Home » Modeling » GMF (Graphical Modeling Framework) » Removing context menu items from diagram
Removing context menu items from diagram [message #217648] Fri, 06 February 2009 19:31 Go to next message
Originally posted by: nuclearpsyche.gmail.com
I am wondering how to remove certain menu items from the default context menu.
For example when I right click a node on my diagram there's an edit
section. What if I want to remove Copy/Paste and only keep Duplicate
from the Edit submenu? Or what if I want to remove the Filters submenu
altogether?
I would basically like to know where I should look in the code to
customize the context menu.
Thank you very much for your help.
tamer
Re: Removing context menu items from diagram [message #217709 is a reply to message #217648] Sun, 08 February 2009 04:41 Go to previous messageGo to next message
Originally posted by: Erazerx.gmx.de
for some elements it works by adding a extension to the
contributionItemProviders extension point, making a popupContribution
and set remove to false. Here is an example for removing the add-group
and the navigate-group:
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
checkPluginLoaded="false"
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider ">
<Priority name="Low"/>
<popupContribution
id="remove_popup_menu_id"
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass=" org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart ">
</popupStructuredContributionCriteria>
<popupPredefinedItem id="navigateGroup" remove="true"/>
<popupPredefinedItem id="addGroup" remove="true"/>
</popupContribution>
</contributionItemProvider>
</extension>
The IDs for the popupPredefinedItem are defined in the class
org.eclipse.gmf.runtime.diagram.ui.actions.ActionIds.
But i am not sure if this works for all context menu entries this way.
Tamer schrieb:
> menu.
> altogether?
> tamer
Re: Removing context menu items from diagram [message #217765 is a reply to message #217709] Sun, 08 February 2009 22:34 Go to previous message
Thank you! This was very helpful! It did the trick for most of the
menus i wanted to get rid of.
However I don't know how to remove specific menu items from certain
menus. I will keep looking (example: removing the copy/paste from Edit,
and keep the Duplicate menu item).
Thanks again for your help.
tamer
On 2009-02-08 01:41:52 -0800, Arne <Erazerx@gmx.de> said:
> <extension
> <popupContribution
> </extension>
> Tamer schrieb:
>> Hi,
>> menu.
>> altogether?
>> tamer
Previous Topic:[Announce] GMF 2.2.0 I200902071249 is available
Next Topic:Node position relative to another node position
Current Time: Sat Jul 26 12:44:18 EDT 2025
Powered by FUDForum. Page generated in 0.05285 seconds
