Home » Eclipse Projects » GEF » GEF Flow example
GEF Flow example [message #217807] |
Wed, 14 June 2006 08:55  |
Originally posted by: mcglinn.cs.tcd.ie
Hi There,
I am looking into creating a finite state machine and I saw that GEF has
a flow example which would be very useful to me. It would be really
handy if I could use that code to begin with. Is that code open source?
and if so, how do I go about accessing it?
Also, I was hoping to create a sequence dicodeuml sequence diagrams I
could start with?
Any help is much appreciated,
Kris.
Re: GEF Flow example [message #217883 is a reply to message #217831] |
Wed, 14 June 2006 12:30   |
Hey,
Thanks for that. Now, is there an easy way to select the code and import
it into my workspace so that I can compile it? or do I have to create a
project with the same name, create each package and import the code
piece by piece? I have been looking around trying to find a way to
simply import the source code but I dont think I am looking in the right
place,
Thanks for your help,
Kris.
Guillaume Windels wrote:
> Kris,
> Flow example sources (+ other) can be found at
> http://www.eclipse.org/downloads/download.php?file=/tools/ge f/downloads/drops/R-3.1-200507071758/GEF-examples-3.1.zip
> /G
> Kris McGlinn a écrit :
>> Oops,
>> Last part of that seemed to get a bit scrambled. I would also like to
>> create a UML sequence diagram in GEF. Is there any open source code I
>> could begin with?
>> Thanks,
>> K.
>> Kris McGlinn wrote:
>>> Hi There,
>>> has a flow example which would be very useful to me. It would be
>>> really handy if I could use that code to begin with. Is that code
>>> open source? and if so, how do I go about accessing it?
>>> could start with?
>>> Thanks,
>>> Kris.
Re: GEF Flow example [message #217920 is a reply to message #217883] |
Wed, 14 June 2006 17:00   |
Hiya,
You may want to try that:
http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg1 5666.html
/G
> Hey,
> place,
> Kris.
>> Kris,
>> /G
>>> Oops,
>>> could begin with?
>>> Thanks,
>>> K.
>>> Kris McGlinn wrote:
>>>> Hi There,
>>>> I could start with?
>>>> Thanks,
>>>> Kris.
Re: GEF Flow example [message #217944 is a reply to message #217920] |
Thu, 15 June 2006 05:56  |
Hi Guillaume,
Cool. Now, if I have included the GEF plugin in a seperate plugin folder
as an extension, is it still possible to access the plugin example the
way you describe? The thing is, I like to keep plugins seperate from the
main plugins folder...but then they dont seem to appear in the "plugins"
tab beside package explorer?
It wont be a problem just moving the GEF plugin, but it would be nice if
I didnt have to,
Thanks again for your help!
Kris.
> Hiya,
> /G
>> Hey,
>> import it into my workspace so that I can compile it? or do I have to
>> create a project with the same name, create each package and import
>> the code piece by piece? I have been looking around trying to find a
>> way to simply import the source code but I dont think I am looking in
>> the right place,
>> Kris.
>>> Kris,
>>> /G
>>>> Oops,
>>>> to create a UML sequence diagram in GEF. Is there any open source
>>>> code I could begin with?
>>>> Thanks,
>>>> K.
>>>> Kris McGlinn wrote:
>>>>> Hi There,
>>>>> GEF has a flow example which would be very useful to me. It would
>>>>> be really handy if I could use that code to begin with. Is that
>>>>> code open source? and if so, how do I go about accessing it?
>>>>> I could start with?
>>>>> Thanks,
>>>>> Kris.
Current Time: Mon Jun 16 08:13:59 EDT 2025
Powered by FUDForum. Page generated in 0.05465 seconds
