Home » Language IDEs » ServerTools (WTP) » Facet constraint based on runtime composition as well as runtime version
Facet constraint based on runtime composition as well as runtime version [message #217254] Wed, 09 July 2008 16:03 Go to next message
Originally posted by: fake.thefakers.com
Here's my facet scenario: I would like to specify a facet with 2 versions.
The first version would be constrained to RuntimeA and would ensure that
RuntimeA contained a certain runtime composition component of version 1.0.
The second version of the facet would be constrained to the same RuntimeA,
but would ensure that RuntimeA contained the certain runtime composition
component of version 2.0.
Is this possible to specify in the plugin.xml? Or would runtime composition
need to be enforced in the java code of the facet install delegate?
Thanks!
Re: Facet constraint based on runtime composition as well as runtime version [message #217431 is a reply to message #217254] Fri, 11 July 2008 12:36 Go to previous message
Dan,
Yes, that's possible, but the mechanism is different. Here is the
information that will help you out in this:
http://www.eclipse.org/articles/Article-BuildingProjectFacet s/tutorial.html#runtime.mappings
- Konstantin
Previous Topic:JSDT not parsing alternative fn syntax
Next Topic:JSDT simple question
Current Time: Fri Jul 25 11:11:35 EDT 2025
Powered by FUDForum. Page generated in 0.06900 seconds
