Home » Modeling » GMF (Graphical Modeling Framework) » Ocl question- check string is an integer similar to Integer.parseInt(myString)?
Ocl question- check string is an integer similar to Integer.parseInt(myString)? [message #217449] Fri, 06 February 2009 07:12 Go to next message
I would like to ask if there is any way to check if a String is an Integer
using an Ocl constraint.
For example in java you can do something like:
1. Integer.parseInt(myString) and catch the exception or
2. boolean isInteger = Pattern.matches("^\d*$", myString)
Is there any way to perform something similar to the above in OCL?
I tried to use something like self.value.oclIsTypeOf(Integer) but the
oclIsTypeOf property deals with the direct type of an object.
e.g. context Person
inv: self.oclIsTypeOf( Person ) -- is true
inv: self.oclIsTypeOf( Company) -- is false
I tried to use something like self.value.oclIsKindOf(Integer) but the
oclIsKindOf property determines whether value is either the direct type or
one of the supertypes of an object.
Any suggestions how this can be done?
Achilleas
Re: Ocl question- check string is an integer similar to Integer.parseInt(myString)? [message #217480 is a reply to message #217449] Fri, 06 February 2009 08:31 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Achilleas,
Try this:
not self.value.toInteger().oclIsInvalid()
This should check that conversion from String to Integer is feasible.
cW
Achilleas wrote:
> Integer using an Ocl constraint.
> 1. Integer.parseInt(myString) and catch the exception or 2. boolean
> e.g. context Person
> or one of the supertypes of an object.
> Achilleas
Re: Ocl question- check string is an integer similar to Integer.parseInt(myString)? [message #217512 is a reply to message #217480] Fri, 06 February 2009 09:46 Go to previous message
Thanks Christian,
It works just fine.
Previous Topic:Changing a label to a dropdown menu
Next Topic:GMF mapping Audit Rules
Current Time: Fri Jul 18 23:09:56 EDT 2025
Powered by FUDForum. Page generated in 0.04984 seconds
