #218013 is a reply to message #217982] Tue, 22 July 2008 14:40 Go to previous messageGo to next message
>>>> Hi,
>>>> Thanks!
>>> for Mozilla.
>>> Cheers
>>> Philippe
>> I use custom attributes within HTML tags. Yes the validator complains, but
For XHTML I agree, but HTML is looser and does "allow" it.
Wojtek :-)
Re: how to extend HTML tags/attributes? [message #218020 is a reply to message #218013] Tue, 22 July 2008 17:17 Go to previous messageGo to next message
The browsers may allow it, but that doesn't make it valid.
In any case, we do have an _internal_ extension point,
org.eclipse.wst.xml.core.modelQueryExtensions, making use of
subclasses of
org.eclipse.wst.xml.core.internal.contentmodel.modelquery.ex tension.ModelQueryExtension
that could be used to add new definitions for what's valid. This
makes use of a number of _internal_ interfaces, however, and is
unsupported beyond its use in WTP, so you'd be on your own. And be
aware that it's easy to torpedo editor performance by misusing it.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: how to extend HTML tags/attributes? [message #218025 is a reply to message #218020] Tue, 22 July 2008 18:29 Go to previous messageGo to next message
Which is unfortunate as it can be useful. I use it inside a <span> to
mark text for special processing. Well, two custom attributes.
The user selects some text in a JavaScript text editor (Xinha), then
clicks on a button. The button surrounds the selected text with a
<span> which contains a custom attribute.
On the server side I parse for the span/attributes, then do the
processing on the text. I then save the original and the processed text
into a DB.
When showing the two texts, the text inside the <span> is in a
different CSS class. So the user can see the selected text plus what
the processing did.
Um, somewhat terse, but I have an NDA...
The alternative would be to subvert and mis-use some standard
attributes.
Wojtek :-)
Re: how to extend HTML tags/attributes? [message #218032 is a reply to message #218025] Wed, 23 July 2008 02:56 Go to previous messageGo to next message
> clicks on a button. The button surrounds the selected text with a <span>
> into a DB.
> When showing the two texts, the text inside the <span> is in a different
> CSS class. So the user can see the selected text plus what the
> processing did.
> The alternative would be to subvert and mis-use some standard attributes.
Why can't you just use a semantic CSS class?
Cheers
Philippe
Re: how to extend HTML tags/attributes? [message #218068 is a reply to message #218032] Wed, 23 July 2008 10:47 Go to previous message
>> Which is unfortunate as it can be useful. I use it inside a <span> to mark
>> The user selects some text in a JavaScript text editor (Xinha), then clicks
>> on a button. The button surrounds the selected text with a <span> which
>> On the server side I parse for the span/attributes, then do the processing
>> on the text. I then save the original and the processed text into a DB.
>> CSS class. So the user can see the selected text plus what the processing
>> did.
There is more there than just UI. The text between the <span> and
</span> is replaced.
Wojtek :-)
Previous Topic:Seems too difficult to remove jars from web project library set?
Next Topic:Buggy 'New Web Project' dialogue
Current Time: Wed Jul 23 12:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.33018 seconds
